Old 24th June 2008, 16:09   #376
JUDA's Avatar
Thanked: 7 Times
Default Top Speed 180Km/hr!
Had experienced this sometime back so thought of sharing this with you'll anyone else done this?
Anyways this was on a straight Pune-Bangalore highway early in the morning-5ish.
Accelerator was not flat out, this was at 3.8-4k RPM.
Full story later when I have time to type......
Back to work now.
Cheers!
J-U-D-A
JUDA is offline   Reply With Quote
Old 24th June 2008, 21:40   #377
Rahulk76's Avatar
Thanked: 204 Times
Back to work now.
Cheers!
J-U-D-A
Juda,
No offence....but Its ODO error . Seems like its badly caliberated.
2.2 max geared speed is 160kmph (as per manual if i remember correctly)
True speed definetly will be lesser.
Thnx
Rahul
Rahulk76 is offline   Reply With Quote
Old 28th June 2008, 16:29   #378
Thanked: 245 Times
Pre-Monsoon Checkup
Had gone for the pre-monsoon checkup today and wanted them to check the follwing, apart from their routine general checkup:
- Clutch adjustment
- handbrake tighten
- Windshield wiper water tank leakage
The Safari was given back to me by 1:00 PM with the following things done:
- General checkup done
- Battery cells acidity check done and topped.
- Clutch Adjusted
- Handbrake tightened
- Suspension bolts checked and tightened.
- Timing belt tension checked and tightened
- Windshield water tank found leaking : No spare, Spare ordered
- Vehicle washing and greasing done
Cost:FOC
Old 28th June 2008, 20:46   #379
jkdas's Avatar
Thanked: 1,436 Times
Originally Posted by dadu View Post
Pre-Monsoon Checkup
- Clutch adjustment
- handbrake tighten
- Battery cells acidity check done and topped. [Maintenance free right?]
- Clutch Adjusted
- Suspension bolts checked and tightened. [Why? ]
- Timing belt tension checked and tightened [ Why?]
Cost:FOC
What your odo reading? And what made you check these?
Old 29th June 2008, 12:09   #380
Thanked: 245 Times
ODO reads 5900 apprx.
Battery is maintenance free but if you read its manual, you still need to get it checked and thats what they check it for, it was done as part of their checkup, I didnt ask for it.
The only thing I usually will get checked is the clutch and brakes.
Clutch, as it needs more adjustments during its first year(due to wear & tear) and these keep it healthy, longer life.
Brakes, as they are your safety.
Although they checked the bolts themselves but for the first year, one should get them checked/tightened as they tend to loosen up.
Rest all was routine checkup.
Old 30th June 2008, 10:59   #381
Default Update on my problem
hi Guys,
Update on the problem I faced - reported on 16th June on this thread -
had the autocop checked, batteries , connections as suggested by Dadu, SUV.
The problem was that there were loose connections which had the battery draining out even while the vehicle was grounded. They corrected those and said that the leakage was so much, that even the dynamo could not charge the batteries. :-(
nyways, the manipal guys corrected that and charged up the batteries as well. had to shell out 750 bucks - 450 for the 24 hour helpline visit and the rest for charging up the battery. Got a wash complimentary :-)
Thanks for all with their suggestions.
vividisha is offline   Reply With Quote
Old 31st July 2008, 10:08   #382
Thanked: 245 Times
The water tank was replaced long time back under warranty but it was too small an update to mention here.
As TSK has confirmed that the Krrr sound is not present in his Safari, need to check with some other 2WD's as his is a 4WD, before concluding and then ask the A.S.S to correct the initial batches.
But the problem is that A.S.S wont understand it, till they are shown the difference. I will need some help from new owners of Safari here (If this is concluded).
Now thats its pointing towards the wastegate actuator, my Question is "how to resolve it ??"
Best thing to do is to collect all the information regarding the 2.2l's facing it and send it to TM in one correspondance, asking for a solution and rectification.
Old 31st July 2008, 10:16   #383
What was the problem with the water tank?
I found that the water in the tank evaporates quite fast if left out in the summer sun.
kingshukt is offline   Reply With Quote
Old 31st July 2008, 10:20   #384
Thanked: 245 Times
It started leaking from somewhere along the metal plate holder and the tank clamping. I knew since the water level receded till the clamp and stayed, within 3-4 days of top up.
Check on the body below, the water leaves a mark (if you have the windshield cleaning fluid added). It might be a case of hairline crack.
Old 31st July 2008, 10:30   #385
In my case the water level used to drop down to the minimum (in the summers) and yes, it used to leave a water mark on the body below (I use left over of shampoo as windshield cleaning additive).
I then found that the pipes which carry the water to the spray nozzles comes off - the shampoo make the water slippery, though it cleans the windshield well - so I put a clip on both the pipes.
Now there is no leakage but the water level drops
Old 31st July 2008, 13:47   #386
smsrini's Avatar
Thanked: 272 Times
I faced a problem of the windshield water draining out, if I operated the rear glass wash/wipe. Found that when i operated it, the pipe used to come off. got it fixed at the A.S.S, and havent faced any issues thereafter.
On the water level coming down, could it be due to the heat in the engine bay near the water tank ?
smsrini is offline   Reply With Quote
Old 31st July 2008, 13:53   #387
That seems to be only conclusion that i could draw. However it is poor designing by TM if correct.
Old 31st July 2008, 14:00   #388
JUDA's Avatar
Thanked: 7 Times
Originally Posted by Rahulk76 View Post
Juda,
Thnx
Rahul
Thanks Rahul but I checked this out with a Tata Motors expert who worked on 3Lit and also has supervised the 2.2 engine bought by Tatas. The engine has been capped to not go over 180Km/hr he said the engine do beyond 200Km without doubt only for the ECU programming.
Cmon Rahul buy the 2.2 I know you love the Safari.......
Old 31st July 2008, 14:58   #389
smsrini's Avatar
Thanked: 272 Times
Hey, Juda,
- Do you also experience the 'Krrr' noise under sudden acceleration that's being discussed ?
- Can your source in Tata, help us resolve this ?
thanks
Old 31st July 2008, 16:17   #390
Thanked: 245 Times
I am a bit hesitant to accept this as a reason since if the heat is getting so high it will effect other fluids also in the engine bay. Shouldnt the coolant in the radiator also evaporate to some extent then.
Fill the water to the brim on a friday night and then check in the morning (better if it doesnt run over the weekend), then check again before any running. If level goes down there has to be some leakage somewhere, IMO.
Your help will be much appreciated.
But first we need to check with some new owners of Safari 2.2 2WD if they also dont get the "Krrrr" noise. If they do then its the same thing and probably some things are changed only for the 4WD.
Hey, Juda,
thanks
My new Tata Safari GX - Cycus Grey + Artic Silver umang dutt Test-Drives & Initial Ownership Reports 124 14th May 2010 22:19
New Tata Safari 2.2 VTT EX 4X2 EDIT 25000kms service done harjeev Test-Drives & Initial Ownership Reports 324 27th November 2009 09:18
Finally my Bull comes home. A TATA Safari 2.2 VTT Ex 4X2 Pearl White blackbeast Test-Drives & Initial Ownership Reports 31 15th September 2009 02:16
New Tata Safari 2.2 VTT 4X2 EX Artic Silver HULK JUDA Test-Drives & Initial Ownership Reports 86 12th June 2009 19:11
Safari 3.0 dicor or 2.2 VTT dicor ? tabrez02 SUVs, MUVs & 4x4s 49 30th December 2008 12:56
