Old 20th July 2012, 17:09   #661
jkdas's Avatar
Thanked: 1,352 Times
Default Re: Safari 2.2L EX ; now 1 lac kms plus; Reclaiming continues without Extended Warran
Originally Posted by ameaa View Post
Hi Jkdas. Congrats on crossing 1 lac km. You seem to have a descent monthly run. If possible please share your local mechanic info if he is in EKM. Would like to give a visit.
How much did your OE tyres last?
I goto a Tvm guy.
http://www.team-bhp.com/forum/other-...rivandrum.html (Independent Tata Service center - Highway Garage (Trivandrum))
Why not try the independent one there?
Tyres last 45-50k.
jkdas is offline   (2) Thanks Reply With Quote
Old 20th July 2012, 17:17   #662
Thanked: 35 Times
How is the Clutch in the 2.2L Dicor? Is it easy to use? What about the comfort of using it through the different stages of the 1lac kms. Planning on picking up the Tata Xenon. Im guessing they have the same mechanicals, ie same engine,gearbox,clutch.
Anil Rajani is offline   (1) Thanks Reply With Quote
Old 20th July 2012, 17:57   #663
Thanked: 39 Times
Thanks JK. 50K on kerala roads are good. I still haven't researched the local guys in BLR. Don't know how they fiddle with Dicors..
ameaa is offline   Reply With Quote
Old 2nd September 2012, 23:00   #664
Thanked: 39 Times
Hi JK, what interval did you replace the rear brake liner. I have replaced my front brake pads at 40K, i still haven't changed the rear set yet. From your experience please let me know how long the liners last.. thanks.
Old 17th January 2013, 14:36   #665
jkdas's Avatar
Its easy unless there's a fault. I changed it at 60k ( which I think was unnecessary). Odo now at 1.10lac and the clutch is still good.
At 90kish I changed the rear.
Ask the mechanic to check the pads. They will suggest if it needs a change (which is based on your usage).
For your reference, check the thread @
The bill and update
Odo @ 91,000km almost.
The clutch issue was back ( was expecting). Got master cylinder changed at http://www.team-bhp.com/forum/other-...rivandrum.html (Independent Tata Service center - Highway Garage (Trivandrum)).
I was charged 2k for the cylinder, 400rs for labour. I am happy.
Also, they got the fog lamps fixed for 120Rs!!! ( 60Rs for bulb holder and 60Rs for a bulb!) .
Mohandas Motors wanted to replace BOTH fog lamp units to fix it!
Old 17th January 2013, 14:51   #666
bj96's Avatar
Thanked: 122 Times
Hi JK,
My 4th year servicing is due next month after which extd warranty expires too. My truck has done only ~22k kms, mostly highway runs and very little 4x4 use. Based on your experience do you recommend timing belt change in next service? Manual says 100k kms for belt replacement,but, doesn't say anything about time limit.
tia,
-BJ
bj96 is offline   Reply With Quote
Old 17th January 2013, 16:39   #667
smsrini's Avatar
Thanked: 232 Times
JK, have you changed the Shock absorbers and springs or are they still factory fitted ones ?
Trying to understand when they will need replacement. I know it will be based on the usage etc.,
smsrini is online now   Reply With Quote
Old 17th January 2013, 20:22   #668
kaviprem's Avatar
Thanked: 546 Times
Originally Posted by bj96 View Post
Hi JK,
tia,
-BJ
BJ, My beast is due for 3 year service [45K] in a month's time with my ODO reading 40K. So far, my service engineers havent recommended to change the Timing belt change. So, I wouldnt expect yours too at half the ODO reading !
Prem.
kaviprem is offline   (1) Thanks Reply With Quote
Old 17th January 2013, 20:30   #669
infotech58's Avatar
Thanked: 217 Times
Assuming your truck is 2009 made, and given it has done only 22k since then, you do not really need to change the timing belt.
Typically timing belt is changed at 90-100k or if vehicle is 7-8 years old with no timing belt change so far. Rubber belts (timing belt, alternator belt, power steering belt, etc) become brittle with age hence need replacement.
Hi JK,
tia,
-BJ
infotech58 is offline   (1) Thanks Reply With Quote
Old 24th January 2013, 17:30   #670
jkdas's Avatar
All OE ones till date! Not bad eh? Who was complaining about quality
Prem.
It has to be changed only at 1lac odo. This info was posted by someone else also in another thread.
jkdas is offline   (1) Thanks Reply With Quote
Old 26th February 2013, 14:01   #671
tsk1979's Avatar
Thanked: 15,539 Times
Originally Posted by gowda79 View Post
Jk the service manual clear tells as mentioned below on Page 147 -
Change Clutch & Brake Fluid (Or 2 years whichever is earlier) 30,000 km
Better get this checked at the service station.
If you do not get oil changed at 30K service, somewhere down the line, you will be denied extended warranty if your clutch master or slave cylinder fails. I have faced this. Had to pay for the cylinders, because Automobile Sterling in Noida did not change clutch oil at 30K
Hi JK,
tia,
-BJ
Was your timing belt ever changed? If not, I suggest you get it looked at. Older safaris had a defective design where timing belt would break within 30K kms, and then you would be looking at a huge expense.
I suggest you get the retro done under extended warranty. Ask the service center to open timing kit and water pump. If any problems are found, push for entire retro kit under extended warranty.
tsk1979 is offline   (1) Thanks Reply With Quote
Old 17th March 2013, 22:35   #672
jkdas's Avatar
Default Odo @ 1.13 lac, 5yrs
Completed 5years two days ago. Odo at 1.13lac if I remember correctly.
  • Have to find how I can block the air is not to sucked when its in recirculation mode.
  • Have to get 2 new tyres. Thinking of something different this time; other than yokos.
  • Also have to get suspension checked; will be done along with new tyres.
  • Fogs have to be fixed. Guess fuse are blown.
Tata Safari 2.2L at 1.5 lakh kms. Reclaiming continues without extended warranty-wdsc_0883a.jpg
jkdas is offline   (3) Thanks Reply With Quote
Old 18th March 2013, 12:41   #673
n.devdath's Avatar
Thanked: 1,482 Times
Default Re: Odo @ 1.13 lac, 5yrs
1. Some air will always come into the cabin even in re circulation mode. This is a known feature/glitch.
2. Try Michelins. Suresh and Hari have it on their steeds and are very happy with them.
Old 18th March 2013, 12:56   #674
condor's Avatar
Thanked: 3,798 Times
How long more you keeping the truck ?
Old 18th March 2013, 13:17   #675
Prowler's Avatar
Thanked: 267 Times
Congratulations JK. 5 years and 1.13 Lac KM - you are really Reclaiming your life. You and Tsk Saab have one of the longest running 2.2 DiCors in this community.
Prowler is offline   Reply With Quote
Attached: BMW's full BSI & extended warranty price list (up to 10 years / 200,000 kms) VSD Technical Stuff 41 8th June 2017 21:50
Ford: Extended warranty up to 5 years / 100,000 kms for EcoSport & Figo Tushar The Indian Car Scene 28 27th April 2017 09:57
Reclaiming life - My Tata Safari TCIC. 13 years, 1,23,000 kms and counting sumannandy Long-Term Ownership Reviews 163 19th April 2015 07:54
Tata Safari 3.0 Dicor: Burnt, Recovered and Reclaiming @ 1,62,000 Kms EDIT : Now SOLD! mercedised Long-Term Ownership Reviews 34 19th February 2015 06:46
Tata Motors - Extended Warranty Woes (Vista TDi) nukeblitz Indian Car Dealerships 8 10th March 2013 11:41
