Old 18th October 2008, 13:45   #436
Thanked: 1,409 Times
Noticed this two days back. I am sure I havent him anything sharp or even jumped big potholes. I am to take the Safari to TASS for this right?
To repair a cracked tire? All the best!
Steeroid is offline   Reply With Quote
Old 18th October 2008, 14:25   #437
Awaiting Email Confirmation
Thanked: 19 Times
Edit: What is that small arrow doing there just below the crack?
that arrow indicates the weakest spot on the tyre. where it is most susceptible to damage.
now, seriously, before I get an infraction for wisecracks-
the arrow is the tread wear indicator.
Old 18th October 2008, 15:07   #438
A S H V I N's Avatar
or maybe it says "caution! crevice! do not fall in!" or "this side up/down"
back to the topic, well i dont thnk that the crack is potentially harmful. let us see what the "tyre Mafia"(as they are known in Cochin by many people) has to say.
A S H V I N is offline   Reply With Quote
Old 18th October 2008, 19:07   #439
Thanked: 242 Times
They are the tread wear indicator, the cut in the tyre is the end of life for it.
Its dangerous to drive with it since its extending into the sidewall and can spread more.
Old 18th October 2008, 19:45   #440
jkdas's Avatar
Thanked: 1,340 Times
All I have as proof about the tyre is a stamp in my Owner's Manual which says Bridgestone and MFD date of the tyres. Thought it will be easy to give the vehicle to them on my way to work so that they can do the necessary.
Old 19th October 2008, 06:46   #441
nitrous's Avatar
Thanked: 256 Times
What is the manufacturing week and year of that tyre?
Old 19th October 2008, 12:16   #442
jkdas's Avatar
March 2008.
I should get it replaced without issues right?
Old 19th October 2008, 18:54   #443
smsrini's Avatar
Thanked: 220 Times
I doubt if Tyre cracks will be covered under warranty for any brand of tyres.
If this tyre is one of the running 4, change it NOW. I'm sure you've done it.
JK, I remember you taking it 'where no jap cars would dare go even once??' Could something have caused it there ? Else it could be due to under inflated tyres being used on bad roads that could have caused it.
Anyway, hope you get it replaced free of cost.
drive safe.
cheers!
smsrini is online now   Reply With Quote
Old 19th October 2008, 19:17   #444
Thanked: 123 Times
Originally Posted by smsrini View Post
... I remember you taking it 'where no jap cars would dare go even once??' Could something have caused it there ? Else it could be due to under inflated tyres being used on bad roads that could have caused it...
But does driving an under inflated tyre or running it on rough surface cause such a crack? If there was a tear, I would understand, but this?
JK, all the best. I do hope you get a replacement!
HappyWheels is offline   Reply With Quote
Old 19th October 2008, 19:19   #445
Thanked: 242 Times
drive safe.
cheers!
I second that for replacement, as tyres are only covered for manufacturing defects i.e. uneven wear (if you can prove not a alignment problem) and bulges etc. For a cut or tearing of sides etc its usually blamed to the owner.
Old 19th October 2008, 19:39   #446
jkdas's Avatar
drive safe.
cheers!
This should have happened very recently. I havent jumped any ponds on NH or so recently. And there is no visible mark of anything piercing the tyre or so.
I also check tyre air pressure now when I go for every alternate fueling.
Old 19th October 2008, 20:06   #447
sudev's Avatar
Thanked: 1,898 Times
As far as I could make out from the picture this does not seem like TWI arrow as across the tread there is not tell tale ridge that usually runs across. But then I could be wrong. Gurus?
sudev is offline   Reply With Quote
Old 20th October 2008, 21:30   #448
jkdas's Avatar
How can a tyre crack ?
IN btw, called up Tata Support at 02266158400 and they asked me to talk to their engineer in Cochin which I did (Shaji) . He wanted me to reconfirm that it was GTD (GTX is fine) which I did later. I also complained about the krr krr and from his reply I understood that its exists/he has heard of it.
Liked the way he took feedback and his josh.
Yet to take the Safari to the TASS and tomorrow I cant as we have the #$%^& th hartal tomorrow.
Old 20th October 2008, 22:47   #449
greenhorn's Avatar
Thanked: 1,031 Times
where did you get the number from?
PS : even I'm thinking about getting some GTX Diesel for my next oil change. they will put in if we give them right ?
about the krr krr
its not gone yet ?
greenhorn is online now   Reply With Quote
Old 20th October 2008, 22:55   #450
jkdas's Avatar
its not gone yet ?
They are supposed to use GTX for 2.2L instead of GTD as Mobil isnt sold anymore.
I called Tata Support and said I have a complaint. They asked me to talk to Shaji first.
Attached: BMW's full BSI & extended warranty price list (up to 10 years / 200,000 kms) VSD Technical Stuff 41 8th June 2017 21:50
Ford: Extended warranty up to 5 years / 100,000 kms for EcoSport & Figo Tushar The Indian Car Scene 28 27th April 2017 09:57
Reclaiming life - My Tata Safari TCIC. 13 years, 1,23,000 kms and counting sumannandy Long-Term Ownership Reviews 163 19th April 2015 07:54
Tata Safari 3.0 Dicor: Burnt, Recovered and Reclaiming @ 1,62,000 Kms EDIT : Now SOLD! mercedised Long-Term Ownership Reviews 34 19th February 2015 06:46
Tata Motors - Extended Warranty Woes (Vista TDi) nukeblitz Indian Car Dealerships 8 10th March 2013 11:41
