Old 14th April 2008, 18:50   #1 (permalink)
Default My 06' vRS Ownership Experience
My First Review on my vRS , A quick Background
Bought the car in Delhi when it had clocked 14k, an Apr'06 model now at 26690kms with 80% of my usage on highways Mum/ Pune every week
and my drive from Del to Pune. (Heading back to Del end of this month and looking forward to the drive)
Misc Problems-
1.Both Radiator fans packed up at approx 20 k , was replaced under warranty, cost I am told is approx 27000 for both fans.
2.Car was not moving the way it should be, the engine felt
like a naturally aspirated one , Called N_C and we scheduled a test drive , he confimed there was a problem and asked me to get the throttle body cleaned and the fuel filter changed.Unfortunately None of the two dealers could diagnose the problem as there was no error codes showing up.
Did extensive research on briskoda on what the possible problems could be shortlisted the following most common issues
A.MAF Sensor
B.Hose leak
C.Throttle body
D.loose bolt turbo to exhaust manifold( Pete mentioned this one to me)
Problem turned out to be the throttle body , once cleaned the car was back to its old self, but what was puzzling was there was no erratic idling nor did it show up on the vag
3.Now that the summers are here the latest issue I have is with the AC , after long drives when started again after a duration
of 15 odd minutes the AC takes a good 5-7 minutes to start cooling again. I pointed this out to Acumen a week back when I was getting it serviced, but unfortunately the problem still exists - Am looking for some help here from other owners on the forum.
4 Tyres - Dunlop , need to be changed ASAP as they are extremely noisy,and the road noise only seems to be increasing as I add
miles to it. Had filled Nitrogen approx 4 months back and the advantage I found was I have only needed to top up once in the 4 month period
and it has held its pressure.
5.Rear door rattle also seems like chronic proble in most Octy's.
6.Had the Front and rear bumpers painted as I managed to scrape it quite a few times on my drive from Delhi. ( Highly recommend Avanthi Motor works for those in Pune )
Service Cost
Last service at 26450 kms
Oil Change - 3600 (shell synthetic )
Filter - 450
Fuel Filter - 450
Throttle body cleaning - 250
labour - 900
Air filter - changed to Green (stock replacement filter prior to service )
Total cost including taxes - 6400
The Positives
Have been mentioned extensively on the forum so I will skip that ,however what is worth mentioning is the fuel economy the lowest I have ever got is 7.4 kmpl and the best 12.2.
Accessories
Upgraded the ICE , to a Pioneer BT system with JBL Comps and the famous 75.4,sub , damping etc The BT is quite a boon in traffic
and works quite well.
Upgrades planned
1.Tyres in the next two months or so
2.Possible stage I remap form Pete's
Overall I am quite enjoying the experience and never once regretted buying this car.
rchimni is offline   Reply With Quote
Old 14th April 2008, 18:58   #2 (permalink)
Team-BHP Moderator
Jaggu's Avatar
Another vRS owner, kewl. I think our resident expert has been in touch with you so you dont have to worry
Hope you have ruled out the possibility of AC filter/Blower cleaning for the issue, also the gas levels.
Do keep us updated.
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 14th April 2008, 21:40   #3 (permalink)
jkdas's Avatar
Just wanted to know what you will do once the warranty is over? Keep it or sell it?
__________________
"She may not look like much, but she's got it where it counts, kid."
Old 15th April 2008, 00:52   #4 (permalink)
iraghava's Avatar
The fans ahve failed on my best friend's RS too & seem to be a problem area for sure. And it was me at the wheel when the A/C fan failed while were stuck in a traffic jam in Delhi on a hot afternoon!
As for the tyres, you want to retain stock size or upsize?
__________________
There is a very fine line between "Hobby" and "Mental Illness".
Old 15th April 2008, 01:15   #5 (permalink)
abhinav.gupta88's Avatar
Nice . I will buy a vRs soon. When did you get your brake shoes changed?
Did they wear off at 12000 km?
Do keep an eye on the AC fan as well
__________________
VTEC NHC AND RED SKODA OCTAVIA vRs (LAAL PARI)
WHY IS EVERYTHING ELSE SO SLOW !!!
-=]|Do The Dew|[=-
Old 15th April 2008, 11:29   #6 (permalink)
Brake shoes have not been changed yet , the service centre mentioned they will do it in the next service around 35 k
I have been reading about you wanting to buy a vRS for a while , I am assuming you know its been discontinued ? Unless you buy used which makes sense..
Retain stock size
Keep it for sure unless I decide to upgrade
Old 15th April 2008, 11:41   #7 (permalink)
sammyboy's Avatar
hey rchimni, great to hear that u are enjoying the RS to the fullest inspite of niggling issues (i think praneet told me about the fans failing in ur car and what a fantastic car u have). Do let us know when u pete ur car.Would be great to hear what it does to an RS.
sammyboy is offline   Reply With Quote
Old 15th April 2008, 12:10   #8 (permalink)
Team-BHP Moderator
DOn't understnd why both fans failed - sounds like a controller issue unless a faulty relay or similar burnt the fans out. Mine indicated that a service is due in a month - need to start saving!
__________________
I love the whoosh, but i miss the bellowing
Old 15th April 2008, 12:36   #9 (permalink)
Actually the larger of the two fans failed first, which I guess put additional load on the smaller fan which resulted in its failure. ( was running at half its original rpm) hence both were changed under warranty.
Old 15th April 2008, 12:52   #10 (permalink)
Super-Admin
Very unbiased straight-forward review! Thanks for sharing. I envy you for using the RS 80% of the time on the expressway and presumably, pedal to the metal on the straights and ghats alike?
Get in touch with Mad Monkey before you dive into remaps. I am sure he will be able to share some valuable tips with you.
__________________
Change the way you think, and watch the world change around you.
  • Please don't PM for support. Use the Contact Form instead.
  • Please read the *NEW* Team-BHP FAQ section for all your queries.
Old 15th April 2008, 13:06   #11 (permalink)
iraghava's Avatar
Originally Posted by rchimni View Post
Retain stock size
Options are Yokohama S-Drives & Michelin Energy MXV8's.
__________________
Old 15th April 2008, 13:22   #12 (permalink)
Thank you , will get in touch with you when I am in Delhi to guide me where to go
Absolutely ,really enjoy the drive between mum/Pune am now looking forward to my drive to Delhi !
I did touch base with him when I was experiencing the issue with the power loss will definitely discuss the remap.
Old 15th April 2008, 13:24   #13 (permalink)
Started getting a foul smell from the air-con of my RS,a few days back.
Apparently there was a puncture in the cooling coil and the refrigerant was leaking.
Had to remove the entire dash to replace the cooling coil. Now I have the ECM light on, a VAG com scan ( I have the software and cable ), shows a MAF sensor error.
It's surprising, as my car is only 3.5 year old and clocked only 18K.
On the other hand, my Mondeo was with me for 6 years and was absoutely trouble free!
ecclipse78 is offline   Reply With Quote
Old 16th April 2008, 12:24   #14 (permalink)
Ajmat , anything else you can think off, that I should be checking ? I would ideally like to get this fixed before I commence my drive to Delhi end of this month.
N_C / Monkey any pointers ?
Thread Tools
My new CVT - ownership experience trrk Long-Term Ownership Reviews 55 12th July 2008 11:39
Tucson-user / ownership experience cerk SUVs, MUVs & 4x4s 12 28th May 2008 19:01
Octavia RS - 20000kms ownership experience da MotorHead Long-Term Ownership Reviews 62 6th October 2006 14:55
Skoda Ownership experience---5600Kms sumitdongerkery Long-Term Ownership Reviews 5 4th October 2006 00:20
Aveo 1.4 ownership experience. namit Test-Drives & Initial Ownership Reports 1 13th April 2006 11:02
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
