Old 29th May 2008, 01:48   #16
Thanked: 1,059 Times
Neat and precise write up Sushanth!! Loved reading every bit of it. And yes Palio is a very good cruiser and a great handler when compared to other hatches. Enjoy your car and drive safe!!
abhinav.s is offline   Reply With Quote
Old 29th May 2008, 18:44   #17
Thanked: 111 Times
I have a Palio 1.2 ELX which just came back from the garage after some denting & painting work. I noticed the headlight alignment has gone for a toss & the high beam, which originally used to light up the road is lowered. The levelling unit is set on "0". Can anyone suggest me good powerful lights for the Pali 1.2 that wouldn't cost a lot?
I need a good spread on low beam & decent far illumination for high beam.
mb_jg is offline   Reply With Quote
Old 29th May 2008, 18:47   #18
Smile
I suppose, you could post your query in this thread, which is meant for the purpose. http://www.team-bhp.com/forum/modifi...pics-here.html (Palio mods/post all queries and pics here)
cheers:
eclectix 1st is offline   Reply With Quote
Old 30th May 2008, 21:57   #19
Thanked: 13 Times
very well written... I have purchases my palio around the same time and it has covered almost same milage.. now i am being 'inspired' to write my review (though it will be almost same as this one)
kanwal is online now   Reply With Quote
Old 9th July 2008, 11:56   #20
sushanthr77's Avatar
Guys, I recently changed my wipers to Bosh. My observations are mentioned below:
01. The rubber material is better than the stock blade material.
02. Requires slightly more water on windshield than the stock ones to operate without any squeaking noise.
03. Cleans slightly better than the stock ones.
04. Not a big upgrade from the stock ones.
I was looking out for replacement for my rear wiper blades as well. They create a real bad squeaking noise when operated. I only found it in a brand called "Standard" which I think is the OEM. So I opted not to replace it.
I've retained my old ones just in case I feel like switching back.
Cost: 350/- (approx)
Service Center: Green Tracks
sushanthr77 is offline   Reply With Quote
Old 9th July 2008, 12:26   #21
Default Upgrade of bulbs
Guys,
I had posted my query related to upgrade of lights here:
http://www.team-bhp.com/forum/885749-post1852.html
Thanks for all the replies and they were really helpful.
Last week I finally upgraded the bulbs. More info below:
01.
Narva - H7 - 100W - 2 Nos - 500 INR approx
02. Narva - H1 - 80W - 2 Nos - 250 INR approx
03. Standard - Relay / Wiring / Fuse / Metallic Clips - 450 INR approx
Total Cost: 1600 INR (including labor cost: 350 INR)
Time consumed: 1 hr with focusing.
My impressions on the setup:
(+ ves)
01. Low beam is very good. Good spread and throw.
02. High beam is also very good. Good spread and throw.
03. The color of both the beams are excellent. They are neither tube light white nor blue. They produce the color of the stock bulbs but only brighter. The color is more biased towards white than yellow.
04. Low beams are fantastic for city driving.
05. So far I haven't felt any excessive heating.
06. Palio has a low beam obstruction built-in in the head lamp assembly. This cover eliminates any necessity for the external black stickers on the surface of the assembly.
07. Since Palio has separate bulbs for both high and low beams, they can operate simultaneously and hence produce better light. This also helps in designing the internal reflectors for specific purposes. The low beam reflectors are more designed for spread and the high beam for throw.
(- ves)
01. People could confuse your lower beams to high beams.
02. The Relay / Fuse are exposed to moisture. I am sure I need to find a cover for them or else they'll get destroyed during a wash.
03. Life of these bulbs are still uncertain.
04. Focusing becomes can become a major issue with higer intensity bulbs. This is simplly because the effects are simply more prominent / amplified.
Now the question: Would it force the trucker / taxi drivers at night to siwtch to lowe beams? Hmmm...Not sure! I am yet to find out.
Is the upgrade worth: Oh yes!
500Km with a Tubeless Tyre puncture - Had no Clue! d_himan Tyre & Alloy wheel Section 31 8th October 2013 17:44
Fiat Linea - Diesel 500KM - 31st MAR emailbhatia Test-Drives & Initial Ownership Reports 22 15th October 2010 15:23
Honda Civic 1.8V A/T. EDIT : 9 months / 8,500KM up! ImmortalZ Long-Term Ownership Reviews 139 9th September 2009 13:51
Chennai-Thalaivasal-Chennai:500km:One day trip.. Ford_madhan Travelogues 2 3rd December 2007 20:37
Maruti 800AC, 17,500km review GeekSrik Long-Term Ownership Reviews 9 3rd June 2007 09:27
