Old 4th August 2008, 10:17   #106
6. Clutch adjustment to make it softer
On the clutch Pedal Hard bit...
The clutch pedal has a spring for its return. A dainty piece of work.
Grease the appropriate areas after understanding the mechanism and the clutch will feel softer
kingshukt is offline   Reply With Quote
Old 4th August 2008, 10:50   #107
suman's Avatar
Thanked: 257 Times
Also noticed the first scratch. A small one on the bumper. Most probably at Lajpat nagar when she was parked getting seat covers.
Glad to hear that the service went off OK - was the scratch noticed when you handed her over for service or after you got her back?
Old 4th August 2008, 11:22   #108
deepaktpatil's Avatar
Thanked: 93 Times
Originally Posted by kdeepakk View Post
Mods Sorry for OT, but its related to Safari. I dint wanted to create a new thread.
As per latest info received from my source who is closely related with Tata, The new safari will be launched in end of 2009 or early 2010. The engine specification will 2.6ltr, around 160bhp & new interiors which will be very close to Toyota standards.
It will be released across world at the same time & it will be matching all the international standards which is related to automobiles...
This is the info from my source, nothing official.
deepak
Deepak,
Thats too far to think of isnt it. I remember the new Safari 2.2 news coming on team-bhp sometime early in 2006 and it said launch will be soon but it took more than 1.5 years to launch . So I suspect the same thing even if its said 2009 end timeframe I think it will be 2010 mid or end to see this vehicle.
Anyway its interesting news especially with the specs, thanks for posting. You should have created it in a separate thread as it will get lost here in case somebody has additional news or comments.
Deepak
deepaktpatil is offline   Reply With Quote
Old 4th August 2008, 11:41   #109
tsk1979's Avatar
Thanked: 16,421 Times
It was noticed after service, but the job card copy which was given to me had it marked. It very small and you miss it unless you look there!
The black plastic of the bumper is visible underneath!
But its Delhi, so its understandable. I guess I will get minor touch up done some time.
As for the clutch, its was more of an adjustment job, so that clutch modulation is better.
The gears are easier to engage now.
Old 4th August 2008, 12:24   #110
Thanked: 146 Times
So, got your first 'scratch', did you!
Anyway, one for the road is always good. And better that it is something that can be fixed thru a minor touch up.
Good that you got the rattling sound fixed. That is one thing that gets on your nerve. I have the rattling on my Alto for ages now. Mostly drive with window closed or placed at a specific point,so that it does not rattle. MASS was soooo unsuccessfull in rectifying this!
HappyWheels is offline   Reply With Quote
Old 4th August 2008, 12:27   #111
Thanked: 245 Times
Safari khandit ho gayee hai. Touch it up yourself using a thin brush.
Old 4th August 2008, 15:42   #112
tsk1979's Avatar
Default Skid plates
When the vehicle was on ramp for inspection of tilted front sump guard(which is a feature not a bug), I noticed pretty heavy skid plates all over, except for the transfer case.
Are these skid plates only on 4x4 or even the 4x2 have them. Pretty thick stuff made of metal
Old 8th August 2008, 14:25   #113
harjeev's Avatar
Thanked: 256 Times
3. As I mentioned earlier what I thought was a AC compressor problem(turning off at idle on throttle input) turned out to be a feature. At narrow parkings where you have to go back and forth quite a bit, a lot of throttle blipping is needed. Won't this shorten the life of the compressor clutch?
Hi TSK
could you please elaborate on this issue/ feature?
I too sometimes feel that the compressor has switched off when driving or sudden acceleration. Before reading your post I thought that it was just me.
further it happens sometimes and not always.
harjeev is offline   Reply With Quote
Old 8th August 2008, 14:34   #114
tsk1979's Avatar
while parking now I don't use the accelerator pedal at all, so no issues, When you suddenly acclerate the compressor cuts off, Its a ECU feature, and It happens always, They showed me on another safari too.
Old 9th August 2008, 10:19   #115
chaxy's Avatar
Thanked: 16 Times
Attachment 35005
Attachment 35006
What are the two rollers like components in the 2nd pic? What purpose do they serve?
chaxy is offline   Reply With Quote
Old 9th August 2008, 15:36   #116
Thanked: 245 Times
There are two black and two blue, those are differential vibration dampners.
Old 19th August 2008, 08:04   #117
tsk1979's Avatar
Default 2000kms update
In 20 days, 2000kms have been dispatched more than half on the highway, 5 in much and slush and almost 100 on winding roads, and in traffic jams.
Aggregate FE of all tank fulls since purchase(I maintain a logbook) is 10.5
Full city driving gives me 10.4, and highway should be around 14, but the offroading, and mountain traffic jams mean she's registering a low figure.
But now I know what petrol car owners feel when a tankful is 2100rs
On the other hand, I get a range of 700+kms which is unthinkable in the indica.
So whats changed in these 2000kms?
1. No new rattles have crept up, which is amazing considering the kind of roads and terrain she has done
2. The gear shift has become smoother, ditto for the clutch
3. The pickup is better now and engine seems to be livelier
But not all is bed of roses.
When she is cold, and I start and then depress or release clutch, sometimes I hear a "clang".
I also think I hear something akin to some metal plate vibrating when I reverse on an incline with some throttle input. This sound comes when the clutch pedal is transforming from press to release.
Not always there though.
I was also able to use 4x4 extensively, both 4L and 4H, and I must say I am impressed. She is no gypsy, but for our needs more than adequate.
On the accessory front the addition has been new seat covers.
Thats all for now folks!
Old 19th August 2008, 08:39   #118
jkdas's Avatar
Thanked: 1,436 Times
I have the same opinion with some minor changes.
Diesel costs more here
I get the same mileage. Take to bad roads and narrower NH my highway driving is almost like city driving now.
15k and no rattles. My Santro would have got bend rim, a suspension job and what not. Kudos to Safari for excelling in that.
I think I too have the clang as I need to reverse first and engage 1st gear from a sloppy curve every morn.
Old 19th August 2008, 08:39   #119
1100D's Avatar
Thanked: 2,503 Times
Looks like its warming upto you. Have any "off-road" snaps?
1100D is offline   Reply With Quote
Old 19th August 2008, 09:10   #120
Thanked: 245 Times
And any details on the Seat covers, are they OEM (Safari tag) and cost.
The Abominable (Skoda) Yeti *UPDATE* 20,000Kms Update on Pg.14 SushilBajpai Test-Drives & Initial Ownership Reports 281 8th December 2016 16:08
4x4 Power, My Skoda Yeti Elegance. UPDATE: 63k kms up on page 6 Akshay1234 Long-Term Ownership Reviews 91 8th December 2016 01:11
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Black Storm-Safari GX 4x4. EDIT : 70k Kms update Lukeskywalker Long-Term Ownership Reviews 49 6th May 2013 16:58
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
