Old 4th May 2008, 17:40   #31 (permalink)
iTNerd's Avatar
Originally Posted by Shankyz View Post
Attention: All SX4 owners
Got this from OMishra...and posting for benfit of all
Here is some update for you. Please cut paste this message to appropriate website forum too.
At this time my car is with Dealer workshop for last 3 days for 10K KM service. During this time I sat with the mechanic and my doubts are confirmed.
Low end vibrations are due to week Engine mounts and less pickup is due to change in front drive shaft assembly. Both are redesigned and altered by MUL and circular is out with Dealers.
Exact part numbers and changes, differences after change I can tell after I get my car on Monday evening.
Pls check with your dealers/workshops if your Car is also having clutch/acclerator pedal vibrations or judder while moving from stop in 1st gear.
Pls update this thread with feedback too if any.
Sorry guys, been away for a week.. and I knew this was coming! I had already told ya guys that the drive shaft and the engine mounts were the problems.. anyway, for me the engine mount correction is still left.. maybe I need to contact them again ! Good that Maruti is listening..
Yes, I just checked in morning. Its gone. Car is very powerful and responsive in lower gear low rpm, smooth in terms of vibrations.
Exactly my friend.. I had been saying that all this time after the drive shaft change... btw, congrats on the new experience
iTNerd is offline   Reply With Quote
Old 4th May 2008, 19:28   #32 (permalink)
gopinathann's Avatar
I called the maruti toll free and they said that they don't have plan to change the shafts in all the cars. If you find problem in your car ask the dealer to check, if it is then they would change it.
__________________
Why do they call it rush hour when nothing moves?
_________________
SX4 ZXI - 2007
gopinathann is offline   Reply With Quote
Old 5th May 2008, 10:40   #33 (permalink)
Yes it is true and I have all experiences with MUL/Dealer are positive.
Thanks,
Yes its car specific. I agree don't let them play with car until you feel problem. Specially on little slop as well as stop and go. In my case, my earlier experience with engine reponse was so sluggish and pathetic that Indica or santro were better. Earlier I could equate performance of my SX4 along side Alto with AC on. (I mean on slope as well as stop and go)
Now definitely miles ahead.
omishra is offline   Reply With Quote
Old 9th May 2008, 20:48   #34 (permalink)
I contacted the MSM dealer and told them that I wanted to change the engine mount & shafts and it seems to be smoother after the change (referred by friends). The technician agreed to change it. My car has slight gear vibration and little jerk in 2nd/3rd gear, so I am going to change it during my 3rd the service, may be in next 2 weeks.
__________________
_________________
SX4 ZXI - 2007
Old 12th May 2008, 10:06   #35 (permalink)
[quote=omishra;812225]Here are changes -
1. Engine mounts
2. Both front drive assemblies.
3. Engine Oil (Mobil1 SuperSyn)
4. Oil Filter
5. Some plastic clips under front fender.
Drive experience after change -
1. Engine vibration from standstill to motion: It improved drastically, i can see releasing clutch slowly on plan surface without acceleration doesn't produce any vibration. On uphill it is reduced by 90% (still I can feel little bit of vibration, 10% compared prior to change)<- I think this is common.
2. Uphill stop and go: This is also not having any major vibration and same as above 1.
3.Power: Certainly now if I did not press accelerator then engine is not dieing for power. It balances car with idle rpm on our buildings parking ramp without knocking. I need to floor accelerator to move ahead. On more slop I need to give little acceleration but car moves responsively.
Responsiveness of car increased.
4. Effect of Mobil1: I have to find out because initial observation about temperature, it is stable at 1/2 position. Noise and power I could not make difference in my 25 KM driving.
THIS WAS THE ACTUAL CAR SX4 -I WAS EXPECTING.
About changes - This was for certain cars, Dealer have circular mentioning chassis number. During service they are changing it.
now part lists is here -
Hello Omishra I discussed this issue with Motorcraft noida yesterday
what they said ther are not aware of such thisng and has not received any circular in this regard.
Can you pls get the details of chasis number range and circular number maruti has send.It will benefit many people.
Can you also letus l your MASS name.
amitbjha is offline   Reply With Quote
Old 13th May 2008, 10:33   #36 (permalink)
iTNerd's Avatar
Finally, my dealer is arranging a close inspection of my car with the visiting MSIL engineers on coming 15th May on the issue of clutch vibration. I am hoping they will do something to the engine mounts!
On the side note, it appears i am getting anywhere between 13-13.5 kmpl average FE for the 35 litres I drove post-drive shaft replacement under city! My odometer reads 447 kms and the fuel gauage indicator is pointing at 3rd tick! All this with full blast AC, and including numerous occasion of engine idling to use the AC in delhi's hot summer. This car does not fail to surprise me even within a year ownership.
Old 13th May 2008, 12:07   #37 (permalink)
Me too! Its sure, post drive shaft replacement I am getting 13+ in City with 100% AC. I can crawl without accelerator, just by using clutch only.
Old 13th May 2008, 12:33   #38 (permalink)
Hello Omishra
I am also facing this issue and I discussed this issue with Motorcraft noida yesterday what they said ther are not aware of such thisng and has not received any circular in this regard.
Can you also let us know your MASS name.
Old 13th May 2008, 14:25   #39 (permalink)
iTNerd's Avatar
Can't agree more.. city drive is a brisk now
Hello Omishra
Amit, with my reference, one of team-bhp SX4 owner also got his drive shaft changed at RANA motors.. You could do so too. PM me if you want the supervisor contact
Old 13th May 2008, 18:09   #40 (permalink)
Do not agree? How can you drive with 1 feet/sec speed? same time avoiding sneaking bikers in between.
Thread Tools
My Logan DLE: Updated to 15000 kms pugram Long-Term Ownership Reviews 94 14th May 2008 22:04
6000 kms road trip travelogue (Mumbai-HP-Punjab-Jammu-Raj.-Ahmedabad-Mumbai)-PART-1 Pankaj1126 Travelogues 17 2nd February 2008 17:48
Cedia Sports 6000 Kms - My experience ranjithc Long-Term Ownership Reviews 7 26th December 2007 13:23
Toyota Corolla H2 (2006) 6000+ kms report samirsarkar Long-Term Ownership Reviews 19 5th June 2007 16:34
Revvhead blabs about his Baleno - 6000 kms Revvhead Long-Term Ownership Reviews 14 26th August 2005 16:58
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
