Old 29th September 2016, 09:30   #871
Samurai's Avatar
Thanked: 12,818 Times
Default re: The First Grand Vitara on Team-BHP [113000 KMs & 9 Years]
Originally Posted by thewhiteknight View Post
Question: Why did you go for an external based sensor, given that it is extremely easy to steal/break/etc? i know the battery/range effectiveness and potential issues but wouldn't the internal sensor based unit be more effective, overall?
The sensors have a theft-proof reverse nut, it is very hard to remove it without the right tool. Also, I rarely ever park my car on streets. It is parked in gated area most of the time.
Besides, I didn't buy the same item as Tejas. I looked for a very popular TPMS system in Amazon.com, with great reviews, then ordered the same item from Aliexpress.
Also, where on Earth did you find the reverse opening umbrella? That is so interesting!
As I said before, found it from Tejas's thread. It is on snapdeal.
lastly, I am resorting to LED bars for close flood and far spot lighting--were you able to find any solution to your fog lamps? I recently received a 120W 12 inch combo bar, will put up pictures of it once I have it on for testing.
I have learned to be happy with the stock fog lamps, they are pretty good actually.
Samurai is offline   (2) Thanks Reply With Quote
Old 29th September 2016, 11:41   #872
Thanked: 132 Times
Since i don't have a Grand Vitara, i could only steal the Reverse Umbrella idea.
Ordered the same.
-- Torqy
Torqy is offline   Reply With Quote
Old 29th September 2016, 11:50   #873
Samurai's Avatar
Ordered the same.
You can install TPMS on any car.
Yesterday afternoon I had carefully managed fill all tyres with 31psi. When I took off at night, only LF showed 31, rest showed 29psi. Today morning only RR is showing 29, and rest are back at 31psi. Now I am wondering how accurate is this thing...
Old 29th September 2016, 15:20   #874
Thanked: 132 Times
I had read these to be more accurate and reliable than internal sensors. But 6% error seems to be on the higher side. If it's not difficult to remove / install maybe you can check with a normal pressure gauge.
Old 30th September 2016, 20:36   #875
Samurai's Avatar
Now I am getting some idea about this. It shows 31 on all tyres during the day time. When I take off at night, it is pretty cool, it shows 29 on all tyres. It is back to 31 by 11am. Today I drove 20kms, the pressure went to 32. Generally my commute is about a km.
Samurai is offline   (1) Thanks Reply With Quote
Old 5th October 2016, 14:54   #876
Hi to all the members on this thread.
I have been following your thread for a while now as I have had a love for Grand Vitaras for a long time and FINALLY got myself a silver 2008 MT 2.0 with 50k on the odo. New Tyres, new battery and a very clean vehicle that belonged to a friend of a friend.
A special thanks to Sudevji who I contacted and got his advice and help when I was checking out the prospective buy.
I will post pictures soon of my new love.
A BIG question as of now - most posts I saw of 2.0 MT earlier stated a FE of 8-10 in the city. Mine is giving only 6.8. That too with a very light foot on the accelerator and all my attempts to keep the rpm and gear shifting as required. It has 235/70 Tyres so I assume I am losing about .5 km because of that. I took my GV to Motorsport in Noida and Rahul drove it and got it checked at the pit. He says its in pristine condition and a good purchase.
What advise would you folks give on what I should look for / fix to come up to around 9km.
ManuKohli is offline   Reply With Quote
Old 5th October 2016, 20:28   #877
vigsom's Avatar
Thanked: 515 Times
^^ Manu,
Both of us have/have had a Corolla and a GV.Welcome to the GV club
As far as FE goes , you can't do much except clean the plugs and set the gap to 1.1mm.
Why don't you reset the FE average by pressing and holding the button for a few secs.The meter will start calculating the FE basis your driving habits and traffic conditions
Old 5th October 2016, 23:22   #878
Vigsom
Thanks for your input.
As for resetting the meter - done that. It shows at 6.7
Have been wondering if I should get the iridium plugs everyone talks about. Called ngk dealer in Delhi today, but he did not seem to have the irridiums.
Am going to check with another source tomorrow to see if he can arrange them.
Do you think the irridiums will help?
Old 6th October 2016, 08:45   #879
Thanked: 680 Times
Originally Posted by ManuKohli View Post
Vigsom
I have a 2007 AT. I changed to Iridium sparks last October. I also had the throttle body cleaned and changed all oils & fluids, along with the air filter. I used the standard paper type air filter.
Fuel average has improved by 1kmpl. Driveability has improved substantially, particularly at low speeds. I get an average of 7-8 kmpl in city. Though my city drives are short and do not involve bumper to bumper traffic. Off-roading, bad roading and hill drives gives between 7-9 kmpl.
You should definitely get about 8-9 in the city. But the 2L engine does not like inching in traffic so it is a trade-off.
sridhar-v is offline   Reply With Quote
Old 7th October 2016, 09:14   #880
Congratulations on your purchase. I got my GV in June this year, 2. MT done 1 lakh on odo. The FE is 6.6 on crowded Mumbai roads and 10 something on highway (AC on). I think this is normal for GV.
spgv is offline   Reply With Quote
Old 7th October 2016, 13:35   #881
Spgv. Thanks
Sridhar - the irridiums mentioned by someone on a post earlier were ngk IFR5J11 but the only ones the ngk authorized dealer in Delhi has for the GV are BKR6EIX-11
I even checked NGK India website and they mention the BKR6EIX-11 as irridiums for GV.
Do you have any idea about this?
Old 8th October 2016, 07:17   #882
Thanked: 680 Times
Spgv. Thanks
From what I remember the 5 series of plugs run cooler than the 6 series.
In the printed owner's manual for my GV IFR5J11 is recommended, though online manuals recommend the IFR6J11 . BKR6EIX-11 seems to be the nomenclature for the new models of 6 heat range irridiums.
As the engine bay is pretty crowded, I have noticed that temperature there is higher than in my other cars. So I am happy with the cooler running plugs. Besides we do not get snow and ice down here in the Deccan plateau.
You can order the plugs through the retails sales counters of Maruti.
Old 9th October 2016, 08:52   #883
vigsom's Avatar
Thanked: 515 Times
^^ Sridhar San,
In the case of Bosch and Champion, a higher number means a hotter plug.
In NGK , a lower number means a hotter plug.
IFR5J11 is the recommended plug for the 2.0GV.That may be because the GV generally runs in colder weather worldwide.Pune sees moderate climate at least 9 months in a year so it is fine.
I think ManuKohli should be fine even with the 6E-11 plug.
vigsom is offline   (1) Thanks Reply With Quote
Old 9th October 2016, 09:15   #884
Thanked: 680 Times
Originally Posted by vigsom View Post
^^ Sridhar San,
I stand corrected. Thanks.
Then actually the 6 heat range should be ideal for Pune. Will change it next time sparks are due for change - 40K kms hence.
Would be interested in seeing how the 6 heat range plugs stand up in the Delhi cold.
Old 9th October 2016, 19:10   #885
tsk1979's Avatar
Thanked: 15,277 Times
I don't think heat range depends upon ambient temp. Spark plug heat range should be chose based on the engine characteristics, and only modified if you are modifying them. So if you advance the ignition timing, change air fuel mixture etc., go for a different heat range.
tsk1979 is offline   (2) Thanks Reply With Quote
Which is better - A car which has driven 1 lac kms in 4 years or 35,000 in 6 years syravi Technical Stuff 41 7th May 2016 16:21
Suzuki Grand Vitara: 2,32,000 kms & 7 years ownership sudev Long-Term Ownership Reviews 412 24th December 2015 13:30
First Embera CRDi owership experience on Team-BHP EDIT: 2 years, 28,000 kms update rohitrk Long-Term Ownership Reviews 101 21st June 2013 23:01
First off-roading with Grand Vitara Samurai 4x4 Excursions 153 23rd March 2010 19:13
Wheel rotation in Grand Vitara at 5000 kms GRV Technical Stuff 5 27th January 2008 09:51
