Old 6th August 2013, 08:05   #541
sudev's Avatar
Thanked: 1,991 Times
Default re: The First Grand Vitara Ownership on Team-BHP [6 years & 70,000 completed]
Now take the beast where it is in its elements and then it will shine like no sedan can ever do.
sudev is offline   Reply With Quote
Old 6th August 2013, 11:49   #542
sudev's Avatar
Driven at steady & sedate 90kmph this is what I got from Chandigarh to Delhi. Though many times on highly spirited driving I have returned half of this figure too.
sudev is offline   (3) Thanks Reply With Quote
Old 6th August 2013, 11:59   #543
aditbelw's Avatar
Thanked: 40 Times
Thanks you Sudev jee, I am sure my perceptive will change once the this metal meets it's elements. Hoping for an opportunity to take it off the road!
Attachment 1122231
That's eye candy figure! I am not able to get above 10 Kmpl even after sedate to hilt driving, and the worst I have achieved after ripping it is 9.1 KMPL.
aditbelw is offline   Reply With Quote
Old 8th August 2013, 21:08   #544
sudev's Avatar
By trial and error I have found that on long distance keeping a very light foot and RPM's always within 2200~2700 band you can achieve the best figures.
CNG!! Why do you want to do that???
Old 9th August 2013, 19:54   #545
Driving in Bombay I get less than 7 to a litre. And with petrol prices going through the roof everyday, I figured a sequential CNG kit is in order for city driving.
DrGonzo is offline   Reply With Quote
Old 6th September 2013, 16:12   #546
GRV
Ah, I should have updated the thread on 12th. Anyway, this time the car was delivered to my office since I was in a meeting. So I couldn't check it out until late night.
They finally nailed the problem. It was not the ECM, that much they confirmed after checking every wire and via scanner. So they did a throttle body cleaning, apparently there was a lot of gunk in there. I guess this is the first time it was ever cleaned.
Now it feels like new, even my wife noticed. All the sluggishness at low speeds have vanished. Earlier it was losing rpms fast at low speeds. Now it maintains the idle speed well when I come to a halt or drop speed fast. Feels very good driving it around.
Got the AC filter cleaned again, AC too feels better. I think we all GV owners should tell the service guys to clean it at every service.
Asked them to check the lower arm bushes again, it has been almost 10K since the last check where the cracks were discovered. The left lower arm bush is now properly cracked, while the crack in the right one is still manageable. The SA showed it to the DGM and he suggested to replace it. So I have put an order for a new lower left arm.
Got the disc brakes cleaned to since pitting was discovered few months back. The brake was also slipping for half second at emergency braking. Got the discs sand papered, disc pads lathed.
Basically I got them to do the 40,000 Kms service although I am 5K short of it.
Hi Samurai
Today I took by Vitara for that Dug dug sound from front. my car has done now 61,000 kms over 6 years. They told me that Suspension bush is completely gone and hence I need to change both lower arm (as it comes only with lower arm). Can you please reconfirm this ??
DId you change lower arm because lower arm was cracked or you change because you wanted to change bush and bush means lower arm also ?
GRV
GRV is offline   Reply With Quote
Old 6th September 2013, 16:16   #547
Samurai's Avatar
Thanked: 13,976 Times
Yeah, I replaced the lower arm because of the cracked bush. There was nothing wrong with the lower arm itself. However, Sudev says the bush can be changed on the lower arm. Check that option.
Old 9th September 2013, 18:03   #548
GRV
Hi Sudev
Could you throw some light here. You mentioned once that now bush comes as stand alone part, but the dealer workshop denies this.
GRV
Old 9th September 2013, 19:18   #549
sudev's Avatar
I will check with Motorcraft and revert. Though in my case this information was passed to me after I had already changed the arms!
Old 11th September 2013, 20:37   #550
GRV
Hi Sudev
Thanks a lot. Waiting for your revert.
GRV
Old 14th September 2013, 16:15   #551
R_R
Thanked: 20 Times
That's a great performance. Was this after you reached home in Noida because that would be even more impressive because you would have gone through the city.
Over the last five months or so, I have noted (tank to tank) anywhere between 9.5 to 11.5 kmpl in city driving for each fill. But oddly, I don't find a huge difference in highway driving, usually only slightly better, about 12 kmpl. Obviously, traffic is the biggest menace. Those driving in mostly heavy traffic should expect much worse figures. My city driving is also Gurgaon to South Delhi, and many times not in rush hour, which explains my better kmpl figures.
R_R
R_R is offline   Reply With Quote
Old 17th September 2013, 08:29   #552
sudev's Avatar
@GRV : Not able to get any confirmation on part number....so I guess you would have to buy the whole.
Old 17th September 2013, 10:31   #553
Thanked: 936 Times
I think it's possible to order the bushes (the service guys don't want to because it'a pain to replace the bushes). For my Tucson, the service adviser told me that that they have to burn and hammer the old ones out and the lower arm bushes are small in size so it takes time.
Here is my case:
http://www.team-bhp.com/forum/long-t...ml#post3133242
Look at the bush and you clearly see a separate part number:
Though I ended up replacing the entire lower arms (~Rs.9000 each), I asked the SA about the sub-frame as the sub-frame bushes will also eventually come up for replacement and replacing entire sub-frame will be stupid (it costs ~Rs.28,000). So the SA said, sub-frame bushes are always replaced because they are bigger so easier to work on + the sub-frame cost is prohibitive.
anandpadhye is offline   Reply With Quote
Old 30th October 2013, 21:45   #554
patil's Avatar
Thanked: 55 Times
Hi Guys,
The rear parcel tray in my grand vitara makes a lot of noise on bad roads and I think the clips have worn out and the parcel tray keeps rattling and makes noise. Can anyone suggest me a good solution for this problem.
patil is online now   Reply With Quote
Old 12th November 2013, 17:53   #555
Samurai's Avatar
Default re: The First Grand Vitara Ownership on Team-BHP [6 years & 75,000 completed]
Last week my Grand Vitara completed 6 years and 70,000kms. What a ride it has been...
This is the most uneventful vehicle I have owned. I can do 400kms trips routinely over and over without checking anything other than tyre pressure and fuel tank. I drive it to Bangalore and park it. Then I don't touch it for two weeks. Then I hop on it and drive it back, like I am driving to office. Been doing this for more than 3 years now. And I do these trips over one of the most horrible road called Shiradi ghats, at least 25 times a year.
Last month I gave the GV for service and I didn't have any problem to report. The SA is hard pressed to find anything extra to do. Check out the service bill, most of it is just engine oil and gear oil.
The First Grand Vitara on Team-BHP-fullscreen-capture-11122013-53827-pm.bmp.jpg
The First Grand Vitara on Team-BHP-fullscreen-capture-11122013-53847-pm.bmp.jpg
Samurai is offline   (3) Thanks Reply With Quote
First off-roading with Grand Vitara Samurai 4x4 Excursions 153 23rd March 2010 19:13
New Grand Vitara Coming soon.. (2007 model) sajo The Indian Car Scene 30 16th December 2008 17:00
Grand Vitara ..how good is it? sunith SUVs, MUVs & 4x4s 12 24th April 2006 10:50
New Suzuki Grand Vitara in US sumitsingh The International Automotive Scene 2 22nd September 2005 09:24
