Old 19th April 2013, 06:51   #691
jkdas's Avatar
Thanked: 1,336 Times
Default Re: Safari 2.2L EX ; now 1 lac kms plus; Reclaiming continues without Extended Warran
With Torque lite I just get Load from the engine. The Liva however shows everything. I guess I need to try the fun2drive app
Do update if you where able to save data in fun2drive.
And how many times would you have done whole suspension work?
How many times were your Safari's ball joint, centre link etc changed?
Old 20th April 2013, 12:55   #692
jkdas's Avatar
Default Blocking or reducing suction from outside Tata Safari
Originally Posted by ameaa View Post
Hi JK, Blocking or reducing suction from outside is pretty easy. The opening is inside the black fairing which sits below wiper arms below the front windsheild. You have to remove the wiper arms and then remove four screws for the fairing to come out. You can see the intake which already has a wire mesh. You can stick a sponge or a similar filter which can filter and same time reduce or filter the air which goes in. The screws are covered with rubber grommets which will come out if you poke with a screwdriver. Hope this helps..
Many thanks for the post.
Hope this helps the rest. Vitamin helps Safari too :P
1) The screws. You need a Philips screw driver and a spanner.
Tata Safari 2.2L at 1.5 lakh kms. Reclaiming continues without extended warranty-1.jpg
2) The wiper's nut without the rubber cover
Tata Safari 2.2L at 1.5 lakh kms. Reclaiming continues without extended warranty-2.jpg
3) The hidden screw after the bush was popped out
Tata Safari 2.2L at 1.5 lakh kms. Reclaiming continues without extended warranty-3.jpg
4) The mesh and leaves!
Tata Safari 2.2L at 1.5 lakh kms. Reclaiming continues without extended warranty-4.jpg
5) Some vitamins
Tata Safari 2.2L at 1.5 lakh kms. Reclaiming continues without extended warranty-5.jpg
I am yet to drive after this job. Can do only next week I guess. Will keep update once I do.
jkdas is offline   (10) Thanks Reply With Quote
Old 20th April 2013, 14:06   #693
Prowler's Avatar
Thanked: 259 Times
Default Re: Blocking or reducing suction from outside Tata Safari
So this is how you became a distinguished BHPian Das. Excellent illustration/images to do this How-to. I will not use the 'Vitamin' thingy and use a card to completely block the port. Thanks.
Prowler is offline   Reply With Quote
Old 21st April 2013, 16:44   #694
Rahulk76's Avatar
Thanked: 204 Times
5) Some vitamins
Attachment 1075669
Thanks JK... I popped open mine and guess what. Crocin strip helps safari too . Just like your picture on the mesh with Vitamins, the Crocin strip fits perfect.
Cheers.
Rahul
Rahulk76 is offline   (1) Thanks Reply With Quote
Old 22nd April 2013, 10:46   #695
tsk1979's Avatar
Thanked: 15,366 Times
Will update when I get to use fun2drive
As for suspension, ball joint, center link, I have lost count of the number of times I have had to work on these.
Old 10th June 2013, 17:17   #696
jkdas's Avatar
So got the second suspension overhaul at 1,14,500km. Cost me 16,900Rs inclusive of front brake pads, a rear fog lamp and a pair of mud guard ( this looks nice).
Will post the split later.
Back to reclaiming
jkdas is offline   (2) Thanks Reply With Quote
Old 28th June 2013, 19:59   #697
Thanked: 371 Times
Back to reclaiming
waiting for split
Was it done at T.A.S.S or outside ? Also 16900 for both front and rear ?
amitk26 is offline   Reply With Quote
Old 1st July 2013, 14:15   #698
jkdas's Avatar
waiting for split
Just the front + brake pads + rear fog lamp (675rs) + mudflap(265rs).
I get all my service done from outside since I dnt have EW. Major services were done at TASS though for the sake of warranty/resale/claim.
Tata Safari 2.2L at 1.5 lakh kms. Reclaiming continues without extended warranty-img2013070100166.jpg
Old 1st July 2013, 14:25   #699
Thanked: 371 Times
Thanks JK.
Actually I went for wheel alignmnet and the guy told me there is a play in front left wheel . Showed it to a garage near to my office and guy showed that play is due to lower arm bush and gave fat estimate for front suspension.
I was sure that T.A.S.S will have similar diagnosis so on saturday took the vehicle to another FNG and this chap simply tightned a bolt below lower arm
after removing the pin and play seems to be fixed. He refused to charge any moeny for this as well and asked me to drive for few days.
I have done around 50 KM afte this but problem has not resurfaced till now. I am hoping that it was just a loose nut.
After this experience I am thinking about oil change and normal service outside
Couple of more questions since you maintain your vehicle outside A.S.S
Can you please tell me brand of the oil filter you are using ?
The FNG guy suggested purolite but I am not convinced because IIRC for 2.2 VTT oil filter was different. I got the part number on the Safari 2.2 VTT thread but could not find OEM for the same.
Old 1st July 2013, 14:54   #700
mercedised's Avatar
Thanked: 155 Times
T
The Safari has the tendency to make the nuts loose, especially the suspension nuts go loose every 7.5K kms. I had this experience that even after suspension work and new tyres the alignment was not getting right. Then, went to my mechanic and he tightened the nuts, to which the alignment guy was referring as play in the wheel. The problem vanished after that. Get the suspension nuts tightened by alignment guy before correcting the alignment.
mercedised is offline   (1) Thanks Reply With Quote
Old 1st July 2013, 16:39   #701
Thanked: 84 Times
[quote=amitk26;3165558]Thanks JK.
It's Purolator IIRC. You can always buy an oil filter over the counter from the ASC and get the oil changed outside.
rb2399 is offline   (1) Thanks Reply With Quote
Old 20th January 2014, 19:23   #702
jkdas's Avatar
Default Re: Amaron Hi-Way battery for Tata Safari 2.2L
Bought a new Amaron Hi-Way battery for 4500Rs (got almost 1000RS for old one). This was bought from the Amaron Trivandrum dealer.
Pix of old and new battery. Old one had 18 months warranty and the Hi-Way has 2 year.
Battery showing signs of old age. Its refusing to start after I parked today. Had similar issue in the morn but it cranked after few min of waiting.
Will go jumpstart it for now using a Fortuner and will buy new one tomorrow.
Old 19th June 2014, 14:24   #703
Thanked: 39 Times
Default Re: Odo at 113500 kms; Tata Safari 2.2L EX on Yoko + MRF Wanderer
Got two MRF Wanderers for 6600 per tyre.
Hi JK, Can you give a feed back on Wanderers? Mine is due for a shoe change. I was looking at better wet road performance and less road noise since i travel more on highways.
ameaa is offline   Reply With Quote
Old 3rd July 2014, 12:29   #704
jkdas's Avatar
'Think' Yokos grip better. I might get rest too changed to Wanderers soon though
Give me a week's time
Old 28th July 2014, 15:26   #705
Thanked: 47 Times
JK dada, how is performance of wanderers in terms of ride quality, noise on highways and handling at good speeds? How will compare it with OEM BS Duellers 689? and Mitchelin L Cross?
Also pl. respond to my query on 'All about Safari tyres' thread. Link below:
http://www.team-bhp.com/forum/tyre-a...-tyres-50.html
LongDrive lover is offline   Reply With Quote
Attached: BMW's full BSI & extended warranty price list (up to 10 years / 200,000 kms) VSD Technical Stuff 41 8th June 2017 21:50
Ford: Extended warranty up to 5 years / 100,000 kms for EcoSport & Figo Tushar The Indian Car Scene 28 27th April 2017 09:57
Reclaiming life - My Tata Safari TCIC. 13 years, 1,23,000 kms and counting sumannandy Long-Term Ownership Reviews 163 19th April 2015 07:54
Tata Safari 3.0 Dicor: Burnt, Recovered and Reclaiming @ 1,62,000 Kms EDIT : Now SOLD! mercedised Long-Term Ownership Reviews 34 19th February 2015 06:46
Tata Motors - Extended Warranty Woes (Vista TDi) nukeblitz Indian Car Dealerships 8 10th March 2013 11:41
