Old 7th January 2009, 17:58   #316
deepgautam_qa's Avatar
@Tanveer: Friend of mine is working with TML. In case of any problem faced, PM me. Let's hope he is able to help!
Jai Hind!!!
deepgautam_qa is offline   Reply With Quote
Old 7th January 2009, 20:03   #317
4x4addict's Avatar
Thanked: 2,669 Times
I always expected niggles out of Tata, but this one has exceeded all expectations.
On saturday I took her to autolinks with the following issues
2. 4x4 noise issue(I was hearing some noises)
Next the 4x4. Well its failed. Dead Nana. The entire hub locking mechanism(basically everything except the transfer case) has to be replaced. And parts are not in stock, they come from TML pune
I think this issue is due to the lack of 4x4 systems with the dealership. Basically besides broker axles and/or propellor shafts the fault is either with the automatic electric hub locks or with the transfer case. Assuming your tansfer case is working and you see the front drive shafts turning when you have the vehicle on a lift then it is a fault of the hub locks. Personally I am not a fan of electric transfer cases and electric hub locks.
4x4addict is offline   Reply With Quote
Old 7th January 2009, 20:54   #318
Thanked: 253 Times
I'd agree that for serious OTR this is not a desirable system, but for a tourer like myself, I find it endearingly convenient!
In two & a half years ownership, I must have engaged the 4WD on-the-fly at least 60 to 70 times! I do find it a bit of a bother to reverse a few meters to fully disengage, but I've not always done that as a priority.
Old 8th January 2009, 01:15   #319
tsk1979's Avatar
Thanked: 16,422 Times
The part breakage is the mechanical hub, nothing electronic about it.
@deepgautam_qa I have sent you a PM,thanks!
Old 8th January 2009, 08:11   #320
5. Wiper leaving streaks
Sorry for questioning a less serious problem in your troubled times. Could you get the wipers replaced under warranty? Mine too have started giving the same problem.
anilrs is offline   Reply With Quote
Old 8th January 2009, 11:04   #321
tsk1979's Avatar
It was a case of adjustment issues, and it was solved. I am told wipers usually last around 1.5 years. After that I plan to get bosch
Old 8th January 2009, 11:16   #322
getsurya's Avatar
Thanked: 967 Times
TSK, sorry to note the troubles. I hope they are done to your satisfaction sooner than later.
On the pulling to the right when braked hard(as you described), I had a similiar problem initially in my Crde Scorp. The brake master cylinder (distributes the braking power to all wheels, if I am right!)replacement solved the problem. Just thought will share with you to keep you informed!
getsurya is offline   Reply With Quote
Old 8th January 2009, 11:54   #323
tsk1979's Avatar
With the slider adjustment, she is doing fine on that front for now. Problem has not come back. More driving will reveal if its really done.
Meanwhile I still await parts from TML pune. If they send it by road, it will not reach due to truck strike, so I am pretty stuck for the moment
Old 8th January 2009, 12:23   #324
suman's Avatar
Thanked: 257 Times
Tanveer, sorry to hear about your woes!
Have they told you whether this was a manufacturing defect or was it due to usage of 4x4 even after the "bent" pin incident?
As far as spares are concerned, most slow moving items (like differentials etc) are rarely kept in dealer's stock. The Central Warehouse in Gurgaon also runs "lean" inventory so most of it comes from the Pune facility. You should put pressure on Gurgaon Centralised Customer Care to have the part despatched by Air since there is a Truckers strike on.
Old 8th January 2009, 12:30   #325
tsk1979's Avatar
Actually, the replacement should have happened when they saw bent pin, which they fixed. Its actually a manufacturing defect. I am worried that the transfer case etc., may also have issues which they may find only later. After all the suspension and the rail pressure unit has issues.
I will call up Gurgaon customer care and try to put some pressure. I called up regional office and they gave me 1800 number and I have left voicemail with my name and number, they are supposed to call me up shortly
Old 8th January 2009, 12:50   #326
Thanked: 253 Times
Tanveer, is there good reason to believe that on-the-fly shifts should not be done? I have been doing these freely, though I am a bit worried now!
To be sure, M&M Scorpio dealerships also probably do not stock 4WD drivetrain components.
On-the fly shifts could also be done on the Gypsy (and I did hundreds!) though there was a rider: ONLY in straight line situations. With the Borg Warner I have been doing even at turns!
Old 8th January 2009, 12:58   #327
tsk1979's Avatar
I have rarely done on the fly shifts, maybe once or twice. From what I read on online discussion forums(international), as well as told my Mr, Atul of Autolinks, on the fly shifts should be avoided in all vehicles.
However in my case I suspect that it was a manufacturing defect in the hubs.
The hub connects the front wheels to the driveshaft. Inside the hub the driveshaft gear goes in. In my vehicles case, the hub had something cracked inside it which caused it not to grip the driveshaft. It was occasionally gripping.
So when we climbed a mini mountain of sand, the rear wheels were rotating, the front was rotating in a jerky fashion.
Once they opened, and discovered the fault, after that it stopped rotating at all, as after opening the crack widened.
Meanwhile I have spoken to workshop and the part has arrived. However the Delphi guys are yet to give confirmation as to when they will come. If they are coming tomorrow, I can give vehicle today noon, and collect it on saturday morning
Old 8th January 2009, 13:11   #328
suman's Avatar
Thanked: 257 Times
I go off the beaten track once a month (in Gurgaon, there are so many that one doesn't really have to hunt around) just to make sure that all is well; to be honest, I've ALWAYS engaged 4H on the fly. Yes, I do stop for 4L but never for 4H. It is a pain doing the 20-30 odd meters in reverse direction to unlock the hubs but I do that as well.
I hope you didn't misunderstand what Atul said Tanveer - 'cos when I separately cross-checked with him a couple of weeks back, he confirmed that it was absolutely OK to use shift-on-the-fly for 4H.
Old 8th January 2009, 13:26   #329
Thanked: 253 Times
Suman, only about a meter of reverse is required! Max 2 to 3 meters if there is any doubt.
Old 8th January 2009, 13:54   #330
suman's Avatar
Thanked: 257 Times
LOL, old age getting to me, too many zeroes I meant 2-3 odd meters! The manual recommends a minimum of three meters though.
The Abominable (Skoda) Yeti *UPDATE* 20,000Kms Update on Pg.14 SushilBajpai Test-Drives & Initial Ownership Reports 281 8th December 2016 16:08
4x4 Power, My Skoda Yeti Elegance. UPDATE: 63k kms up on page 6 Akshay1234 Long-Term Ownership Reviews 91 8th December 2016 01:11
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Black Storm-Safari GX 4x4. EDIT : 70k Kms update Lukeskywalker Long-Term Ownership Reviews 49 6th May 2013 16:58
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
