Closed Thread
Old 2nd February 2010, 12:23   #241
I was not told anything about NOT using the micro hybrid till 1K Kms.
My Micro-Hybrid works. But it works intermittently. i.e. it will work sometimes and sometimes it wont. When it doesn't I switch off the engine, switch off Micro-hybrid and then switch-on micro-hybrid, switch-on engine and then it starts working again. I think there is some nasty algorithm attached to its working (complicated than what is mentioned in the manual).
tanmay_ambre is offline
Old 2nd February 2010, 12:33   #242
I have another question. I bought a new D. White Scorpio on 22-Jan-2010. This is my first diesel vehicle. My question is regarding the procedure of starting the car. Do you have to keep the clutch pedal depressed (even though the gear lever is in neutral position) while starting the car? or is it ok to start the vehicle without depressing the clutch pedal?
reason I ask this is because, when I went for a test drive, I tried to start the car, but it wouldn't (it would just fire up the engine for a fraction of a second and stop again. Its not the micro hybrid) unless you press the clutch pedal. hence the question.
Old 2nd February 2010, 14:47   #243
raj_5004's Avatar
Thanked: 2,031 Times
hi tanmay, its always a good practice to press the clutch (even if the gear is in neutral) before starting the car. it frees the starter motor of all the electrical loads & thus increases its life.
raj_5004 is offline
Old 2nd February 2010, 20:21   #244
anjan_c2007's Avatar
Thanked: 4,703 Times
My car went for the 30,000 kms service a week back & total charges were Rs. 1500/-.
The single & persistent issue i had with the vehicle was the driver door squeaking noise. since this time it was the 5th time i was complaining (!!!) & also since i had sent a mail to the customer care regarding this issue, the SA personally came to check the issue & advised the technician to change all the bolts of the door with new ones.
that done, the noise disappeared but only for a week. the noise is back again & i am clueless now! it useless going back to global gallarie so i am thinking of going to some new A.S.S, anyone here knows which is a better mahindra A.S.S in mumbai?
What about the rattling door Raj? Could you go to another A.S.S. to get that job done to your satisfaction?
anjan_c2007 is offline
Old 2nd February 2010, 20:47   #245
raj_5004's Avatar
the rattling, infact squeaking noise is still present as it has not been shown to any A.S.S thereafter since i was out of town for half a month.
raj_5004 is offline
Old 3rd February 2010, 11:02   #246
by the way, even in my brand new scorpio (2010 edition), the co-driver seat squeaks. The thing is, if someone is sitting on it, then only it squeaks. But when its empty, it doesn't squeak.
btw Raj, I was wondering if a simple solution like greasing the nuts and bolts and joints would help?
Old 3rd February 2010, 13:08   #247
MileCruncher's Avatar
Thanked: 356 Times
I understand HVK also goes to Global Galleries and is totally disgusted with their service. So you might be better off looking for another A.S.S
MileCruncher is offline
Old 3rd February 2010, 13:53   #248
suman's Avatar
Thanked: 257 Times
No point stressing yourself over a squeak, just buy a can of WD40 & spray on the offending area. Keep it in the car for repeated application.
suman is offline
Old 3rd February 2010, 18:18   #249
raj_5004's Avatar
i have not tried that as of yet. i am disgusted that the A.S.S cannot solve such a simple issue.
yes, and i will be doing just that now, global gallarie is useless.
i have tried that, but in vain! i have found another simple solution, turn the music volume up!
raj_5004 is offline
Old 7th February 2010, 11:20   #250
Ranga's Avatar
Thanked: 41 Times
Micro Hyrbid is now working in my car .
The only problem is that it swtiches of the AC and does a complete engine restart which means the audio system also restarts ....
Ranga is offline
Old 7th February 2010, 12:22   #251
Thanked: 356 Times
@RAJ & other microhybrid owners: what are the implications on Turbo and on the compressor of this regular unscheduled abrupt shut down.
Old 7th February 2010, 16:02   #252
raj_5004's Avatar
@ milecruncher: mine is not the refresh scorpio & hence is not a micro hybrid!
raj_5004 is offline
Old 10th February 2010, 13:36   #253
raj_5004's Avatar
My scorpio had a unscheduled visit to the A.S.S. yesterday.
Issues were:
1) a strange noise from the AC blower, something like a grinding noise
2) squeaking noise from the front 2 doors
3) handbrake had become loose with use
4) rear "VLX" badge was broken
Result:
1) the AC noise was because many leaves got sucked into the AC blower & that was making the noise. my car is parked under a tree which showers its blessings on my scorpio every morning. however, as a goodwill gesture, mahindra has replaced the blower free of charge & also without any labour charge. though it was advised to us that mahindra is not entitled to replace the blower under warranty under such circumstances.
2) the door noise is solved as for now. but i am not sure when it will re-appear again.
3) the handbrake has been tightened & is fine now.
4) a new VLX badge was pasted.
Charges:
1) VLX badge: Rs. 64/-
2) WD 40: Rs. 72/- (@ suman: you had advised WD 40, here it is!!!)
Labour charges:
1) AC filter clean: Rs. 60/-
2) Brake adjust: Rs. 380/- (i think this is on the higher side)
Total: Rs. 639/-
The nice part is that they have stopped charging me for car wash & also cotton waste was not charged this time!
i am happy this time!
raj_5004 is offline
Old 10th February 2010, 23:00   #254
Raj Now thats a bill which beats the inflationary trend. Even for my Activa I have once paid something above Rs 800/- but imagine a Scorpio emerging out of the A.S.S. with a Rs 639/- bill that has perhaps solved its four problems!
Old 11th February 2010, 10:18   #255
raj_5004's Avatar
Lol, very true anjan. the only saving grace with mahindra's poor A.S.S is its low cost of spares & service.
raj_5004 is offline
Closed Thread
Scorpio VLX mhawk 4WD with Air Bags EDIT - 43000 kms update 4x4addict Long-Term Ownership Reviews 110 11th April 2013 16:16
Scorpio mHawk VLX Airbag - Initial OwnerShip Review abacusv Test-Drives & Initial Ownership Reports 38 16th January 2012 08:48
3 months 10K kms Mahindra Scorpio VLX mHawk pramods Long-Term Ownership Reviews 103 9th December 2009 11:48
Old Scorpio Mhawk>>> New Scorpio Mhawk rishin.kalra SUVs, MUVs & 4x4s 9 21st July 2009 15:51
