Old 27th March 2008, 17:53   #136
suman's Avatar
Thanked: 256 Times
I want to know the right practice regarding this.
The manual for the 3 litre does mention this, not sure about the 2.2, have you checked your manual?
Old 27th March 2008, 19:11   #137
smsrini's Avatar
Thanked: 216 Times
Here's what i follow:
First start in the morning: wait for 30sec before engaging 1st gear and driving. This is also advisable for COLD starts i.e. the engine has sufficiently cooled down to ambient room temperature.
Stopping anytime: 30sec to let the turbo reach idling speed, and then switch off.
smsrini is offline   Reply With Quote
Old 27th March 2008, 19:23   #138
sandeepmdas's Avatar
Thanked: 282 Times
Here's a discussion....
Halfbakery: Turbo Saver
Here's some electronics:
Browser Warning
never mind the "browser warning" above; im using Opera...:-)
sandeepmdas is online now   Reply With Quote
Old 27th March 2008, 19:51   #139
Thanked: 242 Times
As per the 2.2l manual you are already following it i.e. 30 sec idle before start/stop
Old 27th March 2008, 22:47   #140
jkdas's Avatar
Thanked: 1,269 Times
Suman, manual asks one to follow the 30sec rule. The longest 30seconds one has to wait!
I am following these.
Bit OT, the same rule goes for all diesels? DDIs and all?
Browser Warning
Thanks for the links.
Old 28th March 2008, 10:04   #141
1) A sound like bird chirping from either left door or boot gate when you drive through very bad road. Should be a beading issue I guess.
1) I had a similar issue at the 30K service. In the boot area, near the roof, you will find some plastic cladding. In my truck, the clips inside the cladding have worked loose and I get the same chirping noise. The part has been ordered and will be replaced under warranty once received.
dicorex4x4 is offline   Reply With Quote
Old 28th March 2008, 11:54   #142
The 1/2 minute principle is to enable the floating bearings on the Turbo to be lubricated well so that the Turbo bearings are well lubricated.
The manual is quite descriptive on this subject.
kingshukt is offline   Reply With Quote
Old 28th March 2008, 12:10   #143
jkdas's Avatar
Will check this. Seems this is an old issue as Steer too had this issue sometiem back.
Odo @ almost 1400 and hence I booked for 1st Free Service for tomorrow.
3) The problem with engaging 1st and reverse when the Safari is cold, ie,in the morning or after long parking gaps of 3-4 hours.
Now is this ok or an issue?
When you depress the clutch fully when the Safari is idling, the engine noise is lesser, ie, engine sounds more refined when doing so.
Can someone explain these.
I need to read through tech links regarding turbo ! Time to as colleagues wonder why I do this!
Old 28th March 2008, 12:22   #144
suman's Avatar
Thanked: 256 Times
OK, here you go - the ones I can.......
Have you checked the knob below the rear seat (the one that you turn to fold the seats forward)?
The 2.2 has pretty good insulation & beading on the doors & tailgate so it shouldn't be the beading....I could be wrong though
2) Child lock for rear left door goes back to "lock" position now and then when you close door as its a bit loose.
If it keeps slipping & is very loose, ask them to replace. Your mantra should always be "replace" at the first signs of a niggle
I had noticed the same problem recently with the 1st gear, not with reverse, would go away on warming up. Complained at the 30k service, not sure what they did but its gone.....
I think this is normal & noticeable in most diesels but is it such an appreciable difference? If so, ask them to check it out
Old 28th March 2008, 12:25   #145
simply_sunny001's Avatar
Thanked: 15 Times
hey JK
"The problem with engaging 1st and reverse when the Safari is cold, ie,in the morning or after long parking gaps of 3-4 hours."
this shouldnt be there in a new vehicle as i have seen this problem normally
1. after change in gear oil
2. some people dont depress the clutch fully and safari's clutch throw is long.
3. in cold starts obviously there is some resistance,but it shouldnt be much and everyone must have felt this.
What i would suggest that you try these 2 things
1. try fully depress the clutch and try engaging the 1st gear
2. try to engaging the 2nd gear and then try to move to ist
even if you dont feel situation improving please visit TASS
EDIT : Oops just saw Suman's post.
simply_sunny001 is offline   Reply With Quote
Old 30th March 2008, 18:29   #146
DDDHRUV's Avatar
Thanked: 9 Times
I too face this problem with the first and reverse gear. Such a wonderful vehicle otherwise. I wonder why TATA cant sort the gear issue. The through is too long and one wishes his hands were 1 feet longer. The level of comfort is missing when one engages the 1st gear.
DDDHRUV is offline   Reply With Quote
Old 1st April 2008, 22:49   #147
jkdas's Avatar
Default 1st Free Service at TASS, Odo 1498 kilometers
Beast back from 1st Free service. Paid nothing.
The issue with child lock and the chirpy sound was sorted out.
The Safari also got under body coating and a wax coat. Also got light tints done. All these were free from Kulathungal Motors.
Yet to find System D and hence didnt fill up full tank.
Bought carpets from rexin shop! Felt it would do the job well in rainy and dry season. Will post pix of these later. Had to buy 3 meters x 2 feet in total.
Sankar test drove the Safari. Hope he finds time to post experience about it.
jkdas is offline   (1) Thanks Reply With Quote
Old 1st April 2008, 22:52   #148
jkdas's Avatar
Default Tata Safari 2.2 4x2 EX. Interiors pix
Some pix of interiors.
1) My throne!
2) Most comfortable seats under 10lac!
3) Shiny Shiny!
4) Elephant ear!
Old 1st April 2008, 23:03   #149
kkdelhi's Avatar
Thanked: 13 Times
How's the music system and the sound quality through the speakers (I guess included)?
kkdelhi is offline   Reply With Quote
Old 2nd April 2008, 12:42   #150
benbsb29's Avatar
Thanked: 3,139 Times
JK, why do you still have the plastic on the head rests?! Get rid of them, whatever be your reasons for keeping them on.
benbsb29 is online now   Reply With Quote
Ford: Extended warranty up to 5 years / 100,000 kms for EcoSport & Figo Tushar The Indian Car Scene 23 27th March 2017 17:08
Attached: BMW's full BSI & extended warranty price list (up to 10 years / 200,000 kms) VSD Technical Stuff 40 22nd March 2016 13:24
Reclaiming life - My Tata Safari TCIC. 13 years, 1,23,000 kms and counting sumannandy Long-Term Ownership Reviews 163 19th April 2015 07:54
Tata Safari 3.0 Dicor: Burnt, Recovered and Reclaiming @ 1,62,000 Kms EDIT : Now SOLD! mercedised Long-Term Ownership Reviews 34 19th February 2015 06:46
Tata Motors - Extended Warranty Woes (Vista TDi) nukeblitz Indian Car Dealerships 8 10th March 2013 11:41
