Old 13th March 2012, 18:58   #1771
rrsteer's Avatar
Thanked: 937 Times
Default re: Safari EX 4x4 120000kms update
The gearshift is getting worse. Sometimes, no matter how much I try, reverse cannot be engaged. This is happening even with warm engine.
The continentals which I had put in at 20K are at end of life, will need to get a set of 4 new tires, with the least worn out tire doing spare duty.
What could be the reason for the hard gearshift?
And, will you stick to Continentals?
rrsteer is offline   Reply With Quote
Old 13th March 2012, 19:27   #1772
mercedised's Avatar
Thanked: 177 Times
Other than that, the power windows are problematic. If its below 5 degrees, the window(Drivers side window) has to be pulled up by hand. It won't come up on its own.
For the windows problem you will have to change something called as "Rack" on which the glass slides up and down.
For gearshifts check lever bolts, if something is getting stuck, otherwise the gearbox will have tobe opened up happened with me.
Old 13th March 2012, 20:11   #1773
tsk1979's Avatar
Thanked: 16,421 Times
Hard Gearshift will be checked next time I take to the service center. The front hubs seem to be gone. Vehicle is not shifting properly to 4wd and front hubs make noise. Even on braking.
As for the tires, I actually got 4 tires replaced recently. And they are continentals
Brand new and shiny
And best part. The sliding on ice is much reduced now. That said, I need snow chains. 4x4 can only go so much
Old 14th March 2012, 08:51   #1774
Deeps's Avatar
Thanked: 68 Times
So what does your per km cost stand at now for maintenance and overall?
Deeps is offline   Reply With Quote
Old 14th March 2012, 10:33   #1775
tsk1979's Avatar
78500kms
Repair(service + running repair cost) = 0.98/km
Fuel cost 3.31/km
Average FE(life of vehicle) - 10.70
Accessories(seat covers reverse camera etc.,) : 0.26/km
Non Tata (Tires, alignment done outside, wheel balancing done outside) : 0.79/km
So overall cost/km including fuel = 5.34
Excluding fuel(including accessories and tires) = 2.03/km
Old 23rd March 2012, 21:40   #1776
sumannandy's Avatar
Thanked: 219 Times
I would recommend you check with TASS for repair option for front hubs. The cost of replacement is around Rs. 15k per hub. I had the similar problem, i.e., it would make noise on 4wd. TASS quoted 15k. However, with kind help from someone at Pune (whom I came to know through this forum, but cannot publish his name without permission) and lot of follow up with TASS, finally they repaired it for Rs. 300.
sumannandy is offline   Reply With Quote
Old 26th April 2012, 10:27   #1777
himavanth_m's Avatar
Thanked: 269 Times
Brand new and shiny
Could you please let me know the cost you paid for these new crosscontact tyres?
If you are not comfortable sharing with the information, could you atleast share price quoted by dealer MRP. (assuming you got some discounts)
himavanth_m is offline   Reply With Quote
Old 26th April 2012, 13:51   #1778
tsk1979's Avatar
I paid 7500/tire - discount for old tires (some 2000rs total)
When the ISI marked version comes, shortage should go away, and you should get it for 7000/tire.
I am not sure whether Continental plans to bring this A/T tire to India or not. They are concentrating more on highway tires, since thats where the market is.
tsk1979 is offline   (1) Thanks Reply With Quote
Old 5th May 2012, 23:16   #1779
tsk1979's Avatar
Default 77800kms update
A funny km number to give an update, right?
But then the white elephant spent 3 weeks at the service center, a major part of it to get the 4x4 transfer case parts.
Apart from that she had developed the the habit of marking territory, so rear diff oil as well as power steering oil had to be changed. Gearbox was also giving trouble, so clutch plates and pressure plates were changed, along with a few gearbox parts.
All in all, 50,000 INR worth of parts change.
Yes you read it right.
MY share.. 19960.
The ownership cost is creeping up at a brisk pace now. Hopefully she will last another year without making any more such dents in the pocket.
Anyways, here is the list of parts changed.
Old 6th May 2012, 09:38   #1780
v&v
v&v's Avatar
Thanked: 1,099 Times
50k . 19k you paid is for clutch/pressure plates and consumables. So EW saved a good 30k. At least now your 4x4 system is in top shape!
Where are you heading ?
v&v is offline   Reply With Quote
Old 6th May 2012, 10:35   #1781
F150's Avatar
Thanked: 685 Times
That's a hefty bill tsk.
By any chance did you maintain any excel sheet with the costs incurred towards servicing excluding the fuel costs.
Is it normal for the transfer case parts to fail at 78k kms or is it due to any hard core /extensive off -roading that you have done ?
F150 is offline   Reply With Quote
Old 6th May 2012, 18:25   #1782
tsk1979's Avatar
Not heading anywhere, its just that daily driving was getting troublesome due to gearshift. On a recent trip 4x4 failed to engage.
The 19K is for one bearings, consumables, some 4x4 parts(gaskets etc.,),. synchros, clutch plate, pressure plate.
I do maintain a sheet.
I have spent 97000rs on the car till now (77800kms)
This is excluding - Tires, Fuel, Accessories, and just includes the amount spent at workshops.
The last few notable expenses
69000kms - 16000 for front suspension and steering work, and some rear diff work
60000 - Rear suspension work
As for off roading, I have never done hard core offroading in the safari. even when I went on a NIOC otr, I gave most obstacles the miss.
Even on ladakh trips, there was no place where I had to do hard core offroading. I think its just general safari quality. Something or the other fails. In my case it was the 4x4.
As for clutch, well it could have lasted 10k kms more, but I decided to go for a new one so that daily driving would get better.
Old 6th May 2012, 18:53   #1783
lohithrao's Avatar
Thanked: 163 Times
60k for for "rear" suspension, this is too high for just the rear suspension!
what all was replaced?
Btw have not seen any new travelogue from you offlate? or have i missed it?
lohithrao is online now   Reply With Quote
Old 6th May 2012, 20:30   #1784
tsk1979's Avatar
LOL Lohit, I meant "60000kms"
I have not written any logs for quite some time. Will post a few pics in the coming days.
Old 6th May 2012, 20:34   #1785
lohithrao's Avatar
Thanked: 163 Times
ahhh my bad, btw how much total suspension overhaul cost?
The Abominable (Skoda) Yeti *UPDATE* 20,000Kms Update on Pg.14 SushilBajpai Test-Drives & Initial Ownership Reports 281 8th December 2016 16:08
4x4 Power, My Skoda Yeti Elegance. UPDATE: 63k kms up on page 6 Akshay1234 Long-Term Ownership Reviews 91 8th December 2016 01:11
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Black Storm-Safari GX 4x4. EDIT : 70k Kms update Lukeskywalker Long-Term Ownership Reviews 49 6th May 2013 16:58
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
