Old 5th August 2009, 10:30   #1246
tsk1979's Avatar
Thanked: 16,421 Times
Safari has a cam angle sensor, thats all I know.
One question though. The car has run 10,000kms with this problem. So It won't break down due to this, right? If it won't I think I have had enough, and will live with it as an unsolvable problem
Old 5th August 2009, 10:42   #1247
n.devdath's Avatar
Thanked: 2,150 Times
If he was coming all the way from Pune, it would have been a different matter, but this guy is based in Delhi and he goes as far as jammu on customer complaints, Why can't he come to noida
Which is exactly why I am requesting you to meet him once and build your rapport, phir dekhna Sirji, Noida kya, aapke aangan mein aake gaadi repair karwayega, abhi, just chill and get your job done, and the job is "Rapport".
Old 5th August 2009, 10:44   #1248
tsk1979's Avatar
He will come there sometime during the day.
So unless I take the day off from office, no chance of meeting him.
I have mailed customer support and asked them to get an engineer to sterling. After all its Automobile sterling who send a mail to Tata telling them they can't fix problem.
If Delphi people can go to all workshops for problems, I think this guy will also come.
Old 5th August 2009, 10:46   #1249
anujmishra's Avatar
Thanked: 345 Times
To solve it in better ways. Better lodge consumer complaint at consumer forum for at least replacement of defective engine. After your numerous visit to TASS and calling TML engineers, so much of diagnostics your problem still remain as of day one.
You must be spending your much of time doing rounds of TASS and asking them to rectify the problem. Better if you seek advice to go to Consumer Court with all of your proofs of replacements, breakdowns, communication with TASS, TML etc.
Just my 2 cents.
anujmishra is offline   Reply With Quote
Old 5th August 2009, 10:47   #1250
tsk1979's Avatar
that is the last option. If my vehicle had been breaking down I would have done that.
Since this problem is a big niggle, rather than a breakdown causer, I want to give chance to TML to fix this problem first
Old 6th August 2009, 05:46   #1251
well... my accent had a power window problem during the rains when it used to get stuck midway. it took more than an year to get fixed. they told me.. come back when it rains. good part was that a complaint to HMIL made them run like crazy and the problem was fixed. they replaced the glass, the assembly, channels and the beading too.
Good things do happen to good people, but they take time.
being a tata indica owner too, i am used to trips between the Sterling noida and their CNG installer in okhla (close to sanya motors). One says take it to the CNG guy, other says take it to the tata guys.
niggles crop up... they get major at times. i have been following this thread very keenly and understand to some extent what you are going through - but that doesn't make me stop thinking that in year or so.. i'll buy a safari too.
I wish you all the best, the problem will get fixed.. just go with the flow..
saintsinner is offline   Reply With Quote
Old 6th August 2009, 09:08   #1252
suman's Avatar
Thanked: 257 Times
Originally Posted by anupmathur View Post
That means this sensor verifies the camshaft position with respect to the crankshaft.
Is there such a sensor in use? If this were the case the sensor would cut the engine in case of timing belt breakage too?
Yes, such a sensor is in use. It doesn't let the engine start. Period. As Rahul says.......
Originally Posted by Rahulk76 View Post
It wont let it start..It wont pitch in when it is already running would it. But by then the damage would already be done
Old 6th August 2009, 13:34   #1253
ankur_gupta10's Avatar
Thanked: 50 Times
Tata motors seems to be testing and learning at your expense and time. In warranty either they should fix the problem, or replace vehicle. They can then use your car in their lab for all research and development. I think this is really enough, you should go and launch a case against them, if you know a lawyer. Atleast they should give some sort of end date by when they would either fix or replace. This seems to be dragging forever. You are really too good to them :-)
ankur_gupta10 is offline   Reply With Quote
Old 6th August 2009, 16:23   #1254
tsk1979's Avatar
Yes, the vehicle is giving an unusual number of problems, but response from Tata has been good. All it takes is a mail to customer care to fix most things.
For example, the engineer will now come to Noida
In my opinion, its better to get problems sorted by Tata. Only if Tata had not responded to my problems, and not fixed all issues, I would have sought legal route.
Right now I am mostly looking out for show stopper issues, and ignoring niggles.
As of now, this rpm surging and slight roughness in gearshift is the only problem.
As for gearshift issue, this is apparent in many safari's and looks mostly to be a design issue rather than vehicle issue.
However a TD with the engineer will put all matters to rest hopefully.
Old 7th August 2009, 04:59   #1255
^^ so mr shantanu must be really happy that a tata engineer is finally coming to his workshop. the guys are pretty helpful there at sterling
Old 11th August 2009, 11:55   #1256
tsk1979's Avatar
Default white elephant at Sterling now., engineer here
Met the engineer.
He is currently working on the car. Hopefully things should be sorted out by evening.
Thankfully she did not start working properly at the sight of the engineer.
So he could easily see the problem first hand
Old 11th August 2009, 12:00   #1257
Thanked: 24 Times
Met the engineer.
Good to know the Engineer is finally in, I hope this time around all issues are resolved once for all.
musicmanaman is offline   Reply With Quote
Old 11th August 2009, 12:04   #1258
suman's Avatar
Thanked: 257 Times
Met the engineer.
So what did he say? Does he have any ideas - or is it another one of the usual hit-and-miss approaches?
Old 11th August 2009, 13:25   #1259
tsk1979's Avatar
Even I hope so
Well, he said he will try a few things, different from what he instructed on the phone. Hopefully, he will get to root cause. Otherwise the cycle will continue
Old 11th August 2009, 14:29   #1260
Met the engineer.
ah thats a good news for your beast, finally he could figure out the reasons for all and gets her in perfect shape you want, keep updating.
vijaythacker is offline   Reply With Quote
The Abominable (Skoda) Yeti *UPDATE* 20,000Kms Update on Pg.14 SushilBajpai Test-Drives & Initial Ownership Reports 281 8th December 2016 16:08
4x4 Power, My Skoda Yeti Elegance. UPDATE: 63k kms up on page 6 Akshay1234 Long-Term Ownership Reviews 91 8th December 2016 01:11
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Black Storm-Safari GX 4x4. EDIT : 70k Kms update Lukeskywalker Long-Term Ownership Reviews 49 6th May 2013 16:58
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
