Old 4th August 2009, 10:53   #1216
tsk1979's Avatar
Thanked: 16,421 Times
Yes, they changed Fuel pump and the pressure valve and lots of other components, nothing helped.
Right now the car is at service center, and they have lodged a complaint again with central TML, and they will guide by phone. If nothing works after all this, they will send an engineer from head office Gurgaon.
Old 4th August 2009, 12:31   #1217
forgot to mention! is the pressure control valve or metering unit. ( these are the two types of pressure valves involved in crdi, a third type is there CPC its a mix of both former mentioned valves.) checked? .
also since the surge is at idling, injection timing is most probably the culprit.
electronic causes. are as i mentioned in my earlier posts.
if possible check the rail pressure sensor. it might be sending wrong signal at idling?
have you ever used any kind of tuning box
did you check the cam and crank position sensor. check that also.
if any tech guy comes to the service center. then just tell him that at 0% ACC ped position , EPM module is probably giving interupt signal at wrong time or for more time than normal for the pre tdc injection some guys call it as pilot injections too.
anyways keep us posted.
Thomas8700 is offline   Reply With Quote
Old 4th August 2009, 12:49   #1218
tsk1979's Avatar
Earlier rail pressure sensor had an error code, and after changing injectors that went away.
As for Cam sensor, thats an interesting angle, but there are no error codes in the system form any sensor now.
They checked the ignition timing, and thats correct.
Will keep you posted as updates comes.
Old 4th August 2009, 13:01   #1219
suman's Avatar
Thanked: 257 Times
To the best of my knowledge, any issues with either of these will resulting in the vehicle not starting - it will not cause any surge in rpm.
Old 4th August 2009, 13:03   #1220
Thanked: 24 Times
Tsk, one thing is for sure, I think you have gone through soo many issues with the Bull that I think now you are the most knowledgeable person regarding the Safari 2.2 in the forum.
musicmanaman is offline   Reply With Quote
Old 4th August 2009, 13:17   #1221
Thanked: 253 Times
Suman, I think these sensors, or just one of them, would be responsible for giving the ECU feedback on actual rpm too.
An error (or delayed signal or whatever) could cause rpm to fluctuate.
It will not always be the case that an error will altogether prevent the engine from starting. That would be an extreme/catastrophic failure.
Old 4th August 2009, 13:29   #1222
tsk1979's Avatar
The rpm does not fluctuate all the time.
When I start her up in the morning, rpm keep fluctuating.
this goes away once engine is warm, even with AC on there is hardly any fluctuation.
Now when I drive at rpms above 2500rpm, and then come back to idle, for a few minutes the rpms keep fluctuating.
Without AC its very less, infact it lasts for few seconds and then its mostly stable, with slight fluctuations now and then.
AC on magnifies this.
If I have to demonstrate it to service center, all I have to do is rev her up to 4000 once, and once RPM needle comes back to idle speed its grrr grrr grrr for few minutes, and then it stabilizes.
The interesting thing is that whenever something like ECU/injector/washer etc., is changed, the problem goes way for 200-300kms after which ECU learns again how to dance.
I spoke to service center, they have lodged a complaint with TML on the website system dealers have and are awaiting reply
Old 4th August 2009, 13:34   #1223
theMAG's Avatar
Thanked: 1,572 Times
Tan - sincere suggestion: if the vehicle is running smoothly and reliably otherwise, sweep this problem under the rug and enjoy the vehicle.
Old 4th August 2009, 13:35   #1224
Rahulk76's Avatar
Thanked: 204 Times
IMHO points to Crank Angel Sensor,
The crank angel sensor is fitted on the clutch housing. Can you have it cleaned and checked once ?
Crank Sensor is a magnetic field transducer and generates a voltage output propotional to the rate of change of the magnetic field near a "Missing tooth" configuration. It monitors the rotating speed (rpm), the position of the crankshaft / piston ans speed fluctuations of the engine and gives continuous feedback to the ECU. In other words it gives engine speed and piston position signal to the ECU. The sensor gap should be 1+-0.5mm & should be measured using feeler gauge.
Rahulk76 is offline   Reply With Quote
Old 4th August 2009, 13:49   #1225
tsk1979's Avatar
I have to go to Ladakh, thats why I am worried. What if it exposes some bigger problem at that altitude
I will ask workshop guys too look at that angle also!
Old 4th August 2009, 14:54   #1226
Thanked: 253 Times
You're right, Rahul.
The angle sensor also senses the rpm.
Old 4th August 2009, 15:18   #1227
suman's Avatar
Thanked: 257 Times
Well, it will be the case for the cam sensor - it prevents the engine from starting if it senses that the cam is misaligned. That is the only purpose of its existence.
But yes, in the case of the crank sensor, it does monitor rpm as well. However, if excessive dust accumulates on it, it refuses to let the engine start.
Old 4th August 2009, 15:52   #1228
Rahulk76's Avatar
Thanked: 204 Times
That information is straight from Manual, has to be right
Old 4th August 2009, 16:47   #1229
Thanked: 253 Times
That means this sensor verifies the camshaft position with respect to the crankshaft.
Is there such a sensor in use? If this were the case the sensor would cut the engine in case of timing belt breakage too?
Old 4th August 2009, 16:55   #1230
Rahulk76's Avatar
Thanked: 204 Times
It wont let it start..It wont pitch in when it is already running would it. But by then the damage would already be done
The Abominable (Skoda) Yeti *UPDATE* 20,000Kms Update on Pg.14 SushilBajpai Test-Drives & Initial Ownership Reports 281 8th December 2016 16:08
4x4 Power, My Skoda Yeti Elegance. UPDATE: 63k kms up on page 6 Akshay1234 Long-Term Ownership Reviews 91 8th December 2016 01:11
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Black Storm-Safari GX 4x4. EDIT : 70k Kms update Lukeskywalker Long-Term Ownership Reviews 49 6th May 2013 16:58
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
