Old 20th October 2008, 23:06   #451
iraghava's Avatar
Thanked: 146 Times
That looks like a cut from a steel/metal piece you hit somewhere. As far as I can make out from the picture only the outer tread has a cut and that too does not look very deep. But I would recommend getting the tyre taken off the rim & the tyre inspected by an expert from the inside also just to check on the extent of the damage (even though I don't think it'll be more than a couple of mm deep at most).
As for warranty coverage, no this will not be honoured under warranty in most cases. Also, if the cut is as deep as I'm assuming then it's perfectly fine to keep using this tyre since once the tread wears down to the deepest level of the cut, it'll disappear anyway.
In other words, this cut does not look like something that'll threaten the normal operation of the tyre or affect it in anyway.
Old 21st October 2008, 01:47   #452
kb100's Avatar
JK
It might also help to use this tyre exclusively for rear wheel duties. Will put less stress on it!
kb100 is offline   Reply With Quote
Old 29th October 2008, 21:14   #453
greenhorn's Avatar
Thanked: 918 Times
I'm thinking about getting Delvac MX for my next oil change what about you? . Found a shop near pongumood which had the stuff. 1100 for a 5L can
PS: they also had synthetic
Old 29th October 2008, 22:41   #454
Awaiting Email Confirmation
Thanked: 18 Times
doesnt that work out to Rs220/litre? try 04842342790 its the mobil wholesaler in cochin- I had got mine for 170/litre from them.
Old 29th October 2008, 23:38   #455
Jaggu's Avatar
Thanked: 5,911 Times
Dont run high speed / long distance with that cut, to avoid risk of thread sheering, especially since the vehicle is heavy the strain on the cut thread will be more. Very slim chance it will be covered under warranty also. I would move it to spare tyre duty.
Old 1st November 2008, 23:27   #456
jkdas's Avatar
Thanked: 1,269 Times
I used to get synthetic for my Xing from him. Nice dealer.
I got oil changed for free from TASS. Got GTX this time. Thanks to call from Tata Engineer from Cochin
Changed the defective tyre to stephney.
Guess what? my right side rear tyre has a cut too, but worse I guess. It doesn't look deep though. Defective pairs I got?
ishaan, there was/is not mark of any cut or so and this is what is perplexing me.
Old 2nd November 2008, 09:46   #457
srijit's Avatar
JK, is somebody targetting your Safari? Can this be caused by a blade or sharp instrument?
srijit is offline   Reply With Quote
Old 2nd November 2008, 13:41   #458
jerish666's Avatar
Whats happening to your tyres?I think its a tyre problem.
jerish666 is offline   Reply With Quote
Old 2nd November 2008, 14:26   #459
greenhorn's Avatar
Thanked: 918 Times
thats what i thought too. he was such a nice guy. He suggested some alternative oils,which of them were better, and we had a discussion about my indica's requirement. he was of the opinion that indica's needed only 5L ( which is true for the NA indica's)
I liked his attitude so much that i decided to get it from him after all, despite the 250 buck difference! Now to wait for another 5 months !
Old 10th December 2008, 22:00   #460
jkdas's Avatar
Met with an accident two weeks ago. An absent minded old man in an Activa forgot that his by-road ended . He rode straight in front of my Safari. I saw him seconds ago but I knew I couldnt do anything. I alerted my uncle and cousin that I am gonna hit him (no other way, both sides of road had lot of people and traffic). We all remember seeing him in air above Safari's height and then fall on the bonnet and then roll off. I thought he was dead. Lucky him and me, that I was able to bring the Safari to almost stop prior to hitting him.
Took him to nearest hospital in my Safari and after initial diagonse we came to know he was alive and had nothing broken! Send him for a CT Scan and I wanted to make sure he was all ok and he was as per the CT scan result. All he had was 3 stictches on hsi head and some brusie. He was awake by the time they brought him back afer the CT scan.
Since they didnt have any issues and thr local crowd saw how it all happened we all didt want a case and split after settling his hospital bill.
CT scan which is a life saver costs just 1800 Rs here. A must scan in most cases.
I drove on with a non working left fog lamp and a broken bumper etc. I got my Safari back last week. 21k from pocket for now. Yet to get the claim amount.
I had to replace front bumper(3700Rs), front grill (3700Rs !!!), fog lamp (1141Rs), headlamp (3200rs), bumper grill (560Rs). All plastic !
The bonnet was fixed by spot suction method and hence saved money. I dotn think any other vehicle can take a hit like this. A 60-70kg human falls on a bonnet and all I get is this! See the photo.
And was pretty happy to see a very thick bar just behind the bumper (almost in parallel to the number plate, it should be aleast one inch in diameter). _
Old 10th December 2008, 22:25   #461
Thanked: 18 Times
All's well that ends well. Lucky everything worked out. How much do you expect the depreciation is going to cost on all the plastic and glass?
Old 10th December 2008, 23:01   #462
raj_5004's Avatar
Thanked: 1,954 Times
sad to see the car's state buddy. i know how it feels when we see our beloved vehicle in such a condition.
i am very glad to hear that you took the initiative to take him to the hospital and cover all his medical expenses. i have heard that the people in kerela beat up the car driver in the event of an accident? true?
Old 10th December 2008, 23:04   #463
greenhorn's Avatar
Thanked: 918 Times
it has happened in the area where this occured . Even I keep an extra eye out in that region. jkdas had no problems though
Old 11th December 2008, 14:29   #464
adc
adc's Avatar
Thanked: 2,065 Times
Good clear thinking inspite of the accident must have had the crowd/mob under control. Also much relief to read that nothing serious came out of it.
The frontgrill price atrocious, whats the damage to the headlamps - could not make out any.
adc is offline   Reply With Quote
Old 11th December 2008, 14:31   #465
raj_5004's Avatar
Originally Posted by adc View Post
Good clear thinking inspite of the accident, good to hear that nothing serious came out of it.
look at the base (inside), there seems to be a crack.
Ford: Extended warranty up to 5 years / 100,000 kms for EcoSport & Figo Tushar The Indian Car Scene 23 27th March 2017 17:08
Attached: BMW's full BSI & extended warranty price list (up to 10 years / 200,000 kms) VSD Technical Stuff 40 22nd March 2016 13:24
Reclaiming life - My Tata Safari TCIC. 13 years, 1,23,000 kms and counting sumannandy Long-Term Ownership Reviews 163 19th April 2015 07:54
Tata Safari 3.0 Dicor: Burnt, Recovered and Reclaiming @ 1,62,000 Kms EDIT : Now SOLD! mercedised Long-Term Ownership Reviews 34 19th February 2015 06:46
Tata Motors - Extended Warranty Woes (Vista TDi) nukeblitz Indian Car Dealerships 8 10th March 2013 11:41
