Old 3rd June 2015, 21:03   #661
vigsom's Avatar
Thanked: 482 Times
Originally Posted by srinand View Post
clutch plates, clutch cover and releaser bearing by the A.S.S. The costs are as follows;
Clutch plates 7200.
Clutch cover 7500.
Releaser bearing 15000.
Service charges approx 2000, total about 25k.
Per info that I have the clutch and pressure plates cost 10.5k and the release bearing 3.1k.
Please check Part nos. 22100-65J00+22400-65J20 for the clutch disc and cover assembly and 23810-65J00 for the clutch cylinder assy.
I would suggest you verify the costs at the authorised parts distributor before going ahead.
Originally Posted by sridhar-v View Post
The indicator on the dash was showing 8kmpl average while my actual calculations came to 8.87 kmpl.
The dash indicator can be misleading ; it calculates an approx. FE based on speed and engine rpm.
If you are on 235/70R16 tyres , your odo will show 2%less distance covered .So please add 2% to your calculated FE (OE tyres are 225/70R16)
I am going to replace the high beam bulbs with Phillips Xtreme Vision halogens. And later do the same for low and fogs. That should give more than enough light.
The lows are HIDs and better left untouched.You could try Xtreme vision bulbs on the highs - but replacement is a little tricky, especially on the left headlamp assembly where you will find very little room to twist and put the new bulb back.
vigsom is offline   (1) Thanks Reply With Quote
Old 4th June 2015, 10:01   #662
Thanked: 654 Times
Default re: The First Grand Vitara Ownership on Team-BHP [100000 KMs & 8 Years]
I am running on standard 225/70 R16 tyres.
I am going to get the throttle body cleaned during the steering parts replacement. Let me see if there is any improvement.
Other than that the only simple change would be to go in for a K&N filter in place of the standard one. Will do that next and see if there is any improvement.
The basic reason for low consumption is the insufficient torque upto 2000 rpm. Due to this the AT box keeps in lower gear affecting consumption. For my sedate driving style turbo charging will not work as the benefits start after 2000 rpm. Supercharging would be too costly. So possibly I will try a piggy back ecu or something. Have ordered a OBD2 bluetooth scanner to start with. Will start a separate thread to record my experiences.
The low beam bulb is Halogen. It is a low beam only projector system.
sridhar-v is offline   Reply With Quote
Old 5th June 2015, 20:46   #663
condor's Avatar
Thanked: 3,045 Times
One 2.4L GV has come up in our classifieds.
http://classifieds.team-bhp.com/buy-...d-Vitara.html/
Old 5th June 2015, 21:24   #664
Samurai's Avatar
Thanked: 11,949 Times
Wow, and he has priced it reasonably unlike the ridiculous prices I see for Fortuner of the same vintage. Keep in mind it costs almost as Fortuner for a new one.
I hope someone who knows the true value of Grand Vitara 2.4L gets to own it, assuming it has a clean record and is well maintained.
Old 6th June 2015, 18:35   #665
patil's Avatar
Thanked: 54 Times
Hi Guys,
Can anyone advice me on how to fix the rattle of parcel tray on top of the boot in the Grand Vitara.
patil is offline   Reply With Quote
Old 6th June 2015, 23:26   #666
Samurai's Avatar
Originally Posted by patil View Post
Hi Guys,
Never heard of this before... why does it rattle, it is secured pretty well.
Samurai is offline   (1) Thanks Reply With Quote
Old 7th June 2015, 14:14   #667
patil's Avatar
Thanked: 54 Times
The locks are worn out and with every jump such as a pot hole or a speed breaker it makes noise as it jumps with the car. I hope I could explain it properly.
Old 8th June 2015, 10:47   #668
Thanked: 654 Times
In my car the clips fall off from the u-hooks whenever the rear seat is reclined.
A Juggad fix would be as follows:-
Use insulation tape and wind on the hook till the play reduces. However you will not be able to use the parcel tray frequently. Same can be done for where the tray side lugs fit into the trim recesses.
@Samurai,
I am planning to upgrade to the MapmyIndia head unit. I am planning to install component speakers, with passive crossover, in the front.
I find that there is a subwoofer unit under the front passenger seat. But the service manual does not show any separate wiring for the same. Are you able to separately control the subwoofer volume? Did you change any speakers?
sridhar-v is offline   (1) Thanks Reply With Quote
Old 8th June 2015, 11:19   #669
Samurai's Avatar
Keep in mind the software is very buggy, while it looks very neat.
I am not really into ICE, I have't tried to change speakers or other components.
Old 8th June 2015, 11:46   #670
Thanked: 654 Times
Is it the navigation software or the overall unit that is buggy?
Old 8th June 2015, 17:30   #671
Samurai's Avatar
The navigation software is Okish, but the rest is worse. It does hang once in while. The MP3 player has a mind of its own, be happy it at least plays.
I was advised to change the clutch plates, clutch cover and releaser bearing by the A.S.S. The costs are as follows;
Clutch plates 7200.
Clutch cover 7500.
I just drove this Grand Vitara. There is nothing wrong with the clutch pedal or the clutch. I could accelerate quickly on level roads in 5th, climb flyovers in 4th, etc. The clutch pedal feels just like it does on any other Vitara. But I agree not everybody can be happy with that. But there is a way out.
Behind the pedal, look for the following components and remove them. It will make clutch pedal operation much easier. Do this at your own risk, I don't know the long term affect of this surgery.
The First Grand Vitara on Team-BHP [113000 KMs & 9 Years]-img20150531wa0001.jpg
Old 8th June 2015, 18:46   #672
Jaggu's Avatar
Thanked: 5,271 Times
Attachment 1379809
That is the clutch pedal return spring. GV has hydrolic or cable system for clutch?
If you don't rest your foot on the clutch pedal while driving, removing the spring should not cause an issue. But if you do you will slip the clutch and won't even realize it.
Jaggu is offline   (1) Thanks Reply With Quote
Old 8th June 2015, 18:58   #673
Samurai's Avatar
It is a hydraulic clutch, and Sachin has removed these parts from his Vitara clutch pedal and he is doing fine without it.
Old 8th June 2015, 19:01   #674
Jaggu's Avatar
As i said earlier, it should be fine as long as one does not rest foot on the pedal. The pedal weight by itself would not move the clutch (without any force applied) i guess.
Old 8th June 2015, 19:27   #675
Desmosedici's Avatar
Thanked: 402 Times
@Samurai,
I have seen many pics of the Pioneer Touchscreen HUs installed on the GV. I would however admit that the MMI unit looks perfect though on the GV Console. Since you want to add Comps etc dont you think a Pioneer, Alpine, JBL, Sony etc would make sense rather than the MMI unit. And i think even these units can be teamed up with the Steering Controls easily.
http://pioneer-india.in/product-cate...nt/head-units/
I have been eyeing these for some time now. Just waiting to get a GV first
Desmosedici is offline   Reply With Quote
Which is better - A car which has driven 1 lac kms in 4 years or 35,000 in 6 years syravi Technical Stuff 41 7th May 2016 16:21
Suzuki Grand Vitara: 2,32,000 kms & 7 years ownership sudev Long-Term Ownership Reviews 412 24th December 2015 13:30
First Embera CRDi owership experience on Team-BHP EDIT: 2 years, 28,000 kms update rohitrk Long-Term Ownership Reviews 101 21st June 2013 23:01
First off-roading with Grand Vitara Samurai 4x4 Excursions 153 23rd March 2010 19:13
Wheel rotation in Grand Vitara at 5000 kms GRV Technical Stuff 5 27th January 2008 09:51
