Old 15th March 2010, 21:12   #751
krish3's Avatar
Thanked: 21 Times
Certainly the "No more bachelors club". In the Getz Club.. you are my senior.
I was thinking of extending the thigh support of the front seats by actually stretching it to make it similar to seats provided by Suzuki/Ford with a fair bit of underthigh support.
krish3 is offline   Reply With Quote
Old 16th March 2010, 00:38   #752
ph03n!x's Avatar
Thanked: 120 Times
Congrats for losing the bachelor's, and gaining the Master's
I am thinking why not put in some added cushioning when doing up a seat cover - isn't that possible?
And dont take the car to any service center at all without a seat cover - you WILL have dirty seats when you get the car back!
ph03n!x is offline   Reply With Quote
Old 16th March 2010, 10:19   #753
undead's Avatar
Thanked: 168 Times
Senior in Getz club and junior in "No more bachelors club" .
i thought about the same , but i am worried about whether our knee might hit the dash while driving and it may cause some disturbance. But , in that case , we can try to put an additional bush on the rear 2 bolt's of the seat to increase the seat height a bit and it will make some difference too .
oh man, Bachelor's is better than Master's in this regard.
It is possbile , u can make a cushion foam with the elastic strap ( just like in neck rest ) and fix it to the seats so that you can remove it when not needed. But , its better to paste the additional cushion foam with the original foam itself , so that it will stay intact .
I can understand that the seats may get dirty in the service centre. I will put a new seat cover after an year or two.
undead is offline   Reply With Quote
Old 16th March 2010, 10:35   #754
PatienceWins's Avatar
Thanked: 284 Times
Originally Posted by undead View Post
Its hard to imagine , how an 1 inch thickness of foam sheet can do a big difference to my comfort.
NOTE : This seat modification is based on my comfort and may not be suitable for all persons.
I understand.
I added 1" foam to the seat (bum area) and 1.5" foam to under thigh area of the drivers seat in my Getz as the under thigh support was miserable for me (I am 6' 2") tall. It has made a huge difference in terms of comfort. Earlier, it was very difficult during long drives.
I drive with the seat slidden to the farthest position. So, no problem of my knee touching the dash board.
The lumbar support is pretty fine for me.
PatienceWins is offline   Reply With Quote
Old 14th May 2010, 07:38   #755
undead's Avatar
Thanked: 168 Times
Default Service at 38000 kms
Service done at 38000kms .Following are the details
Helix Oil - Rs.989.30
Red Grease Caliper - Rs.35.55
Fuel Injector Cleaner - Rs. 200
Engine Oil Supplement - Rs.337.77
Filter Cartridge - Rs.1275.59
Filter - Air Cleaner - Rs.293.79
Oil Filter - Rs.314.28
Labour :
Clean All Wheel Brakes - Rs.230
Periodic Maintenance - Rs.615
Clean A/c Filter - Rs.40
Fix Lamp - Rs. 500 ( 3" LED lights for External Door Opener )
Total - Rs.5405/-
Old 15th May 2010, 03:02   #756
ph03n!x's Avatar
Thanked: 120 Times
Any photos for this one? What is this / what does this do?
Old 15th May 2010, 08:38   #757
undead's Avatar
Thanked: 168 Times
Just some fancy lights on the door handle just like the underbody LED lights, i will post the pictures tonight . It will look good only when taken at night.
Old 15th May 2010, 21:35   #758
krish3's Avatar
Thanked: 21 Times
thats a nice mod. Awaiting pics of that. You seem to be on a mod spree.
Old 16th May 2010, 06:27   #759
undead's Avatar
Thanked: 168 Times
Here are the lights i was talking about . I connected the wires to the power window switch and so when i switch on the Parking lights, the lights will be ON.
Taken from my Nokia N95 , these lights look better in real world than in pictures.
Getz Prime 1.5 CRDi - Bright Silver EDIT: 74,000 kms update-15052010206.jpg
Getz Prime 1.5 CRDi - Bright Silver EDIT: 74,000 kms update-15052010204.jpg
Old 16th May 2010, 09:18   #760
krish3's Avatar
Thanked: 21 Times
Super. Feeling envious. I'm yet to start splurging on the car.
Old 20th May 2010, 15:04   #761
djay99's Avatar
Thanked: 491 Times
Originally Posted by vabs78 View Post
djay,
which tires are you using ? I haven't felt much of a problem with my 205/50-15 PP2s except road noise.
Even I am thinking of changing the tires in a couple of months, they are ~25k kms old now and the tire wear is not same for all the tires. Any ideas on what could replace the PP2s?
Vaibhav,
Sorry bro i saw your post today . I think you remeber that my car was running on 195/60-14 PP1. I changed to Maxxis victra 205/50-15 after using michelins for 2K KM. Roads in bangalore have gone worse and i am not feeling good about ride quality.
Did you change you car tyre or no? If no then,
i would suggest you buy 195/55-15 Yoko S-drive if you are looking for good grip or Yoko A-Drive if you are looking for a decent grip-ride quality combination.
If you want a long life then i suggest you buy Maxxis Victra MA-Z1. Maxxis call these as sports tyres and these tyres will definitely last for 45K KM
djay99 is offline   Reply With Quote
Old 20th May 2010, 16:38   #762
ph03n!x's Avatar
Thanked: 120 Times
I am running exactly this - and am not happy at all with the in-city comfort! Every little stone /loose surface feels like its hitting my bottom straight.
But highway / smooth roads are a breeze (if you don't mind the road noise), the tires are pretty grippy. They are prone to aquaplane though.
As much as I enjoyed the speeds I was able to touch on this one, I am changing to something more comfortable next time - Nikhil was suggesting the Conti CPC2. I am also toying with getting my rims back to 14" when I get to change the tires - which would be another year or so, I think, based on the running I have done and how the tires look.
Old 20th May 2010, 16:47   #763
djay99's Avatar
Thanked: 491 Times
hey ph03n!x,
I suggested vaibhav 195/55-15 S Drives because he is happy with 205/50-15 PP2's ride quality. I am sure 55 profile's increased sidewall will give better ride than what 50 profile PP2 gives.
Can we get 14" steel wheels for getz from some tyre shop for a lower price? I did a mistake of selling it to tyre shop as i thought i would never use it. Now hyundai guys are quoting close to 2K per tyre
Old 20th May 2010, 19:06   #764
ph03n!x's Avatar
Thanked: 120 Times
Of course you can - at least that's what Deepak (Tyre Store) assured me in case I need to go back to stock for any issues / warranty claims. Will check how much he would give a set for...
Old 12th July 2010, 06:40   #765
undead's Avatar
Thanked: 168 Times
Done 43000 kms so far .
Few Days back , while travelling on the expressway , a goat happened to cross the road , i tried to avoid hitting it , but ended up hitting its face on the left side mirror and the glass got broken . The goat was fine though , it didnt feel anything and continued to walk away.
Cost of the mirror = Rs. 416 / I felt it a bit costly as few days back i went to change my friend's Figo's RHS mirror and it costed around Rs. 220 only .
Hyundai Getz 1.3 Prime. EDIT : 81,449 kms Service Report PatienceWins Long-Term Ownership Reviews 180 26th June 2018 14:22
My Hyundai Getz Crdi - Dark Grey Metallic. Update: 50,000 kms done ShyamSCrdi Test-Drives & Initial Ownership Reports 190 6th March 2011 22:28
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
Silver Getz Prime CRDi VGT djay99 Test-Drives & Initial Ownership Reports 157 2nd April 2009 13:55
Accessories for Bright Silver Getz mangywarez Modifications & Accessories 7 26th July 2005 11:32
