Old 7th July 2009, 14:20   #1156
m_upreti's Avatar
Thanked: 311 Times
Hi akas, we discussed this before.
Legal recourse is still too complicated in India. Further, not much can be done if the company & dealership are taking care of the issues under warranty.
Originally Posted by akas_chauhan View Post
@tsk
Why do not you lodge a complaint in consumer court. No doubt you were delivered a defective Piece. This vehicle costs you your hard earned money and piece of mind.
Whatever feel good factor i had about safari all gone after going through this thread.
Hope either your car's problem got resolved( which does not seem like) or you get a replacement.
m_upreti is offline   Reply With Quote
Old 21st July 2009, 22:58   #1157
tsk1979's Avatar
Thanked: 16,421 Times
Default The Tamasha starts again
Watch this for yourself
Taken today evening engine temp near center.
Old 21st July 2009, 23:52   #1158
I think its about time you updated the topic heading to "Safari EX 4X4, a terminally ill white elephant"!
bhp1 is offline   Reply With Quote
Old 22nd July 2009, 07:14   #1159
4x4addict's Avatar
Thanked: 2,668 Times
Tanweer, if I may make a suggestion just forget about this and accept it. Don't bother to spend any more time on trying to fix this. For the most part it shouldn't affect your driving so just enjoy the other parts of the vehicle. Safari's are generally meant to flogged for about 100K kms and then sold. It's not something you keep for long anyways. Hopefully in a year or two there will be better options including the latest SUVs from Mahindra and Tata.
4x4addict is offline   Reply With Quote
Old 24th July 2009, 10:55   #1160
ankur_gupta10's Avatar
Thanked: 50 Times
Today I got her back,
There were 2 job cards. one opened last thursday, and other one this tuesday.
For the service light 4 HP lines were changed.
Delphi people changed the injectors(not in system since delphi directly changed that)
For erratic idle, the problem was solved by replacing a 24 rupees washer(not under warranty)
A case of dug a mountain found a female mouse.
So after a week, and expense of 24rs from my side, fluctuating rpm on cold start problem has been solved, hopefully once and for all!
I have a 2.2 Safari LX which has done around 25k KM. I am noticing an issue recently that when i am accelerating v gradually, then around speed of 80 and 2k RPM there starts a minor jerking of the car and speed/RPM starts fluctuating. I like the idea of catching that on mobile video, and would do that. Can u let me know which washer u got changed? i will have checked that on my safari.. I have started reading your thread backwards to understand how much woes and joys are shared by a fellow safari owner.. Thanks for all the details posted, i was missing such a thread. Feels good to be on Team BHP
ankur_gupta10 is offline   Reply With Quote
Old 24th July 2009, 12:18   #1161
tsk1979's Avatar
This problem does not bother me at all, what troubles me that what if its a precurser to some major problem. Thats why I want to get to the root cause
It was some washer sitting at the injector seat.
however in your case I think the issue is different. So you are saying that when you cruise at 80kmph with constant throttle input, the vehicle actually keeps missing. In that case it could be a problem with fuel delivery system.
Old 27th July 2009, 12:15   #1162
tsk1979's Avatar
Default One Year Done- Almost 20K
The ODO stands just shy of 20K mark as she does her one year.
Quite an eventful year I must say.
2 breakdowns, some scares, lots of circus and a perpetually erratic idle.
Tomorrow is her date with Maike Walahs, as they scratch their heads over the mystery of the erratic idle.
800-864rpm fluctuation happens almost all the time now. Nothing to do with cold or hot engine.
Usually it starts when you come to idle state after a 2000rpm+ run.
If idle is quiet, all you need to do is rev to 3000rpm+ and leave the accelerator in neutral.
Its starts grrr grrr grrr and does it for a few minutes and then quietens down.
Other things going slightly wrong are the first gear. It takes a lot of effort to slot into first.
And the power steering seems to be very tight. Driving on twisties is a pain. I never realized this till I drove another safari and found the steering to be much lighter.
Old 27th July 2009, 12:18   #1163
suman's Avatar
Thanked: 257 Times
Centre Pin needs greasing.
Get that Gearbox thing checked out - shouldn't be happening.
Old 27th July 2009, 12:22   #1164
tsk1979's Avatar
Will be giving it at Sterling tomorrow. I think they will adjust something in the gears to make them more pliant or something, however the proper service will happen at Autolinks in September after I am back. (30K service)
Hopefully Noida-Delhi line will be running by then, and even if I have to leave car there overnight, coming back to Noida won't be a big pain.
The thing worrying me most is this erratic idle.
Old 27th July 2009, 12:34   #1165
suman's Avatar
Thanked: 257 Times
I'd be bloody worried if it wasn't resolved before I headed out on a trip to Leh
You never know what the rarefied air may do in terms of aggravating it.
Old 28th July 2009, 14:30   #1166
tsk1979's Avatar
Default Finally are the troubles over?
Today morning 9:50am I gave the car to Sterling again. The same head tech took her in.
Changed washer back, and saw problem lessening.
However solution was elusive.
Then he changed the ECU..
The problem went away.
No erratic idle, no rough idle, and the engine sounds a lot smoother too.
So at almost 20,000kms, she has a new "Brain", and thankfully this fixed the problem.
Apart from that center pin greasing was done.
Total cost = 225rs
ECU changed under warranty.
Old 28th July 2009, 14:38   #1167
simply_sunny001's Avatar
Thanked: 15 Times
congrats Tanveer that finally the erratic idle is gone and safari feels smoother.
but i would still ask you to keeo observing and trying to reproduce all the problems that you have had.
BTW can you confirm that the Old and New ECU were at the same firmware version ?
cheers
simply_sunny001 is offline   Reply With Quote
Old 28th July 2009, 14:39   #1168
Thanked: 146 Times
Seems like there is a mass change of ECU in order.
Read that ECU change was done for two vehicle here at Bangalore, Concord.
So TATA, instead of doing a mass recall (something they obviously want to keep away from) and do the correction, as doing it as and when the vehicle comes for service or comes with an issue.
HappyWheels is offline   Reply With Quote
Old 28th July 2009, 15:03   #1169
tsk1979's Avatar
don't know how to check firmware, the warranty claim shows ECU replacement.
However what I find funny is that no other safari on this forum had this issue!
Old 28th July 2009, 15:03   #1170
svsantosh's Avatar
Thanked: 1,444 Times
Respected Tanveer (for your patience with your car)
How long the std warranty last on a Safari? 18mths unlimited KMS?
Did you get the extended warranty?
Did you bother to check out the cost of the ECU had there been a OUTofWARR incident?
The 1 on my Indigo CS costs approx 18K from Delphi...!!! GOT it changed last month..!!
I have taken a 'SowGun' A.K.A OATH unto Myself - I am SURELY getting rid of my TATA product BEFORE the WARR+ExtWarr Expires...!!!
Considering your experience with a Better TATA product and this one - WILL you retain this car post Warr period???
------------------EDIT-----------------
Happywheels
+1, my ECU was changed by True Sai works, Hosur (@ Delphi Blore office)
svsantosh is offline   Reply With Quote
The Abominable (Skoda) Yeti *UPDATE* 20,000Kms Update on Pg.14 SushilBajpai Test-Drives & Initial Ownership Reports 281 8th December 2016 16:08
4x4 Power, My Skoda Yeti Elegance. UPDATE: 63k kms up on page 6 Akshay1234 Long-Term Ownership Reviews 91 8th December 2016 01:11
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Black Storm-Safari GX 4x4. EDIT : 70k Kms update Lukeskywalker Long-Term Ownership Reviews 49 6th May 2013 16:58
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
