Old 26th June 2017, 08:49   #991
Thanked: 719 Times
Default Re: The First Grand Vitara on Team-BHP [113000 KMs & 9 Years]
Originally Posted by Styler View Post
Hi Sridhar
PrateekSwarup another Vitara owner in Gurgaon installed the Swift Desire 2016 door stoppers on his rear doors. He tells me these fitted perfectly and he did not feel any difference in opening. He's happy having saved a lot of money.
Styler
OK. Thanks for the info.
That makes sense as the rear door geometry, in terms of arc length of the door outermost point for given angle of movement, is different from the front.
So all Grand Vitara Owners can at least save money on the rear door stoppers.
sridhar-v is offline   (1) Thanks Reply With Quote
Old 11th July 2017, 09:20   #992
Styler's Avatar
Thanked: 189 Times
Hi all
The last thing to be done on my Grand Vitara 2.0 2007 is a Power Steering Rack fix. As a lot of people here have discussed that Power Steering Rack leak is a regular problem. The replacement of the complete Rack Assembly is possible but it costs over Rs 40,000. The Power Steering in my Grand Vitara is holding fine for now, but it is leaking a little oil. I do not see any oil dropped to the ground when parked but when check periodically every month Power Steering oil needs to be topped up, and I see some oil on the Rack on visual inspection. I know eventually I would like to have a complete and permanent fix to this problem. My mechanics told me that the Power Steering Rack can be overhauled if we can get a good quality seal kit.
After a lot of searching, I managed to find a Power Steering Rack and Pinion Overhaul Kit for the Grand Vitara 2006-2012.
http://www.bestpartsonline.com/power...0Vitara%202007
It costed $35 with free shipping in US (Around Rs 2,000). They also have paid international shipping.
Manufacturer (Kotek) Site
http://www.powersteeringkits.net/
I have ordered it in the US and somebody traveling to India on the 14th July will be getting it. I will post how it goes when I get it and we get the power steering rack overhauled. I just wanted to post the links here for future reference as I found it after a lot of searching. Somebody in Suzuki Forums had done an overhaul with this kit and was quite happy with the results. He pointed me to this link.
My mechanics will open the system, but we want to get the Power Steering Rack Overhauled from a workshop specializing in Power Steering Overhauls. If anybody has some contact info of a workshop which specializes in Power Steering Systems Overhaul in Delhi-NCR, it will be a great help.
I hope this will be of use to others.
Styler
Styler is offline   (3) Thanks Reply With Quote
Old 24th July 2017, 16:32   #993
Thanked: 13 Times
I need help for sourcing the weather strips for windows. The horizontal strip that scrapes against the window glass as it slides up/Down also prevents water getting straight into the doors. Tried but couldn't explain it to MGP dealer as well.
Photographs are here.
http://www.team-bhp.com/forum/techni...ml#post4237937 (Maruti Genuine Parts (MGP) Catalog: Post your queries here (model list on Pg 1))
spgv is offline   Reply With Quote
Old 24th July 2017, 17:37   #994
Styler's Avatar
Thanked: 189 Times
I have replied in the MGP Parts thread.
It is just one Horizontol strip on the lower length of each window.
The inner and outer is one thing, the inner rubber breaks away.
I told my MGP dealer for the rear right weather strip, he ordered and I got it in a long cylindrical box.
The part no for the Rear Right Weather strip was 83831-65J00 WeatherStrip, RR Door Out RH
Cost was around 973 for 1 window strip.
Styler is offline   Reply With Quote
Old 25th July 2017, 15:08   #995
Thanked: 177 Times
Infractions: 0/1 (5)
Guys ,
Does anyone has an idea about the OE woofer in the vitara , the woofer cone on mine is shot , and I ave tried getting it repaired without any luck .
The alternate is to order a new one (complete amp ) - which costs 6200 in the parts catalogue , the woofer itself is not listed as a child part.
wbd8779 is offline   Reply With Quote
Old 26th July 2017, 14:37   #996
Thanked: 719 Times
Originally Posted by wbd8779 View Post
Guys ,
The speakers themselves are impregnated paper cone type and have "made in china" markings. If you have not been able to get the woofer repaired then it is best to order the complete unit. 6200 is extremly reasonable as all active subwoofers cost much more.
sridhar-v is offline   Reply With Quote
Old 4th August 2017, 15:08   #997
wanderernomad's Avatar
Thanked: 773 Times
Guys how much would, the 4 shockers and the coil cost for the GV, thanks.
wanderernomad is offline   Reply With Quote
Old 4th August 2017, 15:33   #998
Thanked: 177 Times
Front is a version of the Mc pherson strut - Set will cost 18-22k
Rear shockers are 4k each (SGP ) cant say if its gone up in the past few month
Cheaper options are available online , i ordered a complete set , got it delivered to my hotel in europe and carried it back in luggage , landed cost india 12k for the complete set . You have to be lucky at customs for this !
wbd8779 is offline   (1) Thanks Reply With Quote
Old 4th August 2017, 16:39   #999
Thanked: 773 Times
Am thinking of picking up a 2007 2.0 ltr version which has approximately run about 1.75K kms. the price would be around 2.75. Does it make sense? It wont be a daily driver but need something for that occasional Leh and Spiti trips.
Old 4th August 2017, 17:50   #1000
Reinhard's Avatar
Thanked: 981 Times
Presuming you mean 1,75,000 kms, while 2.75L seems a tempting deal as its cheaper than even A segment hatchbacks, a 10 year old discontinued car with that significant amount of running somehow makes me imagine plenty maintenance charges...It will be a bit of a gamble I feel. While the money is not "that much" - if it is a lemon, the peace of mind that you lose will feel like a lot of cost...
Reinhard is offline   Reply With Quote
Old 5th August 2017, 09:16   #1001
sudev's Avatar
Thanked: 1,988 Times
If you are getting it at 2~2.25 its a deal. Despite ten years. Though odo is a tad on higher side. Do check service history.
sudev is online now   Reply With Quote
Old 5th August 2017, 10:40   #1002
Samurai's Avatar
Thanked: 13,734 Times
Originally Posted by Reinhard View Post
10 year old discontinued car with that significant amount of running somehow makes me imagine plenty maintenance charges...- if it is a lemon, the peace of mind that you lose will feel like a lot of cost...
The production stopped only 3 years ago, the parts will be available for another few years at least. A lemon would not have been driven until 175K kms I think.
These days you can't get full service history unless the owner gets it for you. Unfortunately, Maruti will even turn back the odometer for you upon request. Such an owner will not part with the full service history.
Any buyer should demand full service history from the owner to ensure no odo reversal has been done.
Old 5th August 2017, 12:34   #1003
Thanked: 13 Times
2.75 is definitely overpriced. Keep in mind if the seller approaches a dealer for this car he would get a quote downwards of 2. I think you have a leverage to bargain.
Old 7th August 2017, 12:46   #1004
Reinhard's Avatar
Thanked: 981 Times
I meant lemon "now"; should have been clearer sorry. After the 175k kms. Basically if the reason for selling is because the car is now proving to be a white elephant to maintain.
While the parts may still be available - its a Unicorn. Very very rare car. So the parts are bound to be at a premium with on-demand sourcing etc.
Old 7th August 2017, 14:13   #1005
Tanmay K's Avatar
Thanked: 154 Times
All depends on your Maruti service center. When I bought mine I was fortunate enough to have the option of looking at every single job card created for the vehicle in 9 years, including the amount the previous owner had spent each time. This was when I had taken the owner's permission to drive the vehicle to a MASS for a check up (his son accompanied me). If you take the vehicle with you, I'm sure MASS guys will be happy to show you the previous history.
I would like to add that 175k kms aren't that much for a well-maintained Vitara. If the timestamps and the odo readings of the services make sense to you, you can be reasonably sure that the servicing was done on time. Just make sure you know what expenses are coming up ahead. Some parts are reasonably priced, some parts not so much. I get everything at MGP and the prices are fixed.
Tanmay K is offline   (1) Thanks Reply With Quote
Which is better - A car which has driven 1 lac kms in 4 years or 35,000 in 6 years syravi Technical Stuff 41 7th May 2016 16:21
Suzuki Grand Vitara: 2,32,000 kms & 7 years ownership sudev Long-Term Ownership Reviews 412 24th December 2015 13:30
First Embera CRDi owership experience on Team-BHP EDIT: 2 years, 28,000 kms update rohitrk Long-Term Ownership Reviews 101 21st June 2013 23:01
First off-roading with Grand Vitara Samurai 4x4 Excursions 153 23rd March 2010 19:13
Wheel rotation in Grand Vitara at 5000 kms GRV Technical Stuff 5 27th January 2008 09:51
