Old 12th August 2009, 17:20   #1276
4x4addict's Avatar
Thanked: 2,496 Times
Every injector comes with its own set of codes, if you do not match that in the ECU, there can be issues. Here some codes were mismatching. for example ECU was tuned for code A, when it should have been code 4 in one case.
I sincerely doubt the local dealers head mechanic has any clue what an ECU code is. All he had to do with the earlier 2.0 TCIC engine was take a hammer and knock the engine head a few times and it fixed most problems. Now they want him to start learning how to use a laptop, how dare they !
4x4addict is offline   Reply With Quote
Old 12th August 2009, 17:20   #1277
Rahulk76's Avatar
Thanked: 204 Times
Originally Posted by tsk1979
RPM issue is sorted. Problem with ECU parameters. Rest he checked all engine performance and injector pressure like parameters, and everything is normal.
So I go to Leh with her, if issue comes then we check it out after I come back.
However this time I suspect its not going to come again.
Next weekend (21st)
Jai Ho...
good to see the problem being correctly identified and addressed
Rahulk76 is offline   Reply With Quote
Old 12th August 2009, 18:57   #1278
Jaggu's Avatar
Thanked: 7,449 Times
Oh ok thats a convincing job i guess, you should post such info here for other safari owners to spook their dealers, if they are facing such issues
Old 12th August 2009, 22:03   #1279
tsk1979's Avatar
Thanked: 15,638 Times
Nobody on this forum has faced this issue, neither has any TASS etc., (Dada ludhiana, Sterling Noida. Autolinks gurgaon, Sanya Delhi) seen any safari with this issue. My white elephant is truly an unique specimen, one of a kind.
Old 13th August 2009, 13:56   #1280
Thanked: 297 Times
Well you have been calling it a white elephant for quiet some time ( out of affection ofcourse). How does the name Airawat sound (Indra's the mythical white elephant ???)
rajneeesh is offline   Reply With Quote
Old 13th August 2009, 14:17   #1281
tsk1979's Avatar
Considering Indra's love of opulance, I think I will call mine the White Elephant only. God knows what luxury demands she will start making once the namkaran happens
Old 13th August 2009, 15:29   #1282
hey good to know your white elephant getting back to shape and that pune chap is really knowledgable person.
One thing that comes up is does dealers service assistance really have that perfect knowledge of ECU settings with new technology, as what your problem thought one of its kind still makes one feel tata needs to give substance training if such of complaints rises around.
Awaiting to hear more from your coming Leh trip.Have a safe journey.
vijaythacker is offline   Reply With Quote
Old 13th August 2009, 16:20   #1283
tsk1979's Avatar
Default Finally I get her back
The clutch was hard, so changed under warranty!
This is one thing good about tata. No grief for warranty replacements.
Now the clutch feels like a santro clutch! No kidding!
The idle surging has not come back, but 100kms is too less to conclusively tell.
Have placed order for ECU cover also, If it comes before my trip, well and good!
Old 13th August 2009, 20:08   #1284
mjothi's Avatar
Thanked: 216 Times
Good to hear that. So, you are all set to be Leh'd. Congrats.
mjothi is offline   Reply With Quote
Old 16th August 2009, 21:31   #1285
tsk1979's Avatar
Default The idler ghost is back!
Its very pleasant in Delhi today, for a change.
The white elephant is also feeling happy, so she has started singing again.
Oscillations now appear to be 768-800-832-864 type.
Slower and more melodious that the curt grr grr earlier.
They come only when AC on now, without AC no issues.
I will tell the engineer, that 200kms after his software adjustment, the ECU is back to its old ways.
But now I am not going to get it fidgeted with again, and will see to it once I am back from the trip.
Old 16th August 2009, 23:09   #1286
4x4addict's Avatar
My friends Bolero had a similar idle surge issue which was tracked down to a bad alternator. Changing the alternator fixed the issue. Maybe related to the alternator increasing the rpm as it requires(or thinks) it requires more current.
Old 16th August 2009, 23:58   #1287
tsk1979's Avatar
Alternator change did not have any effect, so they put old one back in. I suspect something to with AC, as this problem is there now with AC on.
Maybe the AC pully is putting a higher than normal load on engine?
Old 17th August 2009, 08:06   #1288
raj_5004's Avatar
Thanked: 2,030 Times
When i read your title, the first thing that came to my mind was "Oh NO, Not again"! just when i thought that everything was sorted out & you are enjoying your best.
but when i read the post, i was happy as the issue is minor and you are not bothered with it anymore. again wishing you 'happy motoring'.
Old 17th August 2009, 08:44   #1289
sudev's Avatar
Thanked: 2,383 Times
@tsk1979: I would not to touch the WE with iffy repairs so near a long journey. Unless the problem is severe just go out and enjoy. Come back and attend to the demands of WE
sudev is offline   Reply With Quote
Old 17th August 2009, 08:50   #1290
greenhorn's Avatar
Thanked: 1,309 Times
I was told recently by my service advisor that the intermittent surging issue ( I experienced it for a few minutes before it went away) happens if the contacts are loose/dust or something else interferes with the sensors.
Maybe you have an elusive and intermittent loose contact somewhere
The Abominable (Skoda) Yeti *UPDATE* 20,000Kms Update on Pg.14 SushilBajpai Test-Drives & Initial Ownership Reports 281 8th December 2016 16:08
4x4 Power, My Skoda Yeti Elegance. UPDATE: 63k kms up on page 6 Akshay1234 Long-Term Ownership Reviews 91 8th December 2016 01:11
Jonga 4x4 or M&M Jeep CJ3B 4x4 gd1418 SUVs, MUVs & 4x4s 49 24th May 2013 13:57
Black Storm-Safari GX 4x4. EDIT : 70k Kms update Lukeskywalker Long-Term Ownership Reviews 49 6th May 2013 16:58
Opinion wanted - Dicor VX 4X4 vs Endeavour XLT 4X4...updated Now Booked Dicor VX 4X suman SUVs, MUVs & 4x4s 80 1st April 2009 14:11
