Old 21st April 2011, 17:08   #616
kpzen's Avatar
Thanked: 1,655 Times
Default Re: kpzen to kpgetz : Two Getz CRDi's join the family !! - 77,777 kms
When you slowly release clutch of the parked car, if the clutch is slipping, the car will not stall.
However, if clutch is fine, the engine will stall
Will check and post.
Its not just the readability, its also the accuracy. RPM meters may not be completely accurate.
Agreed, but this is a case of before and after.
Before it was 100kph @ 2000 RPM
Now it is 100kph @ 2100 RPM.
Originally Posted by ph03n!x View Post
My car stalls with the handbrake on alright.
Here are the 2000 RPM speeds I tested today:
2nd - 35 KMPH
3rd -50 KMPH
4th - 70 KMPH
5th - 90 KMPH
5th - 100 KMPH @ ~2100 to 2200 RPM
2000 RPM
2nd gear - 40kph
3rd gear - 60kph
4th gear - 80kph
5th gear - 100kph
5th gear - 140kph @ 3000RPM
5th gear - 180kph @ 4000 RPM
The only thing I noticed was that the car is reaching 180 like always, but crossing 180 KMPH seemed tough - I never got it like I was able to when it was new.
Naah. Don't conclude anything by this.
It depends on lot of external factors like climate, wind, air filter condition etc.
Everything has to be perfect at those speeds.
kpzen is offline   (1) Thanks Reply With Quote
Old 21st April 2011, 17:52   #617
DWind's Avatar
Thanked: 170 Times
What size tires are you using ?
Would size of the tyres matter here?
I thought the speedo is calibrated based on the drive shaft speed. The Size of tyres would matter when one is calculating the actual speed of vehicle. So two cars running different sets of tyres should report the same speed at the speedo for a given RPM. It is a different matter that actual speed (say, calculated by GPS although slightly inaccurate) would be different.
DWind is offline   Reply With Quote
Old 21st April 2011, 18:18   #618
tsk1979's Avatar
Thanked: 16,420 Times
You are right, the size of the tires will have no bearing on the speedometer speed and RPM correlation.
Old 21st April 2011, 21:19   #619
Vdrive's Avatar
Thanked: 18 Times
@ Prajesh : I'm still on stock tyres GPS 2 175/65.
I will check the 120 kmph, 140 kmph, 160 kmph tomorrow and see if it matches the respective rpm. Still confused if it is really an issue or not..
Vdrive is offline   Reply With Quote
Old 21st April 2011, 23:40   #620
ph03n!x's Avatar
Thanked: 120 Times
2000 RPM
2nd gear - 40kph
3rd gear - 60kph
4th gear - 80kph
5th gear - 100kph
That is a neat 10 KMPH difference in the 3rd, 4th and 5th gears. But I dont think I will go for a clutch replacement yet.
ph03n!x is offline   Reply With Quote
Old 22nd April 2011, 09:05   #621
pras.oct25's Avatar
Thanked: 7 Times
Whats wrong with you? You ve done only 40k. I'm sure your driving habits are not that bad that you will warrant a clutch change. If its slipping have the play adjusted and clutch bled. That should do.
pras.oct25 is offline   (1) Thanks Reply With Quote
Old 22nd April 2011, 10:03   #622
kpzen's Avatar
Tanveer,
How much clutch should be released for the test ?
I tried, car stalled when 80~90 % clutch was released. Is this ok ?
Pls don't try those speeds on stock wheels.
Those punny crappy Goodyears can't take that much of power.
This car has a very robust clutch. Can take a lot of torture if driven properly.
So, Don't hurry. Go for clutch replacement only after double checking.
Did you get the clutch bleeding done ?
Old 22nd April 2011, 11:14   #623
ph03n!x's Avatar
Thanked: 120 Times
I can imagine you actually telling that to me in your style!!! No, I wont hurry into a clutch replacement, the car is heading in on Saturday.
Not yet - am taking it in tomorrow for the service. Waiting for Delvac 1 to land
Old 22nd April 2011, 11:38   #624
krish3's Avatar
Thanked: 20 Times
Dont think your car has a clutch problem. Noticed your driving that night when travelling with you (for that short distance) and it's a minimal clutch way. So @pras.oct25 might be right in what he says.
BTW-: My car touches 100 @ 2000 rpm on 5th. Just checked it yesterday on hosur road. But I was accelerating at that point. Will have to try it at cruising mode.
krish3 is offline   Reply With Quote
Old 22nd April 2011, 12:31   #625
tsk1979's Avatar
Tanveer,
your clutch is perfect. Normally on modern engines, with proper usage clutches last 100,000kms easily.
Old 23rd April 2011, 08:05   #626
undead's Avatar
Thanked: 168 Times
Ok to add my Data
at 2000rpm
3rd gear - around 53kmph
4th gear - around 73kmph
5th gear - around 93kmph
My tire size is 195/60R14
undead is offline   Reply With Quote
Old 23rd April 2011, 14:10   #627
kpzen's Avatar
Originally Posted by undead View Post
Ok to add my Data
at 2000rpm
Hi Undead.
How did you get these odd numbers ? Used a GPS ?
Old 23rd April 2011, 18:46   #628
undead's Avatar
Thanked: 168 Times
Hi Undead.
Na, Just a guess.when i looked at the speedo it was around 40% in between 90 and 100kmph . I do have external GPS, will try to calculate using that too.
Old 29th April 2011, 12:31   #629
ph03n!x's Avatar
Thanked: 120 Times
After some sleepless nioghts, and pestering BHPians for their 2000 RPM values, here is what I have (Letz Getz Started (Hyundai Getz CRDi)- UPDATE: 40000, new alloys, tires!!! (page 30)).
Prajesh, your game is up - what mod are you running under the hood???!
Old 23rd May 2011, 12:14   #630
kpzen's Avatar
My Korean missile crossed the 80000kms mark last week.
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-140520111868-large.jpg
Got a new Green filter.
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-170520111876-large.jpg
Old vs New. (Old one got partially sucked in and the fins got damaged)
kpzen to kpgetz : Two Getz CRDi's join the family !! -  1,11,111 kms-190520111877-large.jpg
Kpzen->Kpgetz->Kpfigo : Remapped Figo TDCi kpzen Test-Drives & Initial Ownership Reports 72 14th July 2014 07:13
Happy to join team-BHP family human_being Introduce yourself 5 21st September 2010 14:50
Volkswagen Polo specs. EDIT : 11,111,111th Polo rolls off in Pune (Pg. 18) sidindica The Indian Car Scene 375 23rd February 2010 18:10
Happy Birthday Ashpillai and KPGetz jkdas Shifting gears 5 30th January 2010 16:03
Verna Crdi Vs GetZ Crdi. EDIT : Finalising on Getz! aks_karthik Hatchbacks 74 17th May 2009 10:22
