Old 1st July 2016, 12:36   #841
Thanked: 16 Times
Originally Posted by KaandBaaz View Post
I know this question is a bit stupid on the forum but would plonking a CNG sequential kit be advised for daily usage. My daily commute is on 55kms, one way being at the time of peak traffic. And the last question GV 2.0 MT "kitna deti hain" on petrol.
Was in similar situation a few weeks back. Finally bought a GV 2008 this june with 1.06 lac Km on the ODO. i am the 3rd owner and the car has complete service history with MASS. Negotiated from 3.5lac point to 3.2.
IMO if the car is in good condition you could have quoted 3.75 to a individual(real good condition car with genuine 85K and service records) and 3.5 Lac to a dealer.
Goodluck with your hunt
spgv is offline   Reply With Quote
Old 1st July 2016, 17:36   #842
KaandBaaz's Avatar
Thanked: 55 Times
Default re: The First Grand Vitara on Team-BHP [113000 KMs & 9 Years]
Firstly congrats on your pre-loved Grand Vitara. Do post the pictures of the car. Is it the 2.0 or 2.4? Also M/T or A/T.
And now for my case, I have put the thought of buying a GV on hold. For now have picked up a 2008 Civic M/T wit 81k on ODO.
KaandBaaz is offline   Reply With Quote
Old 2nd July 2016, 12:10   #843
Thanked: 16 Times
Thanks KaandBaaz. Mine is 2.0 MT.
I need help regarding service.
Recently took my GV to MASS vashi. No one touched her for one our saying that only some senior person would assist me with the GV. The senior person though seemed to know but never worked on a GV before. Lots of disappointing things done to my car by their mechanics and i have a very sad vibe about these guys.
Can anyone please suggest reliable workshop/mechanic in Navimumbai for the GV.
Old 2nd July 2016, 18:07   #844
Samurai's Avatar
Thanked: 13,984 Times
One doesn't need any special training on GV to service it. Any competent Suzuki/Maruti mechanic can find his way around it. You think Udupi Maruti service center has GV specialists? Their owner has a GV, so they figured it out themselves.
Samurai is offline   (1) Thanks Reply With Quote
Old 4th July 2016, 02:15   #845
Hi Guys,
I've had a strange problem come up in my GV. The car revs but does not accelerate. It revs up to 2000 rpm but when I depress the accelerator pedal it does not accelerate. I've been doing some reading online and all reviews point me towards a slipping clutch/ transmission issue. I called my mechanic and he seemed a little confused when I explained the problem to him. There was a clanging noise and a stutter that I used to get earlier when I was on low revs. Any help would be appreciated. Thanks in advance.
DrGonzo is offline   Reply With Quote
Old 4th July 2016, 07:58   #846
sudev's Avatar
Thanked: 1,993 Times
Slipping clutch will not limit revs. Rather the engine will rev but car will not move or move proportionally slower.
Likely causes : ECM reset, clean throttle body, clean wiring connections, check in ignition coils and lastly check fuel filter.
Cleaning filter is long job and involves putting vehicle on lift, removing prop shaft, removing tank and then the fuel pump + filter assembly. The wire mesh filter at bottom of assembly gets choked and needs cleaning. Though dealer normally would say replace entire assembly.
Do not get into a funk. The first cause, ECM reset, is most likely to solve the problem.
sudev is offline   (1) Thanks Reply With Quote
Old 4th July 2016, 08:35   #847
Samurai's Avatar
Reminds me of a problem I had in Baleno long ago. It turned out to be a broken crankshaft bolt.
Old 5th July 2016, 10:14   #848
Thanked: 723 Times
We have started our wanderings in the monsoon rains. I will create a separate thread for that.
But just had to post this one picture here
sridhar-v is offline   (5) Thanks Reply With Quote
Old 5th July 2016, 13:23   #849
Ace F355's Avatar
Thanked: 1,555 Times
Lovely pic! Waiting for more to come!
Ace F355 is offline   Reply With Quote
Old 6th July 2016, 09:32   #850
Thanked: 723 Times
Welcome to the club. Do share your initial experiences.
Will be doing it soon.
sridhar-v is offline   Reply With Quote
Old 7th July 2016, 00:56   #851
I think I'm going to rechristen you doc! Took my car to Vitesse in Andheri and left it with the guys overnight to check for solutions. They did an ecm reset and the car was running in super shape by the time I got to the dealership today. They also did a fuel injector cleaning and for a bill of Rs. 1700, Eleysium was running and back in business, munching the Bombay potholes just like it should be.
Thanks again Sudev!
Though I have another nagging issue that I'd forgotten about that just cropped up. I got my tires aligned and rotated a couple of months back and had also got my brake pads changed the week before that. After that, every time I'd turn the car right, it made a strange scraping sound. I took it back to the alignment guy and we checked but couldn't find a solution. Surprisingly as it started, the same way it disappeared and I forgot about it. But today it resurfaced again. Any clue what it might be. It's a strange scraping sound, that's the best I can describe it.
Thanks in advance!
Old 7th July 2016, 03:49   #852
sudev's Avatar
Good that ECM reset solved the problem. But this could have been done by you simply by removing the ground terminal of battery for couple of minutes and then putting it back on!
sudev is offline   Reply With Quote
Old 7th July 2016, 11:37   #853
When the engine management light came on, I took it to the service center. The filter clean wasn't directly a part of solving this problem but it rectified a low gear stuttering problem. My car hasn't driven like this in a while now. Vitesse Andheri definitely gets a thumbs up in terms of service and knowledge.
Old 7th July 2016, 16:23   #854
vigsom's Avatar
Thanked: 565 Times
Originally Posted by DrGonzo View Post
every time I'd turn the car right, it made a strange scraping sound!
A few checkpoints :
1.What is the tyre size you're running the GV on?
2.Are the wheel well fender flaps properly fitted?
3.Is the left front strut weak? Is the vehicle sagging to the left.
4.Is there something stuck to the tread of the front tyres?Some tape or something similar?
5.The GV doesn't come with mudflaps.Have you fitted mudflaps?If yes , is the one on the right side a little loose?
Maybe some photographs of the wheel well(on the inside of the wheels) might help diagnose the issue.
Old 8th July 2016, 21:32   #855
Thanked: 723 Times
My engine bay is a mess. My MASS does not wash the engine during servicing. Sometime in the past, before it came into my hands, the whole engine bay was treated with lacquer. That coating has started cracking, particularly on the wires and hoses. As a result of all this the bay is a mixture of dust, oil stains and grease and other smudges. My local car detailer has offered to pressure wash the bay whilst covering up the ECU with protective plastic sheet. Is it advisable? Or is there any better method?
First off-roading with Grand Vitara Samurai 4x4 Excursions 153 23rd March 2010 19:13
New Grand Vitara Coming soon.. (2007 model) sajo The Indian Car Scene 30 16th December 2008 17:00
Grand Vitara ..how good is it? sunith SUVs, MUVs & 4x4s 12 24th April 2006 10:50
New Suzuki Grand Vitara in US sumitsingh The International Automotive Scene 2 22nd September 2005 09:24
