Old 12th March 2008, 18:49   #166 (permalink)
ST7677's Avatar
Originally Posted by Swageo
1300 km on odo. Under 1.5k rpm, engine is very quiet. This is what one would expect from a petrol engine. At 2k, you starts "feeling" the engine at moderate level of spin, and at 3k its reving "high". Driving @ 2k most of the times in city is irritating. I hope either engine will become silent after 10k on odo or I get used to this.
Assuming every thing is fine, you can hardly hear the engine below 3k RPM...
That apart, Civic is a high revving engine. Try going all the way to 7100 RPM you would feel the revs above 4k RPM but below 3k...! I am not sure.
It's one of the most silent engines at lower RPMs...
For the first time, I glanced through the user's manual and it gives some idea on speed vs gear. If we follow that, it requires us to keep engine at close to 2.8k rpm. I don't like this high rpm, low speed driving.
Hmm. that's nice. So I was not far away when I suggested shifting at 2.5k
Anyway, you should make an exception for this rule in 1st gear, besides that it should be fine to follow this.
What more can an enthusiast want - ability to be on high RPM and still get good economy...
But, if you just don;t want to play at that RPM, just don;t bother.
Stay where you feel comfortable. Not much you will loose - little power & little fuel eco... not much.
ST7677 is offline   Reply With Quote
Old 12th March 2008, 18:54   #167 (permalink)
ST7677's Avatar
Just noticed some exhaust gap problem on another thread. This is again something unusual. Might be that higher engine noise due to some issue there...
Old 8th April 2008, 23:31   #168 (permalink)
sanchits's Avatar
Originally Posted by mhafeez_13666 View Post
Friends! Thought I will share my experience after 6000 Kms, about to go for 3rd Service and some accessories which I have fitted.
What I still don't like?
1. The troubling A pillar on the right, but now I am used to it
2. Belly scratch when fully loaded
3. Some kind of noise from the Enigne in slow speed and rev. The engineer
says that it is knocking sound and will go off after 10,000 kms. I am not
convinced.
4. Think the Audio HU has been compromised of Amp power.
5. If I take the car after 2 days, a sound comes from the belly (TAK...)
My Cousin says it is because of moisture and mud getting stuck in the
chassis.???? Same sound when I move the steering in the morning.
Likes
FE: 10 in City with A/C always on. Ideal Bangalore Traffic Conditions
Top Speed 154, went to the new peripheral road near Electronic City
to try but got scared beyond 150 Kmph.
And Everything about Civic. It is such a pleasure to drive.
And of course the STP Son of a gun for the tyres!!
Bye, I love the Civic, what a CaaaaR!!!!!!
hi,
my civic is just 4 months old, even i face the same problems as you hafeez. i too get a "tak" sound from my steering in the morning and if i don't take the car out for more than 2 days, i get the same sound from its belly, a loud "tak". Do you think these noises are normal and are present in every other civic, cause i am not used to hearing these noises from other cars i own or have owned earlier.
Did you check this with honda service guys? what did they say!!!
sanchits is offline   Reply With Quote
Old 8th April 2008, 23:39   #169 (permalink)
sanchits's Avatar
Originally Posted by ST7677 View Post
The HIDs are white only... 6k is white with very little blue tinge.
The halos are blue.
Below is the pic with HID and Halos on together...(also indicator light is on).
hi ST,
what brand HID's are you using and cost. i am planning to get the HELIOS hid kit from dubai. where have u got the ignitors/ballasts fixed. is it a tedious job to get the HID's fixed and do they require some tinkering to get the beam right? what is the bulb type in civic, is it 9006 for the low beam. thanx
Old 9th April 2008, 11:18   #170 (permalink)
ST7677's Avatar
Similar sound comes from my car while starting after few days. I guess it comes from the wheels and n chasis.
Thé knocking sound does reduce substantially after 10k km, but if you are driving in that range where you are getting the knocking sound, you might be hurting you engine.
Sanchit, Mine HIDs are Phillips, costed 20k.Installation was very simple, blast installed by removing wheel liner slightly. Low beam bulbs are 9006.
Old 10th April 2008, 11:27   #171 (permalink)
indivic's Avatar
Hey, that's 3 people already, strange but I did not notice this before.
Can one of you elaborate on the sound, when do you get it , when you turn the wheel or when you just start up.
May be I was too much in love with the car to notice it
The only sounds I have heard is when you get your tires wet and if you pick some gravel/mud on the way, the next thing in the morning the caked mud gets off the tires and when it hits the suspension wall, you get a noise.
indivic is offline   Reply With Quote
Old 10th April 2008, 13:52   #172 (permalink)
I somehow feel its something to do with the brakes locking up when you park/stop the car. I had not touched my car for a couple of weeks and when I started her up, I could hear a similar noise as described. Also when I started to roll slowly out of the parking, I felt as if something was scrapping my tyre. Got the car out in the open, got out and checked. Nothing was there. After that I didn't have any more noises or scrapping. I did a 700 km journey without any more problems.
I will have to check with the dealer when I give her for service.
__________________
Everyone is born right-handed, only the gifted overcome it.
This is my car and I have my wife's permission to say so.
csentil is offline   Reply With Quote
Old 23rd April 2008, 17:32   #173 (permalink)
Hello Friends,
Needed some help from you - basically, I've managed to misplace the main key of my Civic and am currently using the spare one. I'm worried that the main key might have landed in improper hands and could potentially risk losing my baby. So, in this regard, a few queries to this group:
1. Can Honda just "immobilize" the original key and issue me a new one?
2. If yes, would you know approximately how much would I end up paying for that? And is it coverable under insurance?
3. If the above is not possible, would I need to get all the locks changed and get new keys issued? Again, any idea of the costs involved here?
I do plan to call up the Honda dealership and see what they have to say, but wanted to hear if any of you have had a first hand experience in this. Hoping for a quick response from this group!
Cheers!
eMGee is offline   Reply With Quote
Old 23rd April 2008, 18:39   #174 (permalink)
ST7677's Avatar
1st and 2nd option are not possible. You would need to go for 3rd one and it is going to be very expensive, consider it in 5 figures. Locks itself are expensive, and this will include remote locking + immobilizer.
Do make sure that you have definitely lost the key before going for a changeover.
Don;t know about Civic key, but duplicate Skoda Immobilizer Key with remote lock costs about 10k. Yes that's just the cost for a duplicate key!
On second thoughts do some research and find out if the same immobilizer can be reseted to a new code with new keys (with same cut as before, but new immobilizer code), that way immobilizer and lock cost will get saved, only new keys and labor will have to be paid.
It's an intermediate solution - the risk is that the intruder might still gain entry to your car, but the new immobilizer code will not let him start it.
Old 7th May 2008, 20:24   #175 (permalink)
mhafeez_13666's Avatar
Originally Posted by sanchits View Post
hi,
Sorry, I am late in replying. but I figured out the root cause for
one of the 2 "TAK" sounds.! I found out that the Belly "TAK" sound comes when you park your car for more than 24 hrs with the HAND BRAKE on to fullest position!
So what I do now is, I park my car on gear and full flat hand brake and lo!! the sound has never come so far!!!???
Any Logic behind this???
But the steering sound is still there :-(
mhafeez_13666 is offline   Reply With Quote
Old 9th May 2008, 01:09   #176 (permalink)
nitinralli's Avatar
Hey, did anyone had the suspension problem with the civic?? i heard from lot of prople that the rear suspensions are very soft and if 2 people are sitting at the back, the car starts hitting speed breakers.
nitinralli is offline   Reply With Quote
Old 9th May 2008, 03:48   #177 (permalink)
Team-BHP Moderator
Rehaan's Avatar
See these threads as well >
http://www.team-bhp.com/forum/modifi...uspension.html (honda civic suspension)
http://www.team-bhp.com/forum/indian...ion-issue.html (It's Official: Mid-Day report on Civic Suspension issue)
cya
R
__________________
The memory of you will ride by our side forever.
Old 10th May 2008, 00:11   #178 (permalink)
ST7677's Avatar
Great, this solved my Tak problem - I was guessing it comes from brakes
Can some one help me where can I find paint code for Civic?
The manual says it's on the driver side Jamb, but I can't find it there (or on the other side). I found the engine No, Vin No, chassis no there but paint code is not there.
Old 13th May 2008, 23:55   #179 (permalink)
ST7677's Avatar
Help, I need to know where can I find paint code for my Civic?
Some one there... ... ... ... ...
Thread Tools
Swift Diesel (LDi) Ownership review after 12000 km RufRoc Long-Term Ownership Reviews 30 14th May 2008 13:48
Swift VDi ownership: A Running report GeekSrik Long-Term Ownership Reviews 773 9th May 2008 11:57
Palio 1.2 NV - Ownership Report - 11000 kms finneyp Long-Term Ownership Reviews 21 7th December 2006 22:59
Petra 1.6 ownership report sreenivass Long-Term Ownership Reviews 0 13th November 2006 22:00
Elantra Ownership Report (10000KM) convivial Long-Term Ownership Reviews 0 30th October 2006 10:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
