Old 25th March 2008, 14:01   #241
suman's Avatar
Thanked: 257 Times
Originally Posted by smsrini View Post
In the safari, the idling speed is around 1000rpm, even at standstill.
Its around 700 rpm actually.
Old 25th March 2008, 14:03   #242
tsk1979's Avatar
Thanked: 15,648 Times
You can't do this idle putter in a petrol, you need a diesel with low end grunt.
Most jeeps can putter around in 4th gear at idle.
Even the indica can putter at idle in second gear, and the DICOR should be able to putter at idle even in third gear.
Old 25th March 2008, 14:19   #243
tsk1979, it should be possible in all MPFI cars. I have done this many times in my Indica LSi. Without using the accelerator on a level road, I have gone up to 5th gear. The rpm does drop when you shift up (no tacho in my car but I can feel the slight jerk and hesitation) but the ECU compensates almost immediately. If the clutch is released slowly enough, even these jerks can be avoided.
hrag is offline   Reply With Quote
Old 25th March 2008, 17:36   #244
Thanked: 64 Times
. I have done upto 4th in wagon R ( petrol), Indica ( diesel)as well as Verna( diesel) - in Verna in fact , sometimes, I dont touch accelerator till I am in 5th gear, except for a brief second while shifting gears.
shatrughna is offline   Reply With Quote
Old 25th March 2008, 18:14   #245
the idea is to blip the throttle before upshifting, the vehicle will take it on thereafter. but again this is for diesels i am saying, do not have much idea on petrol engines how this would be.. diesel vehicle will not stall, that's for sure from my experience of 3 years doing this, only this time it is on a higher plane..
so no one has forbidden me from enjoying this crawl till now, that's good..
thanks suman, 4th is on the anvil now for me, lets see how that turns out, even if it does not pull on 4th no issues, 3rd gear speed is optimum to enjoy
the scenery and yeah, i sure wish there were an led sign somewhere to let the other road users know that they are to overtake and leave me behind as they please, no point me holding up traffic and no signaling and horn required too, i am crawling.. hehe
aburagohain is offline   Reply With Quote
Old 25th March 2008, 18:19   #246
smsrini, i believe the idle on the safari should be about 750 or so as suman has pointed out.. try out on an open stretch.
if idle is high, consumption should go up in my opinion, need to hear other riders.
Old 26th March 2008, 09:19   #247
For a change pickup / top speed is not being discussed.
Crawling / puttering is really a boon atleast on diesel cars. I could do it even in my low-powered Sierra. It is a real boon especially in slow moving traffic.
kingshukt is offline   Reply With Quote
Old 26th March 2008, 19:00   #248
@kingskut
looks like you are enjoying all the good things.. safari as well as the sierra. yes, sometimes one feels like taking a break from the fast life, for those times these are the vehicles to hop into and take off, albeit slowly..
Old 27th March 2008, 16:15   #249
jkdas's Avatar
Thanked: 1,389 Times
750 for 3L or 2.2L ?
Old 27th March 2008, 16:17   #250
suman's Avatar
Thanked: 257 Times
Can confirm it is around 750 for the 3.0 - in fact, 760 to be precise IIRC (on one occasion had the diagnostics laptop plugged in)
Old 27th March 2008, 16:38   #251
@jkd
mine is a 2.2, haven't measured too meticulously, the 750 figure is a rough reading looking at the needle. it is at 3 quarters, would not be surprised if actual reading shows 800 rpm too.
Old 27th March 2008, 16:59   #252
jkdas's Avatar
Thanks Suman.
@jkd
Think its 800 or 800plus for 2.2L. Will confirm by eve.
Old 27th March 2008, 19:48   #253
Thanked: 244 Times
Also note the small ratio print on the bottom right of the Tacho, thats the calibration, mine says '1:2.52'
Old 27th March 2008, 21:57   #254
hey, what was that dadu, are we running 2.5 times what is shown.. gotta check it out now that you have conveniently put the doubt in my mind..hehe
Old 27th March 2008, 22:40   #255
jkdas's Avatar
The same for me. At idle tacho was at 900rpm. Not sure how to calculate using the 1:2 thing as Dadu pointed out.
My new Tata Safari GX - Cycus Grey + Artic Silver umang dutt Test-Drives & Initial Ownership Reports 124 14th May 2010 22:19
New Tata Safari 2.2 VTT EX 4X2 EDIT 25000kms service done harjeev Test-Drives & Initial Ownership Reports 324 27th November 2009 09:18
Finally my Bull comes home. A TATA Safari 2.2 VTT Ex 4X2 Pearl White blackbeast Test-Drives & Initial Ownership Reports 31 15th September 2009 02:16
New Tata Safari 2.2 VTT 4X2 EX Artic Silver HULK JUDA Test-Drives & Initial Ownership Reports 86 12th June 2009 19:11
Safari 3.0 dicor or 2.2 VTT dicor ? tabrez02 SUVs, MUVs & 4x4s 49 30th December 2008 12:56
