Old 18th January 2016, 23:53   #766
harjeev's Avatar
Thanked: 256 Times
Default re: The First Grand Vitara on Team-BHP [100000 KMs & 8 Years]
Hi Guys,
This is my first post on this thread. In my opinion this thread should be renamed as an Encyclopedia and Maintenance Manual for Grand Vitara Ownership In India. I've been a lurker on this thread for quite and while and have been reading posts, comments and discussions since years never ever even remotely thinking that one day I might lay my hands on such a vehicle. Reading and Re-reading this thread gave me enough confidence to finally take the plunge last week.
I finally got my hands on a November 2008 Suzuki Grand Vitara and have started my thread on the Test Drive And Initial Ownership Reports Section to document the decision making, buying and initial ownership report.
Here's the link to the thread
The Red Devil Makes Way For the Silver Fox - My 2008 Grand Vitara
Await expert comments and opinions.
harjeev is offline   (2) Thanks Reply With Quote
Old 22nd January 2016, 18:10   #767
Samurai's Avatar
Thanked: 12,547 Times
Today morning I was at a temple for a puja. Being morning hour and all, they had no other customers except us. Few temple admin staff were seated right opposite where I had parked the Grand Vitara, the only car in the lot. So, they were obviously taking a long look at the vehicle in the 90 minutes it was parked there.
As I came out of the temple, one of them suddenly asked...
He: How much was the cost?
Me: Huh, for what? [bit annoyed that he might be asking the cost of the puja, not really his business]
He: I mean the car, how much is it on road?
Me: Oh... the car. You think it is new?
He: Huh, it isn't?
Me: No, it is 8 years old and has run over 1 lakh kms.
He & others: but.. but.. it looks new.
Me:
Couple pics from yesterday at my office campus.
Samurai is offline   (14) Thanks Reply With Quote
Old 22nd January 2016, 19:39   #768
sudev's Avatar
Thanked: 1,808 Times
LOL...that is one awesome looking car.
sudev is offline   (1) Thanks Reply With Quote
Old 22nd January 2016, 20:32   #769
Vid6639's Avatar
Thanked: 17,730 Times
Me:
Looks good. How is it holding up?
The detailing has done a world of good to that car. Much much needed.
Vid6639 is offline   (1) Thanks Reply With Quote
Old 24th January 2016, 10:56   #770
Thanked: 40 Times
I recently acquired a BAFX OBDII reader from the US. Hooked it up with Torque App. The app talks with the reader however it seems that it is not getting any values from the ECU. Anyone have success with the cheap OBDII-bluetooth readers on the market with their GV? When I was researching this, just floored by the amount of data that can be at our fingertips via this approach.
-Vivek
joshiviv is offline   Reply With Quote
Old 24th January 2016, 15:12   #771
sudev's Avatar
GV does not use standard compliant port. For that matter none of Suzuki use standard port.
sudev is offline   Reply With Quote
Old 24th January 2016, 17:21   #772
Thanked: 669 Times
I used one cheap scanner, on my Grand Vitara, and it turned out blank.
While the physical wiring is compliant to ISO9141/SAEJ1962, the actual signalling protocols are totally non-standard. And Suzuki charges to reveal this. So cheaper scanners will be blank.
EasyDiag claims to support all Indian cars. a4anurag is using one on his Swift:
http://www.team-bhp.com/forum/techni...-software.html ($50 only! Launch X431 OBD-II Scanner with Maruti & Hyundai software)
If you are inclined you can try out this one. Available from their online store
www.cnlaunch.com
sridhar-v is offline   Reply With Quote
Old 24th January 2016, 18:11   #773
Thanked: 40 Times
www.cnlaunch.com
Thanks, That thread gives me hope esp since Vitara seems to be one of the models covered. I think even with the cheap ones you can enter some strings (PIDs) in Torque Pro to get the readings from the car. Went through the torque forums but didn't find the right answers.
Old 1st February 2016, 13:23   #774
Thanked: 669 Times
For various reasons my usage of the Grand Vitara has dropped and will remain low till the monsoons. I had changed the battery recently, but I am planning to get a battery charger to be on the safe side. The service manual says that for jump starting cable from positive of external battery should be connected to +ve of battery. Cable from negative of external battery has to be connected to the exhaust manifold or some other earth on the body. Upto now in all instances of jumpstart I have seen direct battery to battery connections. Why is the manual calling for negative to be connected differently? Will the same requirement apply for battery charging?
Old 7th February 2016, 16:45   #775
Thanked: 40 Times
Direct battery to battery connections can lead to some sparking. The best practice is to connect +ves first, and see if chassis grounding works for you. Regarding battery charger, try getting a trickle charger if you have an electrical outlet close to where you park. With trickle charging the amount of current you send is too low to cause any sparking. You can also try using a solar battery charger if you get some sunlight. This one you can actually keep connected all the time, so wont have to disconnect when you drive. In fact I was looking at some on Amazon.com but realized that they won't work too well in the basement where I park.
joshiviv is offline   (1) Thanks Reply With Quote
Old 23rd March 2016, 11:42   #776
Samurai's Avatar
Default re: The First Grand Vitara on Team-BHP [113000 KMs & 9 Years]
Until 40,000Kms of usage, the MRF Wanderer tyres were looking as if they have done only 10K or so. But the wear has suddenly increased, like a 40 year man suddenly hurtling towards baldness. I am shocked at how much wear has happened in the last 2-3K kms. I was planning to wait until the tyres turn 50K, but I don't see a point in waiting.
I am planning to change the tyres by next month.
I was thinking about Michelin Latitude Cross, but the reviews left me disappointed. Users are claiming only 22K kms life and the tendency to get punctured a lot. I don't need either of the pains. The Michelin LTX AT2 lasted me well for 40K kms last time, should I repeat it?
I need at least 40K+ life with high resistance to punctures, good ride, good handling, and less noise. What are my choices these days? The size I need is 235/70R16.
Old 23rd March 2016, 12:06   #777
condor's Avatar
Thanked: 3,280 Times
My Latitude Cross are going good @3 yrs / 50k with 5 tyre rotation. Quite some life left. I did have 2-3 punctures, but that has been routine.
But Latitude Cross may not be available currently.
condor is offline   (1) Thanks Reply With Quote
Old 23rd March 2016, 12:39   #778
Jaggu's Avatar
Thanked: 5,864 Times
Check MRF wanderer is available for the size, i am quite impressed with them after using a friends duster 4x4.
Old 23rd March 2016, 19:19   #779
Samurai's Avatar
Dude, I am on MRF Wanderer since 2012. Looking for some change now.
Old 23rd March 2016, 21:31   #780
Thanked: 669 Times
Have a look at the Geolander A/T-S. I had briefly driven thewhiteknight's Grand Vitara during our first off road and I could immediately make out its superior grip vis a vis my G92S. It seemed much quieter also.
Which is better - A car which has driven 1 lac kms in 4 years or 35,000 in 6 years syravi Technical Stuff 41 7th May 2016 16:21
Suzuki Grand Vitara: 2,32,000 kms & 7 years ownership sudev Long-Term Ownership Reviews 412 24th December 2015 13:30
First Embera CRDi owership experience on Team-BHP EDIT: 2 years, 28,000 kms update rohitrk Long-Term Ownership Reviews 101 21st June 2013 23:01
First off-roading with Grand Vitara Samurai 4x4 Excursions 153 23rd March 2010 19:13
Wheel rotation in Grand Vitara at 5000 kms GRV Technical Stuff 5 27th January 2008 09:51
