Old 25th November 2013, 21:02   #91
anky's Avatar
Thanked: 92 Times
Buy the mirror over the counter from maruti and fit it from a good electrician .
anky is offline   Reply With Quote
Old 25th November 2013, 21:16   #92
Thanked: 2,060 Times
Default Re: SX4 2007 ZXI 20000 km report
Its not just the cover @anky, but the entire assembly with wiring and the folding operations and switch! So unless done by MASS, it would be risky. But I am going to try and see if that is a possibility.
abirnale is offline   Reply With Quote
Old 25th November 2013, 21:47   #93
paragsachania's Avatar
Thanked: 10,511 Times
There will be a couple of things before this is attempted
  • Whether the new Mirrors (Foldable type) will fit on the previous Gen SX4 - Holes, notches, perfect fit. Don't forget the the foldable type mirrors will also have a motor for the folding operation and hence there would be changes to the design of the hinges etc that may make retrofitting a tad difficult unless someone has successfully done that?
  • Since the usual Electrically operated mirrors had adjustment as a sole function (non folding), it would merely send signal to the motor behind the mirror to move as per inputs from the joystick switch on the door.
  • With Folding as a new function, you will not only need to do a bit of wiring but will also have to buy and install the switches meant for folding as well.
  • If there is a separate switch for Fold/unfold, where will that fit on the Door pad? Will that require one to cut the door panel to accommodate?
paragsachania is offline   (1) Thanks Reply With Quote
Honda City Vtec-20000 km report - updated to 61500km ajmat Long-Term Ownership Reviews 185 15th March 2014 12:46
2005 Ford Ikon 1.6 ZXi: 20000 km review. Updated to 80000 km. Absar Long-Term Ownership Reviews 52 2nd May 2012 18:12
Fiat Palio Stile Multijet SDX 20000 Kms (1st report) streetlife Long-Term Ownership Reviews 16 16th April 2011 12:42
Honda Civic - Two Year - 20000 km report csentil Long-Term Ownership Reviews 27 14th March 2009 22:26
