Old 18th April 2011, 14:39   #601
kpzen's Avatar
Thanked: 1,655 Times
Default re: kpzen to kpgetz : Two Getz CRDi's join the family !! - 77,777 kms
Originally Posted by kailashnj View Post
Your car still looks perfect. Man you maintain your car well. Its a beauty to watch.
Thanks Kailash.
lol;loved the last line. Why not get the CAI? Have ever seen the mod setting (knob's?) pix. Can you post that too?
JK
Getz comes with CAI.
Here's a pic of the box.
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-31012009059.jpg
Originally Posted by krish3 View Post
80k in less than 3 yrs?? WOW.. thats an amazing run. What do you do to get such running?
Actually, now i've slowed down a bit. There was a time when i was averaging 230 kms in a day and also did 6000kms in a week.
How's the engine doing with the Pete's? I guess this would be a long termer for the Pete's equipped Getz. Wanted to know if you see more smoke coming now, or any dip in performance.
Engine is fine, still reaches 200kph. Clutch is getting harder and also a bit weak.
Car has run a total of 65k kms with Petes box. Whenever there's smoke, its an indicator to clean the air filter. Once the air filter is cleaned, smoke vanishes.
Old 20th April 2011, 20:04   #602
Vdrive's Avatar
Thanked: 18 Times
Default Re: kpzen to kpgetz : Two Getz CRDi's join the family !! - 77,777 kms
@ Prajesh - Getz comes with CAI ? You mean factory fitted ? Where is it located ? Sorry, not clear from the picture.
Vdrive is offline   Reply With Quote
Old 20th April 2011, 20:16   #603
Vdrive's Avatar
Thanked: 18 Times
@ Prajesh - a little OT. Initially in my Getz CRDi, 2000 rpm corresponded to 100 kmph. But now the speedo is showing only 90 kmph for the same rpm. I'm on stock tyres and stock rims. No mods done.
Old 20th April 2011, 22:06   #604
ph03n!x's Avatar
Thanked: 120 Times
5th Gear, 2k RPM is ~90 KMPH. Not sure how it was 100 KMPH earlier.
ph03n!x is offline   Reply With Quote
Old 20th April 2011, 23:11   #605
kpzen's Avatar
Try to follow the air flow route.
I'll try to post a pic by tomorrow.
In my car, 5th gear @ 2000 RPM = 100kph
Old 20th April 2011, 23:32   #606
ph03n!x's Avatar
Thanked: 120 Times
Interesting!! I am just back from work (I was in work when I posted the earlier post), and did confirm that it is 90 @ 2000 RPM in my ride. Am running on 185/65 R14 now (same as you!) - don't know what else is different! 100 comes at 2100 RPM or so.
Other rocket riders - confirm the 100 KMPH RPM please.
Old 21st April 2011, 13:12   #607
kpzen's Avatar
Your Clutch is slipping.
My cousin's clutch was gone when it started doing 100 @ 2200 RPM.
Old 21st April 2011, 14:46   #608
Vdrive's Avatar
Thanked: 18 Times
@ pho3n!x :- Yes, that's what I'm getting; 100 @ 2100. But I'm damn sure it was 100 @ 2000 earlier. But not sure when it changed and why ..
@ Prajesh :- But my rocket is only 12K done though it is 2 years old. A clutch slip so early ? I had pointed it out to the Hyundai A.S.S. here but he didn't take it a serious issue..
Old 21st April 2011, 14:57   #609
tsk1979's Avatar
Thanked: 16,420 Times
For testing clutch do this
Pull handbrake with car stationary
Put car in 5th gear
take your foot very slowly off the clutch without touching the accelerator.
If your car keeps idling, time for a new clutch. Otherwise, its fine.
Do not worry too much about 100kmph at 2000 rpm or 2100 rpm.
rpm meters are not perfect and a 30-40rpm variation here or there is common.
Old 21st April 2011, 15:41   #610
kpzen's Avatar
Put car in 5th gear
Tanveer
Pls explain the above line.
I would like to test.
Getz has a huge RPM meter unlike some other cars like Figo. Difference of 100~200 RPM is noticeable.
What size tires are you using ?
Old 21st April 2011, 16:05   #611
tsk1979's Avatar
Tanveer
When you slowly release clutch of the parked car, if the clutch is slipping, the car will not stall.
However, if clutch is fine, the engine will stall
Its not just the readability, its also the accuracy. RPM meters may not be completely accurate.
Old 21st April 2011, 16:25   #612
ph03n!x's Avatar
Thanked: 120 Times
My car stalls with the handbrake on alright.
Here are the 2000 RPM speeds I tested today:
2nd - 35 KMPH
3rd -50 KMPH
4th - 70 KMPH
5th - 90 KMPH
5th - 100 KMPH @ ~2100 to 2200 RPM
The only thing I noticed was that the car is reaching 180 like always, but crossing 180 KMPH seemed tough - I never got it like I was able to when it was new. It was used for 3k KM by a few from my family when I was not in town, including not-so-great drivers - don't want to do a clutch job at 40k KM itself
Old 21st April 2011, 16:27   #613
phamilyman's Avatar
Thanked: 3,526 Times
The variation of this clutch test is to test it in the 3rd gear - atleast for the swift - that's how the GM of Apra Auto demonstrated it to me.
Old 21st April 2011, 16:40   #614
Spinnerr's Avatar
Thanked: 155 Times
^^ Would this clutch test work even in a diesel Bolero??
If the low end torque is more should one go to higher gear? say 5th?
Spinnerr is offline   Reply With Quote
Old 21st April 2011, 16:51   #615
krish3's Avatar
Thanked: 20 Times
I'll check today at what rpm mine touches 100 (5th gear). I only remember that @ 1600 rpm, 5th gear equates to 75-80kmph. I think 100 comes around 2000 or slightly above.
krish3 is offline   Reply With Quote
Kpzen->Kpgetz->Kpfigo : Remapped Figo TDCi kpzen Test-Drives & Initial Ownership Reports 72 14th July 2014 07:13
Happy to join team-BHP family human_being Introduce yourself 5 21st September 2010 14:50
Volkswagen Polo specs. EDIT : 11,111,111th Polo rolls off in Pune (Pg. 18) sidindica The Indian Car Scene 375 23rd February 2010 18:10
Happy Birthday Ashpillai and KPGetz jkdas Shifting gears 5 30th January 2010 16:03
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
