Old 6th December 2011, 20:28   #811
Thanked: 68 Times
Default Re: Getz Prime 1.5 CRDi - Bright Silver EDIT: 65600 kms update
Originally Posted by djay99 View Post
So i am searching for a paint shop which can remove the rust and paint it.
Try Carnation, if there is one in your city. In the south, I would recommend TVS workshops. Their painting job is on par with most OEM. And it will be definitely lighter on your pocket too.
lejhoom is offline   Reply With Quote
Old 6th December 2011, 22:26   #812
kpzen's Avatar
Thanked: 1,655 Times
Guys at Hyundai service center are suggesting me to replace both front doors. It will cost over 40K for new doors + painting + labour charges. I cannot claim insurance.
I don't feel the need for spending such an amount on replacing doors.
If you see the pics, only a small portion of door is rusted. Rest of the area is fine.
Replacing the doors for removing this rust ?! Damn these service guys are crazy
I would say you hang on for a while and then get the whole door painted.
Till then you can have some sticker work on it.
Similar rust is on my car as well, but luckily its inside the the wheel well.
Old 8th December 2011, 12:32   #813
djay99's Avatar
Thanked: 491 Times
@lejhoom and kp,
I am told that even after painting, rusting will continue and painting is not a permanent solution. Hence Hyundai service center is advising me to replace the door.
Bubbles will grow bigger even after i apply some sticker as rusting will keep on continuing. I think only option is to cut and remove rusted metal sheet area and replace it with some thing else.
djay99 is offline   Reply With Quote
Old 11th January 2012, 18:29   #814
djay99's Avatar
Thanked: 491 Times
Default Rusting issue solved
Rusting issue on my getz's doors has been finally solved
If you go through the images i posted earlier, bubbles were formed on the outside door's surface. I spoke to a local painter and asked him to remove the bubbles (he used a sharp piece of sheet) and then rub using a sand paper. He did it for quite some time and then we saw that whole rust was removed.
We saw shining steel sheet. Painter applied a thick coat of zinc primer and allowed to dry for a day. Next day he painted a portion of door. He did this for both front doors.
I am very happy that only a small portion of door was rusted. Had rust been deeper, i might had to replace whole door (as per SVC) which is very expensive.
I also got rear bumper and a couple of other area painted which had big dents.
I am planning to go for a paint treatment including polishing. Any suggestions?
3M does a full paint treatment job for around 3K. They said they will remove swirls and small scratches. Is it worth the money?
Old 6th April 2012, 18:46   #815
djay99's Avatar
Thanked: 491 Times
My getz battery died yesterday. Car started morning showing no signs of issues with battery. Evening i crank and i hear some strange noise from starter motor and no crank. Called up hyundai service and they said they will attend my car today and quoted 10K for a new battery. I was shocked to hear such figure for a hatch.
Visited an exide dealer close to my residence and he quoted 9.2K for Exide Matrix which is sealed for life with 5 years warranty. After exchange of old batter, paid 8.2K.
How is it possible that a battery die without showing any signs of aging?
Old 9th April 2012, 09:25   #816
undead's Avatar
Thanked: 168 Times
You could have asked before buying a battery. Why buy exide. its always costly. You could have followed by thread . I bought the tata green batteries for less than Rs.4500.
undead is offline   Reply With Quote
Old 11th April 2012, 11:55   #817
djay99's Avatar
Thanked: 491 Times
I checked your post after buying exide . I know its expensive but i was to travel next day. Hence opted for it. Will keep a close eye on your thread going forward
Old 11th April 2012, 12:37   #818
undead's Avatar
Thanked: 168 Times
Ok. For my next service, i m planning to do it outside service centre . Parts can be sourced from outside. Will be doing the service this month
Old 2nd June 2012, 11:48   #819
undead's Avatar
Thanked: 168 Times
Default 74000 km service.
Service done at 74000 kms. Vehicle hasnt run much for the past few months. Almost 8 months after the previous service was done.
Helix Oil - Rs1157.20
Red Grease Caliper - Rs 36.47
Diesel Filter - Rs.1405
Air Filter - Rs.172.16
Oil Filter - Rs.357.54
Total Service including labour , VAT , ST etc came to Rs.4634
Things to done soon:
1. Timing chain might be changed around 1lac km mark
2. Clutch overhaul around 1lac km mark
Happy with this vehicle. The acceleration is still making me smile.
Old 13th December 2012, 19:43   #820
undead's Avatar
Thanked: 168 Times
Default Re: Getz Prime 1.5 CRDi - Bright Silver EDIT: 74,000 kms update
My Little Monster has been Sold and will leave the Garage. Will be replaced by i10 1.2 Magna Sleek Silver.
Will miss it.
Old 13th December 2012, 22:23   #821
sagarpadaki's Avatar
Thanked: 1,337 Times
Will miss it.
Only one question. Why?
I don't think an I10 Will fill into the shoes of the monster
Old 14th December 2012, 07:26   #822
undead's Avatar
Thanked: 168 Times
True. Cant find a perfect replacement for my getz. But planned to change it in 2 to 3 months. Enjoyed the power of it ,but felt i should slow down a bit . Parts are slightly becoming a problem now as per other getz thread.Put an ad on tbhp for sale and buy a brio,but ended up exhanging with hyundai itself as december discounts were good.
Old 24th January 2013, 21:06   #823
ph03n!x's Avatar
Thanked: 120 Times
ouch! Ouch! OUCH!!! Come on man! The Rocket is for keeps, you couldn't have sold it :(
Oh well, you have the Rocket Sr. around, but still - the Getz D is indeed THE pocket rocket! And there is no problem in parts availability - of course I am not talking about HASS, I have been servicing outside for the past 30k KM now...
Anyways, now that the deed is done, am sure the Getz D would give you a smile whenever you think of it - Will catch up in mine if/ when I drive by your place
ph03n!x is offline   Reply With Quote
Hyundai Getz 1.3 Prime. EDIT : 81,449 kms Service Report PatienceWins Long-Term Ownership Reviews 181 19th July 2018 23:14
My Hyundai Getz Crdi - Dark Grey Metallic. Update: 50,000 kms done ShyamSCrdi Test-Drives & Initial Ownership Reports 190 6th March 2011 22:28
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
Silver Getz Prime CRDi VGT djay99 Test-Drives & Initial Ownership Reports 157 2nd April 2009 13:55
Accessories for Bright Silver Getz mangywarez Modifications & Accessories 7 26th July 2005 11:32
