Closed Thread
Old 27th April 2010, 21:11   #271
raj_5004's Avatar
Thanked: 2,064 Times
on the highways, 100-130 kmph, i mean the mumbai-pune express highway.
raj_5004 is offline
Old 27th April 2010, 21:48   #272
Thanked: 253 Times
Raj, these speeds will not give 12kmpl average, particularly with AC on!
Are you sure this is what you get?
Measurement log please?
anupmathur is offline
Old 27th April 2010, 22:22   #273
raj_5004's Avatar
yes anup saab, 99% of my highway running means mumbai-pune trips.
it includes a 20km drive from my residence to the express highway. i start early morning, that means no traffic. once the highway is entered, i set the cruise control at about 110-120 kmph & relax.
sorry, i dont keep a log book for this but i do get around 12kmpl. also, i have mentioned in another thread somewhere that once i had got 15.5kmpl when i set the cruise control at 70kmph!
another mHawk owner 'getsurya' also had posted some nice figures long back.
the mHawk usually gives 1kmpl more than the CRDe in similar conditions.
raj_5004 is offline
Old 28th April 2010, 12:20   #274
rrsteer's Avatar
Thanked: 937 Times
I can concur our Scorpio (m-hawk) usually returns slightly above 12kmpl in highway condition with 100% AC. The speeds kept are 85-100 kmph
rrsteer is offline
Old 28th April 2010, 20:35   #275
raj_5004's Avatar
yes, maybe if speeds are kept below 100 kmph, it may return more than 12kmpl.
raj_5004 is offline
Old 28th April 2010, 20:55   #276
SS-Traveller's Avatar
Thanked: 11,626 Times
Originally Posted by unoczar View Post
please tell me the FE you are getting now.. on your scorpio...
Here's my FE figures from the other thread (What is your Actual Fuel Efficiency?):
Scorpio mHawk VLX 4WD 2009: FE figures since the beginning (15 Oct 09 - completed 8900 km now) are:
Best: 13.68 km/l; Worst 10.63 km/l (the first tankful when brand new); average: 12.78 km/l. Fuel used: Normal diesel. System-D used occasionally @ 0.5 ml/litre, when FE appears to drop below 12 km/l. AC usage: 20% of total drive.
With the advent of summer, the AC is always on, and Delhi/NCR temperatures have been crossing 40*C regularly. FE went down a bit, and the best FE for April was 12.74 km/l; the worst was 11.49 km/l. The odo reads 11,7xx km now.
Hope this helps.
SS-Traveller is offline
Old 28th April 2010, 21:58   #277
Thanked: 253 Times
Isn't that what I had protested about?!
12 kmpl average with speeds of 120 kmph!!
Even my 2.6 CRDe gives me 12 kmpl if I do highway speeds under 100 kmph!
Old 29th April 2010, 17:52   #278
raj_5004's Avatar
Anup saab, what i said was, if speeds are kept below 100 kmph, the mHawk will give more than 12kpl. so, at speeds of 120 kmph, it gives 12kpl.
raj_5004 is offline
Old 13th May 2010, 16:15   #279
m_upreti's Avatar
Thanked: 311 Times
Hi, I have got up to 14Kpl, on part highway & part empty city roads with speeds between 60-90 KMH.
However, since lot of issues & tinkering has happened in the car over the last 1.5 yrs so i have kind of lost interest in keeping a tab on FE, but still it would be in the range of 11-12 KML
m_upreti is offline
Old 16th June 2010, 10:19   #280
raj_5004's Avatar
35,000 kms service:
Lock set: Rs. 1283/-
Brake pads: Rs. 3898/-
Engine Oil (Maximile Crown) 6 Lit.: 1120/-
Oil Filter: Rs. 138/-
Max Treat: Rs. 346/-
Cotton Waste: Rs. 8/-
Labour:
Engine Oil Change: Rs. 300/-
Front Disc Pads change: Rs. 380/-
Body Bolts Tight: Rs. 300/-
Ignition Switch Change: Rs. 190/-
Total: Rs. 8937/-
Issues faced/Problems reported: None
Total expenses faced till now including all services, general maintainence & repairs (not including accident repairs & repairs after the theft attempt) & excluding fuel bills: Rs. 32,800/- , that is, almost Rs. 1/- per km!
raj_5004 is offline
Old 16th June 2010, 10:32   #281
akshay4587's Avatar
Thanked: 1,686 Times
Raj,after how many kms,do you plan to change this oil?
I am skeptical about 15K drain period by mahindra.
What is Max treat?
akshay4587 is offline
Old 16th June 2010, 12:18   #282
raj_5004's Avatar
after 15k kms. i stick to the recommended procedure, nothing more, nothing less!
there is nothing to be skeptical about this. if you want to change the oil every 10k kms, you can do it. you can even do it every 5k kms! but the point is, whats the use?
i think max treat is an oil additive or an oil flush added to flush out the old engine oil.
raj_5004 is offline
Old 16th June 2010, 14:22   #283
MileCruncher's Avatar
Thanked: 357 Times
Firstly the new oil that is coming is 20k Drain interval, though I intend to stick to the 15k limit.
Secondly, in my discussion with M&M service staff they told me that they don't recommend any diesel or engine oil additives at all. Its the ASC which in its eagerness to fleece customers add the extra stuff. Diesel oils themselves have carbon flushing characteristics so adding something extra doesn't make sense. Atleast not every 15 K Kms and that too in 35k Kms. May be after 1L Kms yes!
MileCruncher is offline
Old 17th June 2010, 02:15   #284
tsk1979's Avatar
Thanked: 16,421 Times
Wow, thats a lot of money per km. The white elephant at almost 50,000kms stands around 60p/km(excluding tires of course)
tsk1979 is offline
Old 17th June 2010, 09:15   #285
raj_5004's Avatar
seriously, makes us think- is mahindra still a budget friendly brand?
raj_5004 is offline
Closed Thread
Scorpio VLX mhawk 4WD with Air Bags EDIT - 43000 kms update 4x4addict Long-Term Ownership Reviews 110 11th April 2013 16:16
Scorpio mHawk VLX Airbag - Initial OwnerShip Review abacusv Test-Drives & Initial Ownership Reports 38 16th January 2012 08:48
3 months 10K kms Mahindra Scorpio VLX mHawk pramods Long-Term Ownership Reviews 103 9th December 2009 11:48
Old Scorpio Mhawk>>> New Scorpio Mhawk rishin.kalra SUVs, MUVs & 4x4s 9 21st July 2009 15:51
