Old 9th April 2009, 09:13   #991
Is that so? I missed out that one. I recollect that he has been complaining about the needle flickering. However I cannot recall engine noise also when he mentioned "surge".
If that is really so, my bad and I apologise.
On my vehicle the flicker is much less pronounced and hearing the engine sound difference is difficult.
kingshukt is offline   Reply With Quote
Old 9th April 2009, 09:31   #992
tsk1979's Avatar
Thanked: 16,421 Times
In my vehicle you can easily make engine note going grr grr grr
Old 9th April 2009, 18:20   #993
Shyamtanu's Avatar
Something is causing an irregular burning.. or uneven fuel injection.. typical if you have injector tips (one/two of them) dirty... or for other reasons.
Shyamtanu is offline   Reply With Quote
Old 9th April 2009, 18:56   #994
Jaggu's Avatar
Thanked: 8,685 Times
Its something to do with engine breathing (intake which can include EGR) or fueling, nothing to do with rpm meter, engine oil viscosity and diesel temperatures.
Engine breathing mostly since there is a direct correlation to the air temperature, so mostly EGR as suggested by others.
Old 10th April 2009, 13:16   #995
Thanked: 245 Times
To rule this out,the easiest option for tsk is to run it through SystemD, next option would be to look at the mechanicals etc.
Its a step by step rule-out A B C process, so tanveer let us know once you have tried the basic, i.e. System D.
Old 10th April 2009, 13:23   #996
tsk1979's Avatar
dadu, I don't think system D needs to be tried. The reason is this.
When I reported this problem, the service center cleaned the injectors and also checked the diesel filters.
there was no problem of gumming etc.,
I think system D does the same, clean injectors.
Moreover this problem is not new.
this is before I started seeing the service light and they had to change HP lines etc., to make this problem go away.
The only thing which I can think of is the EGR. Somebody informed me that sometimes EGR may have a problem such that it does not completely work when its cold. This can cause surging.
At the next service which is coming up soon, they are going to look at EGR.
Old 10th April 2009, 23:14   #997
Thanked: 245 Times
Erratic and un-even idling, surging, ‘pinking’ are known symptoms of injector problems, primarily due to heat soak. Thats the reason I am trying to sell you System D as a solution.
Although its your decision and option, it does not cause any adverse affect.
PS: I have seen the way they clean injectors and trust me the additives are more effective (saying this by experience).
Old 10th April 2009, 23:51   #998
condor's Avatar
Thanked: 4,898 Times
@TSK, System-D will cost you Rs. 250/-a bottle . Far cheaper option in terms of time & money than going to the TASS.
The Safari doesn't like it ? then give the Indica a treat. She'll love you for it !
Old 10th April 2009, 23:55   #999
tsk1979's Avatar
Ok, I will try system D.
I actually used to use it regularly Indica some time back
Old 11th April 2009, 08:10   #1000
jkdas's Avatar
Thanked: 1,436 Times
33500 kilometers. No System D or anything. Used it once, maybe for 2-3 tank fills, thats all.
I will try it again if someone can swear it will help give better FE. My engine is already smooth and hence doubt if an additives can help more.
Old 11th April 2009, 08:57   #1001
phamilyman's Avatar
Thanked: 3,526 Times
OT: 33500km in 13 months? Awesome. How come no triplogs from you man!
Old 11th April 2009, 14:27   #1002
Shyamtanu's Avatar
Do you use premium diesel all the way?
Old 11th April 2009, 14:48   #1003
jkdas's Avatar
No time for trips. All I do is drive to Cochin/Shertalla/Kottayam once or twice a month and daily drive to office.
Used it for 3-4 tank fills sometime back. Now only use if I couldnt get the other brew. Now on HP diet from COCO, for last 10k plus.
Old 11th April 2009, 17:14   #1004
Thanked: 146 Times
...I will try it again if someone can swear it will help give better FE. My engine is already smooth and hence doubt if an additives can help more.
JK,
Don't try to fix if it ain't broken!
HappyWheels is offline   Reply With Quote
Old 15th April 2009, 02:21   #1005
maglev's Avatar
Thanked: 90 Times
1. On cold start the rpm surges between 800-1100. TASC guys could not find anything wrong on the analyzer. Guess this one is a mystery
The RPM surging was present in my dads Octavia as well ranging from 800-1200, rectified after routine service & replacement of the air mass sensor costing around 18000/- with labor & taxes included!!
PS: Rs 18000 only for the air mass sensor.
maglev is offline   Reply With Quote
The Abominable (Skoda) Yeti *UPDATE* 20,000Kms Update on Pg.14 SushilBajpai Test-Drives & Initial Ownership Reports 281 8th December 2016 16:08
4x4 Power, My Skoda Yeti Elegance. UPDATE: 63k kms up on page 6 Akshay1234 Long-Term Ownership Reviews 91 8th December 2016 01:11
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Black Storm-Safari GX 4x4. EDIT : 70k Kms update Lukeskywalker Long-Term Ownership Reviews 49 6th May 2013 16:58
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
