Old 28th May 2013, 10:57   #526
Thanked: 869 Times
Default re: The First Grand Vitara Ownership on Team-BHP [6 years & 70,000 completed]
Not that interesting. Only the knob is in N mode, not the transmission.
Oh OK, then not so interesting. My understand of N mode was the same, so I was a bit puzzled that he drove in "N".
BTW, does GV come with factory fitted high running breather tubes for the diffs and transmission?
anandpadhye is offline   Reply With Quote
Old 29th May 2013, 10:02   #527
Thanked: 869 Times
Never mind.
I looked up on other forums and found the info:
http://www.suzuki-forums.com/2g-2006...breathers.html
Looks like the older GV (XL-7) had better designed breathers than the current model: http://www.suzuki-forums.com/2g-2006...tml#post315954
Old 29th May 2013, 10:59   #528
crazydave's Avatar
Thanked: 27 Times
Originally Posted by anandpadhye View Post
Never mind.
Thanks for this information Anand. Does your Tucson have this feature, are there other SUVs in India with these? Would be interesting to check them and see how these breathers have been implemented. It definitely looks like a very useful addition to have, especially in waterlogged cities like Mumbai!
crazydave is offline   Reply With Quote
Old 29th May 2013, 18:36   #529
sudev's Avatar
Thanked: 1,850 Times
Posting here instead of my ownership thread and seeking inputs and explanations.
My GV has touched 2lac kms in five years. Sadly the price of petrol in last two has meant that I have barely notched up 50k out of these. Now my vehicle is in the garage for the second replacement of air conditioner compressor.
Symptoms: For past 20k kms the air conditioner would either work fantastically or not at all. Worst was that the few times in between when I went to the workshop it would keep working. I was not able to replicate symptoms at will.
Went through lot of eliminations step by step. Since there was a friends rally GV available we swapped climate control system, high pressure/low pressure valve relay, gas change, VAG testing...but symptoms were difficult to catch.
Last month fortunately the symptoms appeared while getting the car washed at MotorCraft garage and again we observed that everything seemed to work including a/c clutch but the pressure gauges did not show compression being developed. The aircon mech said that probably "reed valve" are getting weak and so compressor does not work continuously"
Got this diagnosed at two more a/c workshops with similar conclusions. "Compressor change kariye ji"
So today the compressor was removed and this is picture of compressor oil when drained:
Name:  20130529 17.33.29.jpg
The small metal particles were found in the oil and also the silca gel strainer which is built in to the circuit after the post compression "outside hot" heat exchanger. So the culprit is wear and tear and when any of these metal particle was stuck in reed valves of the compressor it would not develop pressure for air-con to work. No repairs possible and change is inevitable.
On further questioning I was told that even last time similar -tough much more - particles were found. That was when car had run roughly 1.5 lac kms.
Now my question is why in two lac kms twice this has happened? Is there a design issue in GV or does this happen in other vehicles also? Is some contributing cause like bad gas being charged?
Gyaan please.
sudev is online now   Reply With Quote
Old 30th May 2013, 11:49   #530
Thanked: 869 Times
I don't think Tucson has extended breathers, I am going to find out this weekend when we are going to replace the diff oil and get these long breather tubes installed if possible. I think the hard-core SUVs like Gurkha have these.
Gyaan please.
So was the compressor replaced at 1.5L km or just serviced?
From what I have read, this indicates wear and tear of the compressor and eventually it has to be replaced. The root cause can be lack of lubrication (compressor oil leaking slowly, or underfilled in the first place, etc).
"Contamination
A/C systems can be contaminated with metal particles from the normal wear of the compressor and tiny amounts of water moisture. Contamination can cause a system to fail. Protection against contamination is provided by the filter screen on the Expansion Tube and the desiccant in the bottom of the dryer or accumulator. Other forms of contamination may be the wrong kind of oil, wrong kind of freon or other material that will interfere with the cooling system. Almost 100% of moisture is normally removed from the system when it is evacuated prior to installing freon."
Source: http://www.blendair.net/dictionary.html
"Most compressor failures are caused by loss of lubricant and/or refrigerant. Repeat failures are usually due to system ­contamination (sludge or metallic particles from a previous compressor failure)"
Source: http://www.underhoodservice.com/Arti...h_problem.aspx
http://www.ebay.com/gds/Automobile-A...0932422/g.html
"The problem with replacing a bad compressor that is damaged internally is removing all a little metal particles from the system. Often both driveway and professional mechanics would like to just blow compressed air through the lines in the hopes that all of the pieces will be dislodged and removed.
The reason this doesn’t work is because the system contains an oil charge. This oil sticks to the inside surface of all of the lines and tubes. The metal particles then stick to this oily film. This is why the proper procedure is to use a liquid flushing agent to flush the AC system.
The AC flush chemical has similar properties to brake clean. When the liquid is forced through the system the oil is washed out and the alcohol base of the AC flush will dry the interior surfaces of the lines. With no more sticky oil film holding the little metal particles they are easily removed.
One of the components that cannot be completely cleaned with the AC flush procedure is the receiver drier. This component should be replaced along with the orifice tube when you are replacing the AC compressor itself. Flushing the AC system will not remove metal particles from the orifice tube or the receiver drier.
If someone replaces your AC compressor for you make sure that you’re getting your money’s worth and that they are performing the proper procedure. Ask them about how they will flush the system and how long they will guarantee the replacement of the compressor. This will often force them to take the extra step and do the job properly."
Source:
http://www.certifiedmastertech.com/w...r-replacement/
"If you have an internal compressor failure you want to make sure that you completely flush the system with the specialized liquid chemical to protect your investment in the new or re-manufactured compressor. blowing air through the system is not good enough.
The AC oil in the lines can actually hold onto the tiny little metal particles. This is why air-conditioning flushing is done with a special fluid that removes the oil and the tiny little metal pieces. Properly flushing the lines is time consuming. Flat rate mechanics can be tempted to take short cuts.
If you skip this step or cut corners by not flushing all components, when you refill the system with Freon these little metal particles can work their way back to the new compressor and destroy it. I can't tell you how many times I have seen this. It can get very messy as the customer blames the shop, the shop blames the parts company and the the part company blames the shop."
Source: http://www.youfixcars.com/car-AC-problems.html
Can you check what your orifice tube looks like? e.g.:
http://ls1tech.com/forums/general-ma...-what-now.html
anandpadhye is offline   (1) Thanks Reply With Quote
Old 30th May 2013, 15:55   #531
crazydave's Avatar
Thanked: 27 Times
Thanks! Do post details on how you went about installing these please. Sounds like a very good and essential mod to have
Old 15th July 2013, 22:44   #532
I am the proud owner of a 2007 Grand Vitara. I managed the car at a steal and now I need to get some work done on the car to make it picture perfect. There are small niggling issues that can be tackled over time but the one that needs urgent addressing is suspension.
Before I bought the car, I took it to my mechanic (who quoted 65,000) and the MASS (who quoted 90,000). After purchase, my mechanic quotes about 80 - 90 for the suspension alone. Any advice would be appreciated. Can/ Should I order the suspension kit online? Some of the sites retail at unbelievably low costs. All suggestions welcome.
I am taking the car to Vitesse in Andheri tomorrow and will get a total check from them as well.
Thanks in advance.
DrGonzo is offline   Reply With Quote
Old 16th July 2013, 08:10   #533
sudev's Avatar
Suspension is a mix of many things. What all is being replaced? The quote will be according to that. The SGP prices are reasonable for most of the GV stuff.
What is the ODO at? More information.
Old 16th July 2013, 10:11   #534
The ODO reads 50,000 kms. But I suspect it might have run more.
I'm dropping off the car at Vitesse Worli and hopefully should have a quote by end of day. If I need to drop off the car for two weeks, this will be perfect time as I'm travelling for 10 days.
Old 16th July 2013, 22:17   #535
sudev's Avatar
At 50k shockers/struts should not be a problem. Rubber bushing would have hardened due to aging but that should not set you back more than 10~15k. Do share list of jobs they are quoting.
Even at 75k the above should hold true.
Old 16th July 2013, 22:39   #536
Lower arm bushes + service + brake pads + Discs + polishing of headlamp for an estimate of 80,000. I assume, if I spend a 100,000 I should be able to get the car in good condition.
Old 16th July 2013, 23:11   #537
Samurai's Avatar
Thanked: 12,822 Times
Boy, they are taking you for a royal ride.
Check these:
Today the GV was picked up from my office by Abharan motors at 11:30AM and delivered back by 4:30PM. Both the lower arms, 4 spark plugs and the air filter was replaced. All these parts were not available in stock during the last service.
Each lower arm cost me Rs.6411/- and the total bill today came to Rs.17,244/-
And the disc brake stuff:
The First Grand Vitara on Team-BHP [113000 KMs & 9 Years]-grandvitara-service-22.12.11.jpg
The cost of disc brake and brake pad set is roughly 5K each. If you replace both discs and pads, you will be poorer by 21K. Two lower arms will be 13K. You do the math.
Samurai is offline   (1) Thanks Reply With Quote
Old 17th July 2013, 00:17   #538
When the supervisor called me and was giving a part breakdown I think he said the lower arms are for around 9 grand each. Could the rates vary because of the dollar? It's a quote from Vitesse, Prabhadevi and lots of people swear by them. Maybe, I'll give it to another service centre and get another quote.
Old 5th August 2013, 13:06   #539
So... after torrential downpour in Bombay when I came back, my car refused to start. So after a battery change and a tow to the service station, I finally get my car back tomorrow.
So this is what my total expenditure on this buy has been.
Car - 3.25
Battery 6
Suspension - lower arm bushing - 20
Disc brakes and pads - 22
Service (completed 50,000) - 15
Key barrel - 5
What I am left with is AC (that needs to be checked and costs 6 upwards. Letting that be for now).
Not bad for 3.95 (Will soon get a CNG kit fitted for city driving).
Old 5th August 2013, 16:59   #540
aditbelw's Avatar
Thanked: 40 Times
Long due! A few pictures of my GV.
Apologies for small write up, as there is not much to say on the buying process. Better half wanted an SUV as she never get's to drive my Octavia RS, found one & got it home all in 48 hrs! Very happy with the car, but sometime does occur that the engine is a teeny weeny under powered, specially after driving sedans! A few mods already have been done, a few more on the cards!
aditbelw is offline   (1) Thanks Reply With Quote
Which is better - A car which has driven 1 lac kms in 4 years or 35,000 in 6 years syravi Technical Stuff 41 7th May 2016 16:21
Suzuki Grand Vitara: 2,32,000 kms & 7 years ownership sudev Long-Term Ownership Reviews 412 24th December 2015 13:30
First Embera CRDi owership experience on Team-BHP EDIT: 2 years, 28,000 kms update rohitrk Long-Term Ownership Reviews 101 21st June 2013 23:01
First off-roading with Grand Vitara Samurai 4x4 Excursions 153 23rd March 2010 19:13
Wheel rotation in Grand Vitara at 5000 kms GRV Technical Stuff 5 27th January 2008 09:51
