Old 31st January 2008, 10:05   #151
suman's Avatar
Thanked: 257 Times
Originally Posted by m3_07 View Post
guage. Also, can anyone tell me when it goes ON, how much of fuel would be left in the tank??
The red light is supposed to come on when you have 10 litres left in the tank. In real life, you would have more because there would be some in the fuel lines etc (and this beast has a long fuel line...)
Old 31st January 2008, 10:42   #152
Thanked: 245 Times
because they have only given IS1460 or equivalent as recommended fuel (which is met by all indian oil companies, didnt check shell), they have not mentioned if the engine will perform better with Normal diesel(HSD) or diesel with added additives.
Fail to understand that the fuel usage is causing so much confusion. I read in the manual & it clearly mentions "high speed diesel". Does "shell's extra diesel" qualify uder this pls???
As suman mentioned, its 10 ltrs but I remember when I went for a fill earlier on, when the needle was in the middle of the red bar, only 5 ltrs were left and the attended was telling me thats its completely empty, he filled 60ltrs.
Also, can anyone tell me as to at what point does the "low fuel LED" go ON??? I saw that it went ON, even a little before the red patch on the guage. Also, can anyone tell me when it goes ON, how much of fuel would be left in the tank??
Old 31st January 2008, 11:29   #153
Thanked: 1,642 Times
Why are we so worried about .5 kmpl / 1 kmpl differences in mileage? This is a 2 ton vehicle you're driving, not a tiny econo-hatch.
Steeroid is offline   Reply With Quote
Old 31st January 2008, 12:22   #154
Thanked: 245 Times
Personally speaking the mileage is only for the sake of statistics, I am more keen on seeing if the engine behaves better(NVH) with the normal diesel or not.
Old 31st January 2008, 12:32   #155
SUV
SUV's Avatar
Trust me it will behave much better...... After having driven a 60k KM 2.2 all i can say is the engine ages pretty well. You need to put in more miles for the NVH to get lower on a diesel.
PS: One word of advise though, Refrain from switching between regular and additive fuels often.
SUV is offline   Reply With Quote
Old 31st January 2008, 12:34   #156
akash_m's Avatar
Thanked: 88 Times
Being strictly OT, can anyone suggest where is the thread for posting Accident pics? Want to post some snaps I saw today morning!
Thnx
akash_m is offline   Reply With Quote
Old 31st January 2008, 12:36   #157
Thanked: 83 Times
Did you say and mean 60,000 kms 2.2 or was it a mistake? If it was for real, who managed to drive it man? 60000 in 4 months must have been an achievement!
SumitB is offline   Reply With Quote
Old 31st January 2008, 13:01   #158
suman's Avatar
Thanked: 257 Times
Sumit, SUV has extensively driven the 2.2 engined Safari when it was in the testing stages, way before it was officially launched.
That's what he's referring to if I'm not mistaken.
cheers:
Thnx
Here you go -
http://www.team-bhp.com/forum/shifti...ndia-pics.html
Old 31st January 2008, 13:14   #159
simply_sunny001's Avatar
Thanked: 15 Times
TATA also recommends Normal Diesel and System D for best results.
and trust me on my 3.0 dicor,i tried normal/hi-speed etc etc.
but normal diesel+System D yields best results.beast is so calm and responsive with it and no black smoke which everyone hates.
i have been using it since last 10k kms.
and 2.2 should not be an exception.and as SUV mentioned switching between different kind of fuels is very bad.
simply_sunny001 is offline   Reply With Quote
Old 31st January 2008, 14:40   #160
I am not sure if this is the right thread to post. But, please help me.
We've many Indian Oil Companies that sell Diesel. Which one is the best for Normal Diesel - HP, BP, IOC, IBP etc... for Safari?
I've searched the forum a lot but couldn't find exact information.
Thanks in advance
suncity is offline   Reply With Quote
Old 31st January 2008, 15:39   #161
Thanked: 130 Times
Hi Simply_Sunny
How much of System D should be added to one litre of normal diesel ?
power ranger is offline   Reply With Quote
Old 31st January 2008, 15:51   #162
Thanked: 15 Times
Originally Posted by power ranger View Post
Hi Simply_Sunny
i add 1 ml per litre of System D to Normal Diesel.there is a measuring kind of thing on top of System D bottle which fills 10 ML if full.
Old 31st January 2008, 16:13   #163
m3_07's Avatar
Thanked: 200 Times
dumb question - is system D sold in the petrol bunks & how much does it cost?
m3_07 is offline   Reply With Quote
Old 31st January 2008, 16:23   #164
Thanked: 245 Times
You can but it from any TATA service center.
Adding system D to the normal diesel makes it diesel with additive but System D might be using a different formula than the local oil companies (they also buy the additive from foreign companies and mix it).
System D is tested by TATA's and engines tuned accordingly, therefore they recommend it and the engine also performs.
Old 31st January 2008, 16:31   #165
Thanked: 15 Times
it costs 192 Rs/250 ml bottle if i'm precise.and TATA sells the one from company called "Iftex" and same product is also available at BP outlets(the yellow ones).
you can buy it from both places either from petrol bunk or from TASS.
Main advantage of adding System D i found is :- it reduces black smoke if regularly used and beast also behaves better
My new Tata Safari GX - Cycus Grey + Artic Silver umang dutt Test-Drives & Initial Ownership Reports 124 14th May 2010 22:19
New Tata Safari 2.2 VTT EX 4X2 EDIT 25000kms service done harjeev Test-Drives & Initial Ownership Reports 324 27th November 2009 09:18
Finally my Bull comes home. A TATA Safari 2.2 VTT Ex 4X2 Pearl White blackbeast Test-Drives & Initial Ownership Reports 31 15th September 2009 02:16
New Tata Safari 2.2 VTT 4X2 EX Artic Silver HULK JUDA Test-Drives & Initial Ownership Reports 86 12th June 2009 19:11
Safari 3.0 dicor or 2.2 VTT dicor ? tabrez02 SUVs, MUVs & 4x4s 49 30th December 2008 12:56
