Old 20th December 2014, 07:38   #376
sudev's Avatar
Thanked: 2,666 Times
Do a push start. Slot in first. Clutch pressed. Ignition to on. Get two three people to push. Release clutch.
Once it starts go for a few kilometre spin. Should be okay.
sudev is offline   (1) Thanks Reply With Quote
Old 20th December 2014, 09:13   #377
SS-Traveller's Avatar
Thanked: 11,631 Times
Default Re: Suzuki Grand Vitara: 2,32,000 kms & 7 years ownership
Originally Posted by rattanw View Post
Fearful that excessive cranking or repeated tries may cause damage, I left it after three tries.
Just FYI: Cranking the starter for up to 15 seconds at a time is fine, and won't cause any damage to starter motor or battery or anything else. That's provided of course that the battery has enough charge to continue cranking.
As suggested earlier, a jump start with cables and another battery, or a push start, is required if your battery is run down.
SS-Traveller is offline   (1) Thanks Reply With Quote
Old 20th December 2014, 10:09   #378
mustysekhon's Avatar
Thanked: 60 Times
Get tow strap from Mayapuri. Look out for shops with pulleys and straps hanging outside. They sell supplies to cranes - ask for "patta" or strap. These are used by cranes to lift heavy equipment hence they are built tough. You can get D-shackles at the same place. The preferred length is 12 to 15 feet. Anything longer may not help as hills or most recovery situations do not have much space to allow more than 10-15 meters of straight space. The weight rating of tow ropes should be 3x of vehicle weight as thumb rule (not scientific but works). D-shackles should be .25 tonne less than tow strap rating to allow for breakage. I have a 5 tonne strap and 4.75 tonne D-shackles for my Vitara. Try and take the Vitara (or try out) the D-shackles for "fit" in both front and rear tow hooks (mine were OK for Vitara but a tight fit for Gypsy. This exercise will also help you understand the dependability on size of tow hook in recovery vehicle - although that is useful to know and may not be practical if there are limited vehicles to help choose from for in a recovery situation. Cost for both strap and a pair of D-shackles is between 1300 to 1800 depending on haggling.
mustysekhon is offline   (2) Thanks Reply With Quote
Old 20th December 2014, 15:02   #379
rattanw's Avatar
Thanked: 102 Times
Well yes that was the problem. Called Maruti on road assistance guys and they fixed the problem by jump starting. Left the car idling for 1 hour hopefully that should take care of charging the battery.
Thanks Samurai.
rattanw is offline   Reply With Quote
Old 24th December 2014, 22:47   #380
Got a Ferreterro 3 Ton Strap with two 2.5 Ton D shackles. Thanks for the advice
Suzuki Grand Vitara:  2,32,000 kms & 7 years ownership-tow-strap-12_24_2014.jpg
Suzuki Grand Vitara:  2,32,000 kms & 7 years ownership-tow-strap-vendor.jpg
dumdumdigadiga is offline   (2) Thanks Reply With Quote
Old 22nd March 2015, 12:30   #381
Hello @samurai and @Sudev - So this is a crazy problem. I lost(or someone found it) my key and feel that it might be used to steal my vehicle. I asked MASS Store and they're quoting something like 17K and 1 week for delivery. What can I do here?
What I have done is opened the bonner with my spare key and disabled some stuff so that it doesn't start.
Someone was telling me that CarShringar or other accessories shops might be able to do something with the key codes.
Any help is appreciated here.
dumdumdigadiga is offline   Reply With Quote
Old 22nd March 2015, 15:11   #382
Thanked: 548 Times
I had lost a key of one of my previous car. There are 2 options:
  1. get a new key (as a spare) and after getting it cut, get both the key reprogrammed so that the lost key cannot be used to start the car
  2. Even if the keys are reprogrammed, someone can break in to your car using the lost key. If you want to prevent it, you need to get the door locks changed as well. I assume this 17K quote may e for that
Other thought is, just forget worrying about the lost key! I know it is a not a good feeling and you are always worried, but it is unlikely that someone finds the key, he happens to be a car stealer and manages to know it belongs to your car and decides to steal it (a rare petrol SUV). Chances are very very low.
Guna is offline   (3) Thanks Reply With Quote
Old 25th March 2015, 00:22   #383
Thanks Guna, appreciate your response.
Option 1 is what I am planning to go for. Is there any danger in the programmer being able to create another copy of the key? How to make sure. Do I use a road side hacker or go to the showroom?
Option 2 - You mean open the doors but not start the car, right? Please confirm.
Old 25th March 2015, 17:06   #384
Thanked: 548 Times
Reprogramming requires a specific instrument. I dont know if roadside guys have it. In my case, even the showroom guys did not have it and they had to get it from their Chennai branch.
Yes the person who has found the lost key can enter but not start the car as you would have got it re-programmed.
Guna is offline   (1) Thanks Reply With Quote
Old 28th March 2015, 01:35   #385
Thanks Guna. These have the machine it seems. I'm planning to get a non remote version reprogrammed for about 2K. Is this expensive?
Old 28th March 2015, 05:32   #386
rajeev k's Avatar
Thanked: 1,750 Times
Push starting in second gear is advisable than first gear, as this will be smoother and a jolt can well be avoided.
rajeev k is offline   (1) Thanks Reply With Quote
Old 28th March 2015, 09:24   #387
Thanked: 548 Times
Better to check on EBay (you can buy a compatible blank key and get it cut/programmed) to see if that is the reasonable price. My gut feel is, it may come to 2k anyways.
Guna is offline   Reply With Quote
Old 29th March 2015, 01:07   #388
swiftnfurious's Avatar
Thanked: 6,583 Times
...[*]get a new key (as a spare) and after getting it cut, get both the key reprogrammed so that the lost key cannot be used to start the car...
Would Maruti re-program a key that's done outside? I doubt. If you buy from Maruti, the keys come ONLY in pairs.
Don't think so. They have a standard rate for re-programming and it's something around the rate you mentioned.
swiftnfurious is offline   Reply With Quote
Old 29th March 2015, 12:13   #389
Thanked: 548 Times
Note sure about Maruti. Chevy (in my case)had got me only 1 key. They were OK to program it if I was getting the blank key from outside.
Old 25th April 2015, 14:34   #390
Thanked: 60 Times
Any pointers on getting Geolandar AT-S tyres 225/65/R17 on the 2.4 Ltr GV. My tyres are due for replacement today.
Anyone faced any issues with tyre touching the body etc?
mustysekhon is offline   Reply With Quote
The First Grand Vitara on Team-BHP Samurai Long-Term Ownership Reviews 1252 14th July 2018 15:26
Maruti Suzuki Alto LXi Ownership Review : 7 years and 70,000 Kms gpa Long-Term Ownership Reviews 202 30th August 2017 22:06
Celebrating 4 years & 85,000 kms - Ownership experience of my Maruti Dzire JoshMachine Long-Term Ownership Reviews 29 31st January 2015 14:16
Bajaj Pulsar 180 UG4 - Ownership review. 2 Years & 13,000 kms nilaykmrsr Motorbikes 21 26th December 2014 22:49
Twin Tested & Ripped: New Honda CRV AT v/s New Suzuki Grand Vitara MT Dippy Test-Drives & Initial Ownership Reports 23 29th July 2007 00:19
