Old 15th April 2009, 09:05   #1006
jaysmokesleaves's Avatar
Thanked: 1,258 Times
Originally Posted by maglev View Post
PS: Rs 18000 only for the air mass sensor.
Are you sure they replaced the sensor with a NEW one or just cleaned it and put it back while charging you a bomb for it ?
jaysmokesleaves is offline   Reply With Quote
Old 15th April 2009, 09:22   #1007
greenhorn's Avatar
Thanked: 1,516 Times
System D reduces the roughness on my TCIC indica, but these days I have my doubts if its robbing performance a bit. FE never was a strong point , and i dont intend to measure it. Jk, if you have given away the bottle of system D that you had , ping me. Can lend you mine for the trial
Old 15th April 2009, 09:40   #1008
jkdas's Avatar
Thanked: 1,436 Times
Guess its for the Skoda and hence hope they had put in a new one !
Old 15th April 2009, 12:16   #1009
tsk1979's Avatar
Thanked: 16,421 Times
Looks like old troubles are coming back.
Yesterday on a smooth road at 90kmph I was forced to hit the brakes due to a cyclist crossing the road without looking.
The rear went towards the left as the rear wheels locked up and by the time I stopped she was perpendicular to the road
Old 15th April 2009, 12:35   #1010
greenhorn's Avatar
When I started reading, I thought it was the return of the C.E.L. god knows which is worse
Old 15th April 2009, 12:42   #1011
suman's Avatar
Thanked: 257 Times
I'm quite intrigued by this problem that you have faced on multiple occasions. Tell me, do you give any steering inputs at all? Or do you just brake hard & let go of the steering. I mean - if you're braking hard & the back is stepping out of line, surely some inputs on the steering would help?
Then again, if you're just trying to see how far the back steps out, I'd say its a potentially dangerous experiment.
Old 16th April 2009, 02:04   #1012
Shyamtanu's Avatar
Are you sure the front and rear wheels were perfectly aligned in straight line, if not, typically in panic braking, this can happen. Try this if you can manage in a straight, lone stretch, when you are cruising at absolute straight line.. but you may like to keep it within 80 for safety?
Shyamtanu is offline   Reply With Quote
Old 16th April 2009, 03:47   #1013
maglev's Avatar
Thanked: 90 Times
They did as they didn't have it in stock & we had to pay Rs: 5000/- as advance, as well as wait for about 3 weeks! as it comes from abroad!
Also not only did the surging but overall performance & efficiency improved as well.
maglev is offline   Reply With Quote
Old 16th April 2009, 08:01   #1014
tsk1979's Avatar
I was cruising in a straight line, when the cyclist came I slammed the brakes hard. Not step on them hard, but hard.
The tail started stepping out.
I gave opposite lock also and it somewhat controlled the skid, but still the car went sideways quite a bit.
Its not as bad as it used to be. Earlier it would skid sideways totally and I would end up facing the direction I came from if I did not leave the brakes!
Yup, I will do some more experiments.
But you know what, every time this has happened, the car has skidded in a way that the front turns towards right, and rear goes towards left.
If it had to do something with driving direction I would have seen skids both ways, left and right
Our 3.0 safari back home had this problem, and one visit to service center rectified it. Only some adjustment was done.
Old 16th April 2009, 08:16   #1015
Just yesterday afternoon I stood on the brakes at 120kph to avoid flying over a huge hard speedbreaker. Noticed it at the last second. Although my wheel alignment is out of tune and is due anyday now, the Safari tracked straight. However, I do make sure to avoid steering input while braking, just making sure the steering is straight.
Somehow, I have not heard of such a thing happening on any other Safari and it does sound strange that this problem is re occuring so soon after TASS intervention.
I really hope its sorted out soon.
Cheers,
J
Old 16th April 2009, 08:24   #1016
tsk1979's Avatar
Its actually happening 7000kms after it got fixed.
The 15K service will happen next weekend, This is one more item on the list!
Old 16th April 2009, 09:06   #1017
Whenever you go back to TASS just have them check the brake bias also.
Non uniform application of brake pad pressure on the drum / brake disc between front and rear brakes can also result in what you have described.
EDIT: Does the Ex 4*4 come with ABS ?
Also see this in Wikipedia : Fishtailing - Wikipedia, the free encyclopedia
kingshukt is offline   Reply With Quote
Old 16th April 2009, 11:33   #1018
tsk1979's Avatar
Nope, there is no ABS. So the wheels will lock when I hit brakes hard.
I think there is some problem with brake bias adjustment mechanism.
Old 16th April 2009, 18:24   #1019
smsrini's Avatar
Thanked: 272 Times
Default Engine Surging
TSK,
My car is showing signs of the Engine surging on cold start. Have observed it in the last 2-3 days. Has this got something to do with the injectors change ?
smsrini is offline   Reply With Quote
Old 16th April 2009, 22:56   #1020
tsk1979's Avatar
No idea. In my case it was there even before the service light started showing up.
Take a video on your mobile phone to show TML guys when you take her out to service.
10K kms after this started happening, I have observed no apparent side effects to this problem.
I don't know whether its fixable.
I have stopped worrying about it.
The Abominable (Skoda) Yeti *UPDATE* 20,000Kms Update on Pg.14 SushilBajpai Test-Drives & Initial Ownership Reports 281 8th December 2016 16:08
4x4 Power, My Skoda Yeti Elegance. UPDATE: 63k kms up on page 6 Akshay1234 Long-Term Ownership Reviews 91 8th December 2016 01:11
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Black Storm-Safari GX 4x4. EDIT : 70k Kms update Lukeskywalker Long-Term Ownership Reviews 49 6th May 2013 16:58
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
