Old 11th September 2010, 10:02   #571
kpzen's Avatar
Thanked: 1,655 Times
Default Late 60000kms service !!
The 60k kms service was delayed a bit due to rains and ended up running 2000kms more than the scheduled time/kms.
Odo - 62386 kms
Things replaced:
Shell Power Steering Oil
Shell Coolant
Shell Brake Oil
Hyundai MOBIS Fuel Filter
Things done:
Radiator Flushing
Brake servicing
TOTAL BILL - Rs 3495/-
cost of Consumables - Rs 2420/-
Labour + tax - Rs 1075/-
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-gtz25-large.jpg
Name:  60k service.jpg
Old 13th September 2010, 11:37   #572
kpzen's Avatar
Rattling + an insensitive Horn button - a small DIY solution.
The horn button used to rattle once in a while but one strong tap on it used to make it disappear.
But, the current running on bad rain affected cratered roads have taken a toll on them and tapping no longer works.
Also, since last week the horn was only working when pressed at couple of locations.
One free sunday and awesome weather turned out to be an ideal combo for a DIY.
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-1.jpg
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-2.jpg
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-3.jpg
Carbon deposit looked like a possible reason for an insensitive horn button.
Cleaned it with a dry cloth and fixed it back.
VOILA !! Problem solved.
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-4.jpg
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-5.jpg
Old 14th September 2010, 10:46   #573
krish3's Avatar
Thanked: 20 Times
Thats a nice pictorial description. Thanks for this. In case we ever face this issue, we now know what needs to be done. Helps save the trip to service centre
krish3 is offline   Reply With Quote
Old 20th September 2010, 17:05   #574
kpzen's Avatar
After a long long search, got the synthetic (based) gear oil from Hyundai itself.
2L - Rs 1500 (inclusive taxes)
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-180920101241.jpg
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-180920101242.jpg
Old 20th September 2010, 20:36   #575
pras.oct25's Avatar
Thanked: 7 Times
@kpzen - what is the advantage of synthetic based gear oil over normal gear oil?
pras.oct25 is offline   Reply With Quote
Old 21st September 2010, 15:37   #576
krish3's Avatar
Thanked: 20 Times
Whats the change interval for a synthetic gear oil? I think its 30k kms for normal.
Old 22nd September 2010, 12:15   #577
kpzen's Avatar
All Hyundai diesel and automatic variants come with synthetic gear oil from factory but as a refill Hyundai has given the service centers only the mineral type gear oil.
Mainly, due to the cost factor. Synthetic costs almost 3 times. When they launched Verna they had synthetic but customers had preference for the cheaper option of mineral.
80k for synthetic. I got it changed @ 64k.
Old 22nd September 2010, 12:26   #578
pras.oct25's Avatar
Thanked: 7 Times
Apart from the long life, does it help smoothening out gear transmission? As in does it help remove the notchy feel when shifting gears?
Old 22nd September 2010, 12:33   #579
jkdas's Avatar
Thanked: 1,436 Times
That's a lot of dust for a 2000kms run,right?
And will it help if one changes gear oil more frequently? like 20k /30k?
Old 22nd September 2010, 16:10   #580
benbsb29's Avatar
Thanked: 4,276 Times
Great job regarding the DIY for the horn issue, KP.
Old 18th October 2010, 13:34   #581
kpzen's Avatar
Random AC Test.
Didn't follow any SOP (Std Operating Procedure) Just went about it with my own logic.
Outside Temp - 39 C
Grill Temp - 13.x C
Front seat temp - 21.x C
Rear Seat Temp - 23.x C
Operating Time - 15mins
AC on full blast.
Old 18th October 2010, 13:48   #582
.anshuman's Avatar
Thanked: 9,159 Times
@KP: Even i had to search for synthetic gear oil for my Elantra. The dealerships generally stock only the mineral gear oil. I'll search the bill to compare the cost details.
Old 18th October 2010, 22:18   #583
kpzen's Avatar
I think it does, but can't be sure unless we try mineral oil in the same gearbox.
PW got it changed & felt the roughness in gear change.
yeah, it becoming a pain now & i'm not sure if its bad or good in the long run.
Not required IMO. Even the mineral gear oil have a change interval of 30~50k kms.
Thanks.
That rattle is back.. need to find another solution.
Ya, even i searched a lot, almost ended up sourcing FUCHS from Germany. Then, at the last moment the HMP fellas told me that they have it in stock & hardly anyone has ever asked for one so they never mentioned about it.
Old 18th October 2010, 23:22   #584
ph03n!x's Avatar
Thanked: 120 Times
Prajesh, your Monroe review is due!!
ph03n!x is offline   Reply With Quote
Old 19th October 2010, 12:44   #585
kpzen's Avatar
Guilty as Charged
Here you go, a small review.
MONROE SENSATRAC
Rear Dampers
Total kms done - 5000 kms
PROS
1. Make no mistake, the Korean rocket now goes like a stink.
2. Braking is more progressive, absolutely no nose dip and there's so much of confidence while braking at high speeds.
3. The car's absolutely planted at any speed even while changing lanes. There's no waving feel and no hint of the tail
coming out.
CONS
1. Firm ride at the back. Its not horrible, just some better cushion seat would make it better. Mind you, its only in
the rear, in front you won't feel it.
2. Steering has become a tad lighter. Which i guess is due to weight balance which has shifted to the rear. The car
feels as if there's 300kg load at the back.
3. Lot of stress of tires/ chassis & passengers
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-310720101145-large.jpg
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-310720101146-large.jpg
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-310720101147-large.jpg
Kpzen->Kpgetz->Kpfigo : Remapped Figo TDCi kpzen Test-Drives & Initial Ownership Reports 72 14th July 2014 07:13
Happy to join team-BHP family human_being Introduce yourself 5 21st September 2010 14:50
Volkswagen Polo specs. EDIT : 11,111,111th Polo rolls off in Pune (Pg. 18) sidindica The Indian Car Scene 375 23rd February 2010 18:10
Happy Birthday Ashpillai and KPGetz jkdas Shifting gears 5 30th January 2010 16:03
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
