Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Long-Term Ownership Reviews
Thread Tools
Old 29th November 2007, 11:11   #76 (permalink)
Yes, I don't remember having changed the alternator till now. The only OEs changed are battery and tyre sets.
How much does a new alternator cost?
CaAT is offline   Reply With Quote
Old 29th November 2007, 11:52   #77 (permalink)
Team-BHP Moderator
tsk1979's Avatar
8500 Rs.
you can get the alternator opened and see the repair costs, if they cross 3000rs, go for a new one.
Please go to your regular mechanic and not the TASC.
__________________
Reclaiming.....!
Old 29th November 2007, 20:36   #78 (permalink)
nitrous's Avatar
Good reporting, tanveer.
Originally Posted by tsk
If tomorrow I open an automobile industry and make a car, I will try to have as few Lucas TVS parts as possible. I hear that Tata is replacing many of these Lucas TVS parts with made in china parts. Well good for them. They should replace all the Lucas TVS parts with made in china ones
Its embarassing for me since I live 3kms from the main plant and they're popular in the local circle for their good "quality".
1 lakh mark means timing belt change, but thats a story in the future.
Id suggest U dont wait for the 1 lakh mark and do it ASAP. It'd cost just a few hundred and is total VFM for the peace of mind it gives for the next 40K kms. Trust me.
This time I put in Shell super diesel 15W50, instead of 15W40. Its API-CG grade.
Why did U shift from the API-CI4 grade GTX diesel?
And what brand of filter do u use?
__________________
The Road less travelled, is less travelled for a reason
Old 29th November 2007, 21:17   #79 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Yup, next service at 93K, new timing belt will come in. Infact maybe much before. Around 90K only before end of dec
As for the change of grade, I thought I will put in 15W50 instead of 15W40. This means better high temp protection. I know its winters and all, but the minimum temparature never goes below5 degrees, and I always idle before starting out in morning.
However on long drives the temp needle is mostly at middle mark and 15W50 gives better protection to a hot engine.
Moreover this car requires APi-CD. So CI or CG is not going to make that much of a difference for this one!
__________________
Reclaiming.....!
Old 29th November 2007, 22:18   #80 (permalink)
nitrous's Avatar
OT:
Originally Posted by CAAT
The problem is with alternator overcharging. The battery gets charged upto 16 Volts sometimes
Most probably, your alternator regulator needs replacement.
__________________
Old 30th November 2007, 10:23   #81 (permalink)
You are right Nitrous, and I did replace the regulator yesterday evening.
Went to Lucas distributor - Abhisudan Agencies - on Karve Road, Pune. Upon opening the alternator they gave me an estimate of Rs 5,850.00 and informed that bearings (two Nos.), rectifier, coil, regulator and oil seals need replacement. I put my foot down and asked them to replace the regulator only. Having been a transformer manufacturer, early in my career, helped, as I told him that coil looks in perfect condition. The rectifier normally does not go wrong unless the alternator really 'blows off'. So it finally trickled down to regulator seal and bearings. With some generous greasing(I paid him 50 bucks extra), bearings were fine too and so only oils seals and regulator were changed. Ofcourse they cleaned the coils and other parts of alternators throroughly and right before me too.
A word of caution for Indica and Indigo owners:
As soon as you see a sudden increase in the blower speed or in the intensity of head lights or if the temperature needle crosses the mid mark, please get your regulator replaced. For, any delay will lead to alternator coil damage and eventually, alternator and battery malfunction. Another way of detecting alternator 'over-charge' is that the battery starts bulging from its sides.
Also, fyi, the charges for alternator spares (in Pune) are:
1) Bearing (Small) : 250.00
2) Bearing (Large) : 1450.00
3) Alternator Coil : 1700.00
4) Rectifier : 1200.00
5) Regulator : 650.00
6) Oil seals : 250.00
7) Labour Charges : 300.00 to 350.00
If you leave your car for alternator repairs with TASS, chances are that you won't get to have a look at the alternator coil or bearings. (They send it to TVS Lucas distributor anyways). Try to get the job done from Lucas distributor. Insist on being present when the job is being done. Have alook at the coil. If it is pitch red, there is no need to change it. If the insulation from the copper wire has come off, then look for black marks (which indicate burning/insulation failure). Another way is to smell the coil for carbon. As for bearings, rotate them and look for any untoward noise. Ask the service guy to grease it and rotate again. More often than not, bearings, coil and rectifiers are in good shape.
As an aside, I checked with the owner, during a casual talk and he informed me that alternator works fine for 5/6 years (with a average running of 1k/year) for Indica. For Maruti vehicles (read petrol) he said they don't have to service/replace it for 8/9 years with mileage same as above. Maruti owners please confrm.
Sorry for a long post.
Old 30th November 2007, 11:20   #82 (permalink)
rkbharat's Avatar
even in my 90K KM Indica, its still original alternator. Voltage is perfectly fine.
12.6 with engine off.
14.1 at idle, no electrical.
12.9 at idle with AC
12.6 at idle with AC and headlights.
13.1 at idle with AC and headlights and little rev.
I am planning to get the timing belt replaced.
your car still has the original alternator? I think the regulator has gone.
__________________
Cheers.....Rajiv
SX4-ZXi, May 2008, 1500KM, FE City 10.5-12, 100% AC
Maruti 800, 1999, 7800 KM, 19KM/L
Indica V2, Sold at 97234KM
rkbharat is online now   Reply With Quote
Old 22nd March 2008, 16:12   #83 (permalink)
super report!
Good job Tsk.
Read whole thread after spending 25minutes
Now i knew what should i expect from indica
Good work.
Does current model of Indica( DLG0 also suffer from this alternator & voltage problems?
gary4gar is offline   Reply With Quote
Old 23rd March 2008, 20:24   #84 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Originally Posted by gary4gar View Post
super report!
Good job Tsk.
Good work.
Not so much as the older ones, but still electrical troubles can crop up sometimes.
__________________
Reclaiming.....!
Old 16th April 2008, 13:39   #85 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Default 100000 kms update
On the 15th of April, the car completed 100000kms near karnal.
The past 12000kms have been very very hectic, with trips to shoja and Rohru/chansal Pass. These 12000kms were covered in less than 4 months. 3 months and 20 days to be more specific.
The car has behaved great, with just one problem which can be blamed on Tata.
There have been other problems, related to the great highways which are more of obstacle courses than roads.
89000kms
Got the timing belt changed. Tata recommends 100000kms, but I thought why take chances, it cost 1375rs inclusive of labor.
91400kms.
As small mishap with road caving in cause a bent tie rod and busted ball joints. Got them replaced, and also changed the power steering fluid and hose as a related change
Total cost 1690
93550kms
Did regular service and also changed the crossmember which had gotten bent due to hitting rocks on the road at night.
Total cost 1315, inclusive if 4L oil, Oil filter, Diesel filter set(Delphi)
94100kms
The electrical ghost strikes again. The glow plug timer has gone bust. Local part costs 250 and Tata original costs 1700(approx). Got it with great difficulty from Sec 16 noida market because most shopkeepers stock "local"
Total Cost 1850
98700kms
The most recent service. Total cost of Oil and Oil filter and labor = 870
The Odo reads 10200kms now.
I have been tracking all the expenses on this car inclusive of Repairs and Fuel since 81868kms on 1/07/2007
Total Kms : 17955
Total Fuel Liters/Cost : 1268/39288
Repair cost/km : 1.37 (Inclusive of service, wheel alignment etc.,)
Fuel cost/km : 2.19
Total cost/km : 3.55
Thankfully this period has been relatively free of electrical problems, with most issues being related to tie rods and cross members hitting rocks on roads etc.,
The car is still doing fine on Original clutch plate, and the G.box has never been opened. While on the very steep incline to chansal pass full of melting snow there was mild clutch judder. While going to shimla got struck in an uphill traffic jam where the car overheated a little bit(got to know due to AC cutting out). Will have to get radiator flushed, or maybe its a thermostat issue, since there was no power loss, and the engine oil is fine and the temp marker goes just slightly above the middle mark.
As of now vibrations have increased due to a speed breaker hit near Narkanda, and it appears either the crossmember is touching the exhaust or the engine mounts need replacement. Past 3-4 days has seen multiple underbody hits(esp while going to Chasal Pass). Nothing is leaking or broken, but alignment/balancing are definitely out of place. One rim is also slightly bent.
Thats all folks, Many miles to go, and many miles gone
__________________
Reclaiming.....!
Old 16th April 2008, 14:14   #86 (permalink)
Great to see that your car has completed 100000 kms with very little problems. My wife's sister is also looking for an upgrade, and I did suggest Indigo or Logan. However, she has not purchased anything yet.
__________________
For one who sees Me in all beings and sees all beings in Me, I am never lost, nor is he ever lost to Me.
vasudeva is offline   Reply With Quote
Old 16th April 2008, 15:02   #87 (permalink)
hmm, congrats. and the apollos still look like they have a decent grip!
__________________
My dream: An india where even a CD100 runs HID to teach insensitive full-HID dudes that HIDs are a zero sum game.
phamilyman is online now   Reply With Quote
Old 16th April 2008, 16:15   #88 (permalink)
svsantosh's Avatar
Tanveer, I think the 5th Pic sums it up... You have been through hell and high water and many a storm in a tea cup, Your ride still Lives to See another Day. Superb writing and even more superb reason to still trust that Ratan's Dream is after all not so 'UN'reliable.
(PS - are these old pics, I remember reading somewhere in 07' you changing the plates from my bengalooroo to delhi?)
__________________
Dont wear Helmets & Seatbelts to reach Heaven Faster
You hardly have any time left in this world to be a sinner
svsantosh is offline   Reply With Quote
Old 16th April 2008, 16:23   #89 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Nope, these pics are very very recent.
I am not planning to change the plates to DL or UP.
__________________
Reclaiming.....!
Old 16th April 2008, 16:46   #90 (permalink)
adityamunshi's Avatar
tanveer, any preventive maintenance on the radiator/cooling system ? Most Indicas have overheating probs around 100K.
__________________
And Michael Schumacher is actually in a very good position to win the race. He is in last place. - Murray Walker
adityamunshi is online now   Reply With Quote
Thread Tools
Indica DLS 2002 - 88000KM Report rkbharat Long-Term Ownership Reviews 13 21st April 2008 16:12
Old Indica LEi / New Indica DLS / New Alto LXi shuvc Hatchbacks 20 19th February 2008 16:31
Indica DLS / DLS TURBO / DICOR?.....What BUY? musicmanaman Hatchbacks 18 11th August 2007 19:38
Indica NA DLS vs Turbo DLS vs Turbo DLG greenhorn Hatchbacks 10 5th May 2007 17:20
TATA Indica V2 DLS 107000km Report .anshuman Long-Term Ownership Reviews 16 27th February 2006 20:38
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
