Old 14th May 2009, 08:00   #421
undead's Avatar
Thanked: 168 Times
What about the black smoke after cleaning the GC filter ?
undead is offline   Reply With Quote
Old 15th May 2009, 14:59   #422
kpzen's Avatar
Thanked: 1,655 Times
Totally gone! Air filter was the culprit.
If everything goes as per plan, another CRDi might join the existing monster soon.
Old 15th May 2009, 21:09   #423
Awaiting Email Confirmation
Thanked: 20 Times
Stop teasing and tell us which one! Are you single handedly planning to push up the sales of this hot hatch?
Old 15th May 2009, 21:16   #424
Eddy's Avatar
Thanked: 5,067 Times
KP is buying an old Palio-D
Eddy is online now   Reply With Quote
Old 18th May 2009, 13:41   #425
undead's Avatar
Thanked: 168 Times
is it an used Elantra CRDi ?
Old 19th May 2009, 09:34   #426
kpzen's Avatar
Originally Posted by brraj View Post
Until and unless Verna crdi and Getz petrol is existing there is no need to worry atall even if they stop production.
But surprisingly there a few parts which it shares with an Elantra.
Getz/ Elantra have a common fuel filter whereas the Verna and Sonata share the same filter. No idea why it is so.
Don't think its gonna work. It was a one year old Getz 15k kms done.
Ohh ! Wish i could.
Old 19th May 2009, 13:51   #427
undead's Avatar
Thanked: 168 Times
Ohh ! Wish i could.
Got to be little careful in getting one.
Slightly
Last week went and drove an Used Elantra CRDi . 2004 Model . Run 105000 kms. No accident history when i checked with the dealer. Most of the parts changed like Brake Pads , Front Studs , Timing Belt , Clutch plates . New Michelin Tires , Koyas Seats in clean condition , K&N Air Filter . Car in Good condition .But , when i started the car , it seemed like a Stroke was missing while the engine is running in idle, like the engine noise flow was up and down and not smooth. When asked about it with the Hyundai searvice guy , he said , there might be some dust inside the valve and the only option would be changing the injectors which costs Rs. 20000 for One. They say , they should change all the 4 injectors if we decide to do it. Or it may also be a case of Sensor problem .Or , might be one of the cylinder is in a bad condition .Reboring costs Rs.75000+ . Other than the engine , the car was in an immaculate condition. Well maintained by the owner. So , avoided the car due to this.
Old 19th May 2009, 16:12   #428
Jaggu's Avatar
Thanked: 8,671 Times
OT reply : Good decision undead, stay away from any car with engine as suspect. New age engines, esp diesels are quite complicated and cost a bomb to repair.
Old 28th May 2009, 14:01   #429
kpzen's Avatar
Default Update :30000 kms / 4th Service (Paid)
The car has gone in for the 30k service today.
Was planning to give the car for servicing at 27.5k kms and finally its gone for servicing after a week and 1000kms due to time constraints and a lot of mile munching.
Problems reported :
1. Brake juddering at speeds > 100kph.
2. Windscreen jet washer alignment (LHS)
3. LHS indicator on fender falling off at speeds above 160kph causing turbulence.
Things to be replaced during 4th service
1. Engine Oil
2. Oil Filter
3. Fuel Air filter in fuel tank
4. Brake Oil
5. Coolant
Note : Now, SHELL HELIX Super 15W40 is the official engine oil replacement for all Hyundai CRDIs.
Old 28th May 2009, 14:18   #430
theMAG's Avatar
Thanked: 1,572 Times
A 2nd CRDi engine in the back of your Getz CRDi? Similar to Mercedes-McLaren's specially built twin-engined A-class for Mika Hakkinen and David Coulthard after they won WDC and WCC !!!!
Old 28th May 2009, 18:53   #431
trrk's Avatar
Thanked: 13 Times
1. Engine Oil
2. Oil Filter
4. Brake Oil
5. Coolant
Don't see an air filter change. Air filter change every 10000kms was a must for the older generation CRDi engines.
trrk is offline   Reply With Quote
Old 28th May 2009, 20:40   #432
Jaggu's Avatar
This car is running on after market replacement filter, doesnt require replacement, just cleaning is enough
Old 28th May 2009, 22:12   #433
trrk's Avatar
Thanked: 13 Times
Missed out on that. Sorry.
Old 28th May 2009, 23:14   #434
kpzen's Avatar
Sensational idea, Is it possible ?
Originally Posted by trrk View Post
Sir,
You are right about replacement of stock air filter @ every 10k kms.
My car is running on Green stock replacement filter which was fitted at 13k kms. Every time i give the car for servicing i remove both petes and the filter and put the stock filter which has only done 3k kms.
During the last two periodic services, the SA was shocked to see such a clean filter after doing more than 10k kms.
Old 28th May 2009, 23:28   #435
black12rr's Avatar
Thanked: 274 Times
You mean to say that , you are afraid that, you loose the warranty if they find out about the green cotton setup ?
black12rr is online now   Reply With Quote
Kpzen->Kpgetz->Kpfigo : Remapped Figo TDCi kpzen Test-Drives & Initial Ownership Reports 72 14th July 2014 07:13
Happy to join team-BHP family human_being Introduce yourself 5 21st September 2010 14:50
Volkswagen Polo specs. EDIT : 11,111,111th Polo rolls off in Pune (Pg. 18) sidindica The Indian Car Scene 375 23rd February 2010 18:10
Happy Birthday Ashpillai and KPGetz jkdas Shifting gears 5 30th January 2010 16:03
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
