Old 7th August 2017, 19:04   #1006
R_R
Thanked: 20 Times
Default Re: The First Grand Vitara on Team-BHP [113000 KMs & 9 Years]
The problem with the Grand Vitara is not so much the cost of spare parts, but that Maruti ASS do not stock many parts (understandably) though they are available on order. For example, I recently had a clutch problem on my 2008 GV, and two different Maruti workshops told me they have to order all components of the clutch, including the flywheel, beforehand, before opening the clutch up. I refused, since I was doubtful the flywheel was worn and just ordered the clutch disc and pressure plate and crossed my fingers. When we opened the clutch up, the flywheel was fine. But the problem was, if I had needed the flywheel, I would have been in trouble, obviously. (I'll post pictures soon).
R_R is offline   Reply With Quote
Old 9th August 2017, 17:13   #1007
R_R
Thanked: 20 Times
A question for any of the GV gurus here: what is the safe top speed in a GV when driving in 4H Lock and 4L? And what is the highest gears you can be in when driving in 4H Lock and 4L? Any such limits?
Old 9th August 2017, 17:47   #1008
Samurai's Avatar
Thanked: 13,734 Times
The lock mode and top speed should not be discussed in the same sentence. If you are thinking about driving fast, you better not be doing that in terrains that require diff locking. It is not safe.
Beach is the only place where I have driven fast with locks on. But even empty beaches can have hidden surprises. So you can never really drive fast safely with locks on.
Samurai is offline   (1) Thanks Reply With Quote
Old 9th August 2017, 17:50   #1009
theMAG's Avatar
Thanked: 1,427 Times
Did the GVs sold in India ever come with the V6 option? Almost all surviving GVs I've observed here seem to have a V6 - which would make such a light car incredibly vicious !
Old 9th August 2017, 17:57   #1010
Samurai's Avatar
The previous generation (1998–2005) of Grand Vitara, also known as Vitara XL-7 did have V6 in India.
Old 9th August 2017, 18:00   #1011
R_R
Thanked: 20 Times
Oh, I may have given the wrong impression. I absolutely do not plan to do that, no speed-demon me . I was just asking because I do not want by mistake to drive too fast or in too high a gear when 4H lock or 4L. I am primarily concerned about what is safe for the car mechanically. Can I assume that 40-50 kms/hr in 4th gear is OK in 4H Lock and, say 30 kms/hr in 3rd gear is OK in 4L? Thanks.
Old 9th August 2017, 18:21   #1012
Samurai's Avatar
What kind of terrain? Tar, slush, sand, snow, gravel... That information is necessary.
Old 9th August 2017, 18:27   #1013
R_R
Thanked: 20 Times
Rough tracks, broken roads, water-crossings, maybe a bit of snow. Planning a Gurgaon-Leh-Manali-Gurgaon trip. Thanks.
Old 9th August 2017, 18:47   #1014
Thanked: 719 Times
Wait for the experts to give a definitive opinion.
Based on my limited experience with off-roading & bad-roading I would say that :-
1. 4LL is good for crawling over rock obstacles and steep slippery slopes.(or crossing water bodies - which I did). I guess 10-20 kmph may be the maximum safe speed. The engine heats up a lot in 4LL though.
2. 4HL is a sort of insurance for trails where you expect to loose traction. Should be good for snow, though I have no experience.
I have done a few longish stretches of deep mud & slush. 4H was more than adequate, though the vehicle did slide around a lot.
For standard unprepared trails with small rocks and loose soil I have found 4H to be more than enough. That should also apply to majority of the roads in Leh.
In almost all situations I drive in either 4H or directly go for 4LL.
Go for good AT tyres. They play a major role in traction. Continental CrossContact AT is the choice of the Himalyan Rally chaps.
sridhar-v is offline   (1) Thanks Reply With Quote
Old 9th August 2017, 19:06   #1015
R_R
Thanked: 20 Times
Thanks. Much appreciated. When you say 10-20 kms/hr on 4LL, that's on 2nd gear, correct? Or do you have to stay on 1st gear? I don't do any hardcore off-roading, so these rather basic questions. Did do Spiti road a couple of years back (Shimla-Narkanda-Kaza-Losar-Manali), but that's about the hardest I've done. And hardly had any use 4HL or 4LL there. I am on MRF Wanderer ATs, upsized to 235/70/R-16, with slightly over 20K kms on it. Looks good still. Again, thanks.
R_R is offline   (1) Thanks Reply With Quote
Old 9th August 2017, 19:27   #1016
Samurai's Avatar
For rough tracks and broken roads (good traction), you can stay in 4H-Unlocked. Only for water crossing and snow, you can switch to 4L-locked. Only if you have slushy roads, you may need 4H-locked.
Old 9th August 2017, 19:27   #1017
wanderernomad's Avatar
Thanked: 773 Times
While on sand and slush you need higher momentum and therefore 2 gear is preferred, while on loose gravel and small rocky path slow and steady is the key so you would be in 1 to ensure a more stable movement.
wanderernomad is offline   (1) Thanks Reply With Quote
Old 9th August 2017, 19:52   #1018
R_R
Thanked: 20 Times
Thanks for all the advice. Very useful.
Old 10th August 2017, 08:55   #1019
Thanked: 719 Times
I have an AT gearbox. This has 2 advantages:-
i) The torque convertor acts as a torque multiplier in addition to the step up of the low range.
ii) The engine does not stall as a suitable gear is automatically selected. My guess is that the gearbox keeps it in 1st. or 2nd. depending on the speed. But I can tell you that the torque is humungous.
4H should cover most of the situations. Go directly to 4LL in tricky patches and slow down suitably.
Service the transfer case selector mechanism, as lack of frequent usage sort of jams it in 4H position. A sticky lever action can create trouble in the field. A shot of WD40 will do the trick. Access to the mechanism is poor so it may be best to get it done by MASS.
Do post a travelogue. All the best.
Old 10th August 2017, 14:10   #1020
sudev's Avatar
Thanked: 1,988 Times
Going to Leh? Unless you plan to off-road in Nubra sands you would not even need 4HL.
Oh you would need 4LL if you plan to take shortcuts at Gata loops or Tanglanla
sudev is online now   (1) Thanks Reply With Quote
Which is better - A car which has driven 1 lac kms in 4 years or 35,000 in 6 years syravi Technical Stuff 41 7th May 2016 16:21
Suzuki Grand Vitara: 2,32,000 kms & 7 years ownership sudev Long-Term Ownership Reviews 412 24th December 2015 13:30
First Embera CRDi owership experience on Team-BHP EDIT: 2 years, 28,000 kms update rohitrk Long-Term Ownership Reviews 101 21st June 2013 23:01
First off-roading with Grand Vitara Samurai 4x4 Excursions 153 23rd March 2010 19:13
Wheel rotation in Grand Vitara at 5000 kms GRV Technical Stuff 5 27th January 2008 09:51
