Old 27th July 2008, 09:28   #421
kpzen's Avatar
Thanked: 1,655 Times
6j alloy for a 175 tire is a little too much...N those goodyears are tube type tires. Please change them asap.
Old 27th July 2008, 10:56   #422
undead's Avatar
Thanked: 168 Times
In certain websites it says i can go upto 6.5J . Yes , those are tube types , but the dealer said many owners drive like that and they never faced any problems. If i have to fit the tubes , i need to remove the mouth in the alloy wheels , right ? If I do that , then when changing to tubeless in the second set of tires , i need to buy new set of mouths.
undead is offline   Reply With Quote
Old 27th July 2008, 11:20   #423
kpzen's Avatar
I have driven 200kms with stock tires and i wasn't very comfortable with them.
mouth of alloy wheels?? What's that?
Old 27th July 2008, 11:23   #424
Akshay1234's Avatar
Thanked: 7,239 Times
i think maybe its the valves. tubeless and tube type have different valves?
Old 27th July 2008, 11:31   #425
undead's Avatar
Thanked: 168 Times
I dont mind if the tire wears out faster. In fact i am happy if it does , as i am eager to shift to wider tires. And do i need to lower the psi since i put alloys? i usually keep 32 psi in front and 30 psi in rear. Shall i make it 30 psi for all ? I am getting little vibrations , i feel i am keeping the air pressure a little high.
yes , i was talking about the valves .
Old 29th July 2008, 06:35   #426
undead's Avatar
Thanked: 168 Times
Pictures of my Getz with alloys.
Name:  DSC_0010 Medium.JPG
Name:  DSC_0013 Medium.JPG
Name:  DSC_0015 Medium.JPG
Name:  DSC_0028 Medium.JPG
Old 29th July 2008, 11:17   #427
djay99's Avatar
Thanked: 491 Times
Congrats vasanth. Car is looking good. Which brand alloys you bought? and for how much?
djay99 is offline   Reply With Quote
Old 29th July 2008, 13:03   #428
undead's Avatar
Thanked: 168 Times
I already gave the details few posts back
Yongle Alloys 14" 6J
Cost : Rs.15000 (5 nos)
Balancing - Rs.450
Old 29th July 2008, 22:49   #429
ph03n!x's Avatar
Thanked: 120 Times
I have this question too - what should be the tire's air pressure after upsizing? should we stick to the factory recommended, or should we experiment, say with max - 10% pressure?
ph03n!x is offline   Reply With Quote
Old 30th July 2008, 15:17   #430
@undead, the vibrations that you are getting is not due to the higher air pressure. It might be due to the improper wheel balancing.
If you are sure about your wheel balancing, then it is probably due to the hub size of the alloys being too large thus creating a gap when fitted. This can be sorted out using rings.
Naman
naman is offline   Reply With Quote
Old 30th July 2008, 16:14   #431
undead's Avatar
Thanked: 168 Times
Naman
Balancing has been done.
May be its due to the reason that i am using tubetype tires as tubeless and also that 175/65 is not recommended for 6J width
Old 2nd August 2008, 00:01   #432
Hey,
I don't think that tubeless will cause vibrations. However, not too sure about whether 175s on 6 Js will cause it or not.
As far as I'm concerned, when I changed to alloys (14x6) I used to get vibrations even after doing proper balancing. After that tire dealer suggested me to put hub rings and now the vibrations are gone. I suggest you check this thing out as well.
Btw, tires that I'm using are PPs 195/60-14. Now I just love the stability and control at high speeds. Simply enjoying the car.
Naman
Old 2nd August 2008, 06:18   #433
undead's Avatar
Thanked: 168 Times
Hey,
Naman
I am going to fit the tubes back in the tires and will ask the tire dealer about the hub rings. I have left the car at the Hyundai service as i am getting sounds from the suspension.
Old 2nd August 2008, 12:26   #434
undead's Avatar
Thanked: 168 Times
The sound from the suspension has been solved. The hyundai service men did the job very well . The sound is gone and the car is as fresh as new. They said , they removed the suspension kit and re-fitted it after applying some grease . Hey djay , hope the sound problem from your Getz is solved too
Old 2nd August 2008, 12:58   #435
djay99's Avatar
Thanked: 491 Times
I have changed Michelin PP1(195/60-14) on P&W 14" wheels to 205/50-15 Maxxis Victra on P&W 15" alloys.
Here is the pic:
Getz Prime 1.5 CRDi - Bright Silver EDIT: 74,000 kms update-26072008371.jpg
Hyundai Getz 1.3 Prime. EDIT : 81,449 kms Service Report PatienceWins Long-Term Ownership Reviews 180 26th June 2018 14:22
My Hyundai Getz Crdi - Dark Grey Metallic. Update: 50,000 kms done ShyamSCrdi Test-Drives & Initial Ownership Reports 190 6th March 2011 22:28
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
Silver Getz Prime CRDi VGT djay99 Test-Drives & Initial Ownership Reports 157 2nd April 2009 13:55
Accessories for Bright Silver Getz mangywarez Modifications & Accessories 7 26th July 2005 11:32
