Closed Thread
Old 3rd September 2008, 16:20   #256
nitrous's Avatar
Thanked: 282 Times
4) MAJOR UNDERSTEER problem at speeds above 110... nearly got killed 3 times
Reason:
a)Suspension setup
b)tyres
solution: Limit your speeds at corners and always enter slow.
About the oil@Rs.203 ,Oil prices HAVE shot up.
I've been noticing the trend for quite a while.
Moreover, this is where service centres make money .They purchase oil in 210 litre barrels at very special wholesale rates and charge customers 10% more than retail.
I recently paid Rs. 1600 for a 7.5 litre can of Mobil Delvac MX (API-CI4-as good as it gets in India) which works out to around as much as you have paid(per litre).But, you can't carry your can of oil to the service centre and ask them for a change. You will have warranty issues.
Finally, stick to one service centre and one service manager/advisor.
nitrous is offline
Old 3rd September 2008, 17:09   #257
svsantosh's Avatar
Thanked: 1,389 Times
Originally Posted by alpha_romeo View Post
It might be worth waiting for FIAT multijet engine on CS.
yeah, but nope - the monocoque in the vista is space age compared to CS, either the engine will vibrate itself to death, or the chassis could Implode under the exrteme torque...
Originally Posted by hrag View Post
Remember seeing a rate close to 200 per litre for engine oil. I think they use only Castrol.
true... i am still checking.
Originally Posted by trrk View Post
I was charged 550 for my Honda for wheel balancing and alignment. I said yes when asked without thinking. I don't do tyre rotation.
then its ok then...
Originally Posted by nitrous View Post
solution: Limit your speeds at corners and always enter slow..
yep > i was overspeeding in a wrong car, but learnt MANY valuable lessons
Moreover, this is where service centres make money .They purchase oil in 210 litre barrels at very special ....
yep, same as edible oil trend i guess, then its ok with me.
svsantosh is offline
Old 3rd September 2008, 19:13   #258
trrk's Avatar
Thanked: 12 Times
Hi Santosh,
> then its ok then...
I usually never do the alignment / balancing at the service centre unless some suspension work necessitates the checks. It was a mistake in the Honda service. There were absolutely no need for those.
It is definitely cheaper outside. If you have the time, you could try somewhere outside for these jobs.
As a personal policy, I don't do tyre rotations.
trrk is offline
Old 3rd September 2008, 21:49   #259
svsantosh's Avatar
would that not be a good idea so that when the time comes, you need to buy only 3 new tyres instead of 4/5 and then use one of the earlier sets as a spare?
Old 4th September 2008, 12:15   #260
trrk's Avatar
Thanked: 12 Times
Hi Santosh,
> buy only 3 new tyres instead of 4/5 and then use one of the earlier sets as a > spare?
For cars with relatively higher mileage can try this. Without the roatation, the front tyres are good for around 40000 kms or more. So buy one of the same make and join it with the stepney to form a pair and use the better of the front as stepney.
The rear should easily last for another 30000kms. So the next change would be 2 for the rear.
Theoretically it should space out your tyre expenses.
In my earlier Indica, one rear tyre was the OEM tyre at 65000kms with more tread to be used.
unfortunately, the roads do not allow me to test out this theory properly, by damaging a tyre and spoiling the sequence.
For eg. My Marina front tyres lasted for only 35000kms (Apollo Aceleres). But at 12220kms on the odo, my right rear tyre developed a bubble, warranty was not honoured by Apollo, so shifted that one to the stepney with a tube and put the stepney to the right rear. So my right rear tyre has run 12220kms less than my left. I expect the left to last for another 10000kms.
So the sequence that I have described may not work out this time with the Marina.
trrk is offline
Old 8th September 2008, 20:21   #261
svsantosh's Avatar
Talking Another weekend, another road trip - Blore - Kollam (Kerala)
Another weekend, this time to Club Mahindra,Ashtamudi (kollam) Kerala.
Major Statistics as follows...
Total Trip - 1375Kms
FE - 18-21 KMPL (Thx to Rajesh's advise of keeping and slow and steady)
Oh... AC Through out day and night, never switched off the entire 1375 kms.
Max speed - 90, (mostly 70-80 while driving)
Roads are Ok from Blore - Coimbatore and Palakad. From Palakad to Thrissur is more than a nightmare. Car ATE 4-5 Potholes, thankfully no major damage done, thx to low speeds maintained.
Rest of the roads are a breeze to drive by. Kerala roads are hectic to drive during day times, got bogged down entire trip back to blore.
Attached some pics, please enjoy...
(PS - Rajesh, thx for the breakfast treat, i loved it)
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1487.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1488.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1491.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1517.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1520.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1522.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1545.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1552.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1555.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1560.jpg
Old 8th September 2008, 20:24   #262
svsantosh's Avatar
some more pics... i loved the orange one... couldnt get down from 'neendakara bridge' in evening rush hour to get a better shot...
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1564.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1580.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1582.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1597.jpg
Indigo CS TDI - 40,000Kms done. Edit: SOLD-imgp1636.jpg
Old 8th September 2008, 20:27   #263
svsantosh's Avatar
Oh... almost forgot, Mods, can you please update title to 10,000Kms , yep, today is the 3rd month aniversary... god knows whats the ODO gonna show in 1 year!!
Old 10th September 2008, 20:18   #264
Thanked: 7 Times
Oh Man, Santhosh! I want to relax in this lovely place. Good to know about the FE figures with always A/C.
TeddyBear is offline
Old 22nd September 2008, 10:19   #265
svsantosh's Avatar
...Update...
Dashboard digi clock and reverse gear (white) light fuses blew for no reason. They both stopped working simeltaneously. Will update in a few days after I get time to fix them.
Old 22nd September 2008, 13:10   #266
trrk's Avatar
Thanked: 12 Times
Hi svsantosh,
> Dashboard digi clock and reverse gear (white) light fuses blew for no reason. > They both stopped working simeltaneously.
Yahoo! Groups
8th from left as you look at htem. It is a 20A fuse that works the clock, reverse lamps and the mobile charger (cigarette lighter).
This is based on the Marina fuse positions. I am sure it would be common to the models.
You could have spares in the fuse box itself.
trrk is offline
Old 22nd September 2008, 20:33   #267
svsantosh's Avatar
WOW - Rajesh YOU ARE GREAT.
I did not mention the 'incident' that started this. I got a new lighter (car), poped it in, did not work, and then noticed all this problem. That lighter is going back to where it came from!!
Old 23rd September 2008, 12:24   #268
Autocop's Avatar
Thanked: 89 Times
Santosh, Lovely pics. Nice to know you having long drives and fun with your car. Enjoy!
Autocop is offline
Old 23rd September 2008, 12:38   #269
mjothi's Avatar
Thanked: 216 Times
Man, what are you up to? 10K in 3 months. You have did justice to the Diesel engine
mjothi is offline
Old 23rd September 2008, 12:51   #270
trrk's Avatar
Thanked: 12 Times
Hi Santosh,
I'll accept the compliment on behalf of the Yahoo Indica User Group which has been a great source of knowledge and inspiration to pass on what one knows to help others.
That piece definitely has no place in your car.
The Marina is the 4th car from the Tata stable with me.
trrk is offline
Closed Thread
Dark Knight has arrived! VW Vento TDi Highline. EDIT: 5th Service done el lobo 6061 Test-Drives & Initial Ownership Reports 244 15th October 2016 12:39
VW Polo TDI Highline : Multiple Breakdowns & Replacements. EDIT : Now Sold! shashank.nk Test-Drives & Initial Ownership Reports 83 15th September 2015 16:11
My new 2.0L CR TDi Jetta Comfortline - 30,000kms *UPDATE* deepakchan Test-Drives & Initial Ownership Reports 138 21st June 2013 16:08
Figo TDCi EXi vs Indigo CS LX TDi. Update: Its the Indigo. vivekgk What Car? 32 22nd November 2010 21:59
