| | Thread Tools |
| | #16 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| IMHO think too much of unwanted stuff done for a 15,000 km service. For starters Gear oil was not required to start with same with coolant. Both replaced only at 20000 kms at the earliest. Wheel alignment if done outside would be 200 bucks. AC unless you had an issue it was absolutely not required! Maruti has something called 5 point check and 9 point check, thats all required at 15,000 kms. You should wait for 20 k before you do 20k service at 15k, car is too young. Brake pads did you check the wear indicator?
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin Last edited by Jaggu : 21st February 2008 at 22:23. |
| | #17 (permalink) | |
| BHPian Join Date: May 2006 Location: bombay
| well i dont brake hard because i cant afford to flatspot my tires, but i do drive fast. in fact i always pump my brakes. will sometime post pics of my old pads i have the pads at my place. At 2 200 for front brake pads thats safety, speed and performance guarrantied man , just cheap if i dont change them + the mechanic who doesn't know me nor how i drive said i had 5 000 km left on them tarox , EBC , etc say always replace pads when 60 % worn - reason being the thinner the pad the faster they heat and over heat resulting in failure , warped/damaged discs and brake fade Quote:
200 rs wheel allignment !!! i didnt do that to my 118 NE !!! thats allignment with STRING !! Jagu : read properly when did I say 15 k ??Busa said that ! My car was serviced at 17600 Km because she needed it what difference does 2000 KM make? For my and my cars well being. Have a big feeling you and me are very different people when it comes to cars and driving. Last edited by theMAG : 21st February 2008 at 23:45. Reason: Please continue to use the same post to record adjacent thoughts | |
| | #18 (permalink) | |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: Mumbai, India
| Quote:
Something I don't understand, what is "Paid service : Rs. 700" for? When they have charged labour for every job carried out. Also what is "lubricating brake calliper bush?" And throttle body cleaner is Rs. 505? They used one whole body of TB cleaner? I need to be more careful when my 20k kms service comes up.
__________________ Viffman still rides amongst us! Turbo Lover. | |
| | #19 (permalink) |
| what diff does 2000 km make, then why change gear oil ![]() Hey am not questioning your TLC for your car, trust me i also do that and sometimes go beyond reasoning BUT if the money spent doesnt make a diff to the car it aint worth it is what i feel. And 200 Rs for the best laser wheel alignment set up, in Bangalore. String method is very costly since very few have that skill these days.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin Last edited by Jaggu : 21st February 2008 at 22:46. Reason: missing 0 and gunitee :) |
| | #20 (permalink) |
| Ported the Rs 700 bucks is what i referred to as 9 point check by maruti and anything apart from those 9 points are billed separate. Aint that convenient lol, sad fact all dealership and authorized workshop follow the same model for most of the manufacturers.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #21 (permalink) | ||||
| Quote:
![]() bgprod.com Air Intake System = throttle body yeah as for the brakes i think they charged me labour of 700 that included bleeding with a wurth machine , opening inspecting and cleaning my drums AND brake pad change for the front along with grease where needed. Thanks for the valve adjustment gyaan man :] PS : they charged me twice for gear oil will get back to them for that PS 2 : i asked for all of this very specifically , knew what was needed and required. Supervised every bit of it stopped the mechanic from making dumb mistakes 6 times !! Quote:
9 point check up , HAH ! look in your manual see what they [ official maruti ] say needs to be done at 20 000 service - then see the 9 point check list which dealers provide 700 is a charge purely for getting a paid [ not free ] service done at S & S Quote:
total bill was 15100 rs excluding the oil-ows + oil filter-K&N + oil flush-ows + radiator flush-tectaloy = 15,100 + 5200 = 20 300 rs + ows gas treatment rs 600 Quote:
it did and does make a difference string method a skill !! ??? happens all over mumbai and it costs 200 bucks just lamblasted a friend for doing it in his ikon even though he said the car felt alligned ps : like i said 10 mins back i any way changed the gear oil at 14000 km . Why ? because i felt it needed it and man it felt SO SO SO much smoother after i just changed the gearoil at 14 000 km it was not funny. Maruti says change it only at 20 000 KM PS2: putting in synthetic gearoil sooner than later rs 1800 a lt. OWS synthetic gearoil the only gear oil which i can find which is synthetic and gl 4 rated ! Last edited by theMAG : 21st February 2008 at 23:17. Reason: Please continue to use the same post to record adjacent thoughts | ||||
| | #22 (permalink) |
| lol i know the list and the points for 20 k kms service, i was not referring to that, rather the way dealers bill. when you go back for double bill for gear oil, try getting some more info and understand the same. the water 40 ml that came from exhaust is due to condensation, which any well tuned engine at start up/cold engine will give out. This is specially true for MPFI engines. Am glad at the work done and inspired by the excitement, but am tired and hitting the good ol sack for the day. Will entertain each other some other time. cheers Jaggu
| | #23 (permalink) | |
| Quote:
The equipment is only as good as the operator using it.
| | #24 (permalink) | ||
| Quote:
listen man that maybe true but chances of a hunter error free alignment system making a mistake is FAR less than a human with a pipe. Besides i am not that cheap to leave a service station and go get my tires and wheels balanced and aligned somewhere else not to mention the fuel wasted while doing so. Also they have a dedicated bunch of guys that only do alignment/balancing. So im pretty sure they knew what they were doing.Also for the first time in 3000 Km and 2 different alignment guys later my car is finally going in a straight line .so they did a very good job AKAIK. { my new rim-tire package helped tremendously } + i dont go to " somebody at a random tyre shop with an alignment machine.' Quote:
how often does your car give it out at startup? Only a really clean engine would do that.Dont even think mine does that 1 st thing in the day but i dont rev hard at my first startup either way NOR have i checked. But the water came after my decarb and the BG Air Intake System Cleaner. Meaning no water even after the decarb but water after the BG which was done after the de carb i am not doing this to entertain you , trust me ,maybe just to prove a point AND defend myself . Last edited by theMAG : 21st February 2008 at 23:47. Reason: Pl note that once posted, a post can be edited for upto 20 mins from that time. Trust there's clarity on this. | ||
| | #25 (permalink) |
| Killer :- Sikand Standley Enterprises (Pvt.) Ltd. A 5, 44, Amrita, Sher Gill Marg New Delhi-110 003 India 011-91-11-2463-5146 Phone 011-91-11-2469-7563 Fax thats the BG guy for india. Very impressed with the Throttle body cleaner AKA BG Air Intake System Cleaner. Welcome to BG Products, Inc. |
| | #26 (permalink) | |
| Quote:
its not a spray its a liquid which is sprayed into your TB [ VIA a required machine ] while your car is running .Takes 20 mins . Some people were confused and its the 1 st time i had heard of it or seen it or used it . Its for the inside s not just the TB or butterfly valve or whatever its called. cheers Last edited by cyneverdie : 22nd February 2008 at 03:59. | |
| | #27 (permalink) | |
| Quote:
a) the string comment was total sarcasm from my side ![]() b) my car is diesel, if water comes its konked!! c) all my other cars used to do tail pipe emissions loaded with H2O at start up, coz i keep them tuned. Its nothing to do with "clean", its proper tuning. When you idle for throttle body clean, carb clean/purge the vapor condenses inside end can and when you rev afterwards it comes out. Thats all. Finally reason why i took the effort to reply to your post? There are lot of NON experts amongst us (including me to an extent) and i wouldnt want anyone to be misguided. Yes 20k kms is a major service and going by dealer recommendation it will be expensive compare to rest of service BUT it neednt be as Exorbitant as your bills. Finally you have chosen some very good products to pamper the car, am not disputing it. But if you say that its the only reason for amazing results, am not convinced. This is purely my experience which i am sharing, no need to defend anything or prove a point to me. You are the owner of your car and you know best. cya Jaggu
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin | |
| | #28 (permalink) | |
| Senior - BHPian | Quote:
You have just gone overboard with the service. Quite a few things didnot need replacement and doing what all you have done will lead to very marginal increase in performance. Instead get a Turbo or something if you really want performance.
__________________ thecarsandmore.blogspot. com | |
| | #29 (permalink) | |
| Quote:
But be specific with what didnt need replacement.I would love to hear this man. PS : i rather go high compression than turbo on THIS car. Can get the same power gains as gembella without a turbo plus it would be more reliable Last edited by cyneverdie : 22nd February 2008 at 14:42. | |
| | #30 (permalink) |
| the them i referred to was speedworksindia i must say the ONLY issue i have is that they didnt direct me to a plug gapping machine , which IS available in bombay. gapping by hand [ which was not done by them , but done by someone JD Madan highly recommended ] did ruin my plugs. Live and learn i guess , but its all good. Still will go back to them and still do have faith in them. Thats all i wanted to say before people misunderstand. cheers people |
| Thread Tools | |
Similar Threads | ||||
| Performance MODS for ALTO lxi | badboyscad | Modifications & Accessories | 41 | 18th April 2008 12:00 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
