| | Thread Tools |
| | #16 (permalink) | |
| BHPian | Quote:
__________________ Why do they call it rush hour when nothing moves? _________________ SX4 ZXI - 2007 | |
| | #17 (permalink) | |
| BHPian Join Date: Jul 2007 Location: Bangalore
| Quote:
Your FE numbers are enviable. I get only 10.5 in city and 11.5 in highways. Anyways, have a good time ! | |
| | #18 (permalink) |
| Senior - BHPian | This looks like a case of a soft-recall. Wherein upgraded parts are retrofitted when cars come in for service. The Driveshaft change must have been prompted by observation of massive torque steer on the car. Or worse, Maruti might have seen some cases of shaft failure.
__________________ ________________________ Every Ferrari is always a Fiat |
| | #19 (permalink) | ||
| BHPian | Quote:
I am aware they are not related.. but as i mentioned, along with the drive shaft replacement, the service guys also worked on the gears when I complained of it being hard, and at times, getting stuck. What the drive shaft replacement did was to enhance driving in the lower torque gears.. like before, when I had to make the car move from standstill, go gear 1,2 and slowly floor the accelerator, and then you'll know what I meant.. the torque is so slow, that the car can't accelerate fast, and if you floor the accelerator, either you are being welcome with noiser engine, or the ghak ghak sound (jerk). I think this is probably why the dealer changed the shaft. Might be possible that Maruti is aware of this big issue in SX4, and that they have modified the drive shaft, which is exactly what I hear from my service manager. And as I mentioned earlier, the drive is definitely different after the shaft-replacement, i.e, it is much smoother and driving at gear 1,2 is as good as 3,4,5 (don't take literally though) in that, it is responsive and power delivery is instant. Even if I assume that I have a defective drive shaft and that the dealer knew about this, and they changed them. But if that was the case, from the similar complains I hear from SX4 owners, it implies, they too have defective shafts! Quote:
| | #20 (permalink) | |
| BHPian | Quote:
ITNerd, can you confirm from your engineer, if this modified drive shaft is to be installed in every SX4 or was it just for your car? Further, is there an official communication from Maruti about this? Thanks, | |
| | #21 (permalink) |
| BHPian Join Date: Dec 2006 Location: Delhi
| Attention: All SX4 owners Got this from OMishra...and posting for benfit of all Here is some update for you. Please cut paste this message to appropriate website forum too. At this time my car is with Dealer workshop for last 3 days for 10K KM service. During this time I sat with the mechanic and my doubts are confirmed. Low end vibrations are due to week Engine mounts and less pickup is due to change in front drive shaft assembly. Both are redesigned and altered by MUL and circular is out with Dealers. Exact part numbers and changes, differences after change I can tell after I get my car on Monday evening. Pls check with your dealers/workshops if your Car is also having clutch/acclerator pedal vibrations or judder while moving from stop in 1st gear. Pls update this thread with feedback too if any. |
| | #22 (permalink) | |
| BHPian Join Date: Jun 2007 Location: Pune
| Quote:
There is no issue of gear shift, gear/clutch vibration with my car. Now going with Mobil1 SuperSyn 5W50, @900Rs/Liter. I bought 4+1 Liters of it, as SX4 requires 4.4 Liter Max and 4.0 Liters Min Oil. Putting 4.2 now and keeping remaining for top up (if required). | |
| | #23 (permalink) | |
| BHPian | Quote:
And three days for a service! isnt that a lot?? | |
| | #25 (permalink) | |
| Quote:
Friday - color touch to all four corners on bumper 1 day. Saturday- waiting for spares 1 day (meanwhile myself looking out for Mobil1) Sunday no work 1 day Monday complete work+ test 1day Last edited by omishra : 28th April 2008 at 15:46. | |
| | #27 (permalink) |
| Here are changes - 1. Engine mounts 2. Both front drive assemblies. 3. Engine Oil (Mobil1 SuperSyn) 4. Oil Filter 5. Some plastic clips under front fender. Drive experience after change - 1. Engine vibration from standstill to motion: It improved drastically, i can see releasing clutch slowly on plan surface without acceleration doesn't produce any vibration. On uphill it is reduced by 90% (still I can feel little bit of vibration, 10% compared prior to change)<- I think this is common. 2. Uphill stop and go: This is also not having any major vibration and same as above 1. 3.Power: Certainly now if I did not press accelerator then engine is not dieing for power. It balances car with idle rpm on our buildings parking ramp without knocking. I need to floor accelerator to move ahead. On more slop I need to give little acceleration but car moves responsively. Responsiveness of car increased. 4. Effect of Mobil1: I have to find out because initial observation about temperature, it is stable at 1/2 position. Noise and power I could not make difference in my 25 KM driving. THIS WAS THE ACTUAL CAR SX4 -I WAS EXPECTING. About changes - This was for certain cars, Dealer have circular mentioning chassis number. During service they are changing it. now part lists is here - ![]() Last edited by omishra : 28th April 2008 at 22:03. |
| | #28 (permalink) |
| I see that they have replaced "engine mounts" for your car, maybe they added a layer which absorbs the vibrations and doesn;t transfer them to the chassis, but for doing it they would have to physically remove the engine from the bay and replace the mounts, which looks like a complex and time consuming task or is there a simpler way too? The judder experienced while moving from stop in 1st gear and also in stop and go traffic is completely gone or reduced? I don't know about your car, but if you exceed 2.5k rpm, vibrations can be felt in accelerator and clutch pedals. Can you try and share with us if the new setup resolves this issue too? Thanks in advance |
| | #29 (permalink) | |||
| Quote:
In my last trip, I have done upto 140KM/h occasionally and 120km/h constant for 25 min on Pune-Mumbai E'way with upto 3.5k-4k rpm. But I did not experience any vibration in accelerator. I don't remember touching clutch during that time. I can update you when again I get chance to travel on E'way. (may be during next 2 weeks time) | |||
| | #30 (permalink) | |
| BHPian | Quote:
Can you get the Chassis no. range from your dealer which Maruti is changing parts for? My dealer here is still unaware of anything such ![]() Thanks.. | |
| Thread Tools | |
Similar Threads | ||||
| My Logan DLE: Updated to 15000 kms | pugram | Long-Term Ownership Reviews | 94 | 14th May 2008 22:04 |
| 6000 kms road trip travelogue (Mumbai-HP-Punjab-Jammu-Raj.-Ahmedabad-Mumbai)-PART-1 | Pankaj1126 | Travelogues | 17 | 2nd February 2008 17:48 |
| Cedia Sports 6000 Kms - My experience | ranjithc | Long-Term Ownership Reviews | 7 | 26th December 2007 13:23 |
| Toyota Corolla H2 (2006) 6000+ kms report | samirsarkar | Long-Term Ownership Reviews | 19 | 5th June 2007 16:34 |
| Revvhead blabs about his Baleno - 6000 kms | Revvhead | Long-Term Ownership Reviews | 14 | 26th August 2005 16:58 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
