Old 21st March 2009, 22:18   #931
Thanked: 253 Times
Originally Posted by dadu View Post
Its a pressurised tank, controlled by the valve in the cap which acts as the gateway. When vaccum is created it sucks and when pressure it expels.
That means it is the standard system as found in most cars.
In which case what I had posted earlier is correct. And basically there would be TWO valves in the radiator cap.
Originally Posted by anupmathur View Post
Radiator coolant heats up, expands and this force opens the spring loaded valve to send some coolant to the overflow tank.
How does it get back into the radiator when the coolant contracts on cooling? There's a spring loaded valve in the way, fitted for the wrong direction, remember!
So is there another valve that enables the reverse flow? Yes there is a vacuum valve and if this jams, coolant can never get back into the radiator, bent pipe or not!
And, if the radiator has even a small leak, vacuum will never build up to open the vacuum breaker valve; instead atmospheric air will keep getting inducted whenever the coolant contracts on cooling!
Am I missing something?
Dadu, is this the kind of system?
Old 21st March 2009, 23:24   #932
tsk1979's Avatar
Thanked: 16,421 Times
The pipe from radiator cap is connected to the bottom of the coolant tank.
The pipe at the top of the coolant tank is the overflow pipe.
Anyways, she is back, autolinks people delivered it around 8pm.
New radiator. Sounding much smoother now. They did some adjustments for erratic idle, so I will know only tomorrow morning if it really is okay now.
Tomorrow I get a new tire also from KB
Old 22nd March 2009, 07:53   #933
Thanked: 253 Times
New radiator. .....
Hope they have replaced the radiator cap too!
Old 22nd March 2009, 11:24   #934
SS-Traveller's Avatar
Thanked: 11,627 Times
Hi Tanveer, How was the cold start-up in the morning? And did you get your tyre?
Old 22nd March 2009, 13:50   #935
tsk1979's Avatar
Let morning happen buddy! ITs still too early. Don't you know on a sunday morning is 4pm
Old 22nd March 2009, 14:06   #936
Thanked: 253 Times
Let morning happen buddy! Is still too early. Don't you know on a sunday, morning is 4pm
Classic case of generation gap? DocSS & Tanveer.
Old 22nd March 2009, 14:20   #937
And here you are, killing so many members due to asphyxia, because all of us are waiting with bated breath to know if your car starts properly in the morning or not... Pheeeew... Can't hold breath any longer.
Old 22nd March 2009, 14:30   #938
Thanked: 253 Times
...because all of us are waiting with bated breath to know if your car starts properly in the morning or not... .
LOL, no one said anything about morning sickne...err..start, it was about cold start!
Lil' silly to assume that it happens in the morning!
Old 22nd March 2009, 23:47   #939
tsk1979's Avatar
Well it always starts properly, just a little grrr grrr, but then beasts do grrr grrr, right.
Anyways today I started at noon, so no issues, early morning starts...? I don't have any idea, will do and see. Even if it does, no big deal, its been doing that since 10K kms
Anyways I did more than 100kms today. She behaving fine, hopefully this continues, couple of long drives should do the trick, and verify that things are really okay!
Old 23rd March 2009, 10:58   #940
Jaggu's Avatar
Thanked: 8,685 Times
That article posted by Jaggu would have you believe that coolant from the expansion tank will not go back to the radiator. Hence the confusion.
Arre i did not post it to confuse you, i was referring the more modern system on assumption that you know of the older systme. Simple explanation is here for the older system HowStuffWorks "How Car Cooling Systems Work" but its too brief and doesnt mention the more modern systems. The cap has two circuits, a pressure valve and a vacuum line (some have thermostatic valve also on the cap).
Safari system is a mix of both, mostly due to lack of space (me guess). For the pressurized overflow tank to work, i understand the tank itself has to be at a higher level than the radiator upper chamber. This might be the reason why they went the complex hybrid path.
Anyways back to Tanveer, hope you have a peaceful drive this time around. What happened to the "Infamous" tube, is it IN or OUT now. How about the oil leak, suspension sound etc, all sorted?
Old 23rd March 2009, 11:35   #941
tsk1979's Avatar
The new tube is "out".
I will let it be that way.
Suspension sound went away on changing tie rod end.
And oil leak has also gone.
It was at the joint of 2 pipes.
Old 23rd March 2009, 12:01   #942
Thanked: 2,470 Times
Tanveer,
How was the early morning start and did you drive it around.
Any new developments on your Safari
Old 23rd March 2009, 12:10   #943
tsk1979's Avatar
It was okay, but then the temp was high due to sunlight.
since she's behaving properly now, things should be okay.
Keeping my fingers crossed. One longish trip planned before the 15K service
Old 23rd March 2009, 15:32   #944
tsk1979's Avatar
Default Are the troubles finally over....?
With the breakdown behind her, and the radiator changed I hope most of the troubles are over.
Things to do now
1. New Tyre. will get it today
2. Try to getup at 5am and check cold start surging problem(this is difficult)
3. When I visit service center check which error code is there. Since service light was coming on I suspect there may be some error code
15K service is just a couple of weekends away. Am already planning a long trip. If I complete 14K by this weekend, will service her sometime next week, otherwise its after the trip.
Instead of coolant there is water in radiator, as they want to check if she is still loosing water. There seems to be no sign of any such troubles for now!
Old 23rd March 2009, 15:50   #945
suman's Avatar
Thanked: 257 Times
LOL, good to see a short & simple title without the diseased horses & nightmares
Good luck & hopefully its all behind you now. Start driving!
The Abominable (Skoda) Yeti *UPDATE* 20,000Kms Update on Pg.14 SushilBajpai Test-Drives & Initial Ownership Reports 281 8th December 2016 16:08
4x4 Power, My Skoda Yeti Elegance. UPDATE: 63k kms up on page 6 Akshay1234 Long-Term Ownership Reviews 91 8th December 2016 01:11
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Black Storm-Safari GX 4x4. EDIT : 70k Kms update Lukeskywalker Long-Term Ownership Reviews 49 6th May 2013 16:58
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
