| LinkBack | Thread Tools | Search this Thread |
| | #781 | |
| Distinguished - BHPian ![]() | Quote:
| | #782 |
| BHPian Join Date: Aug 2007 Location: Pune
| Tanveer mentioned that the pipe is flimsy. From what I recollect, the pipe is not flimsy. It is also possible that TASS may have changed this pipe during one of the many visits. In such an scenario they may have fitted a longer / shorter pipe resulting in the bend. |
| | #783 | |
| Team-BHP Support ![]() | Quote:
Now open your bonnet and try to pinch this pipe, it pinches easily. In my case it has bent at the exact place it goes in the clip. It was out of the clip and bent. The last time TASC touched this vehicle was around 10000kms, and this issue came at 12500. So somewhere in between due to vibrations etc., it came out, maybe touched the radiator and due to heat got bent. I don't know how it got bent or why it did, but I am sure if it had been as hard as your kitchen gas pipe, it would never have bent. And be thankful that your kitchen gas pipe is not made by Tata. BTW, another update, I spoke to a few people about the surging at cold start which as been there from day one. Apparently its due to faulty EGR. EGR valve is not opening fully when its very cold, hence the erratic idle at cold start. I wonder what all I will keep on finding as I prod further. Is anything even right with this thing? | |
| | #784 | |
| Team-BHP Support ![]() Join Date: Feb 2004 Location: New York
Thanked: 933 Times
| Quote:
| | #785 |
| Distinguished - BHPian ![]() | Isn't this the "hiccup"ing that Dadu had mentioned on the 2.2 problems thread & TML replaced the EGR in his vehicle? I thought all you guys with similar symptoms were doing the same. |
| | #786 |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
Thanked: 957 Times
| Fluid and gas dynamics my dear friends, can create amazing master piece out of rubber tubing. Stop the denial and if you are smart enough safari owner, go get a decent rubber tube and replace it to avoid such mishap, will cost under 100-200 INR OR atleast tie the tube up properly so that it wont wander. |
| | #787 |
| Team-BHP Support ![]() | I did not have any hiccuping. Only on cold start(in winter type climate, not summers) it would do grr, grrr grrr with rpm needle dancing between 800-1200rpm the expected this problem to go away with FP and injector change, but it did not, so it seems EGR needs to be changed. |
| | #788 | |
| BHPian Join Date: Apr 2005 Location: BLR
| Quote:
Note from the Team-BHP Support: Slang and SMS Language are STRICTLY prohibited on Team-BHP. Please type in full and proper English for the benefit of other community members. Last edited by Technocrat : 17th March 2009 at 15:53. Reason: see note in post | |
| | #789 |
| Senior - BHPian Join Date: Feb 2005 Location: Delhi
Thanked: 90 Times
| More than anything, its sheer bad luck. I cant possibly imagine that pipe bending on its own even though its out of the clip, with a hot coolant flowing through it, not as much to stop the flow of the coolant properly for sure. |
| | #790 |
| Senior - BHPian Join Date: Jan 2007 Location: NAMMA BENGALURU
Thanked: 1,097 Times
| What EGR, better ask those people to change the Safari itself. How long would you be the test mule for TATA's. Its better you find one final and last solution. I cant help but laugh at the whole situation of yours(Not sarcastic) This is a complete " Comedy of Errors" ![]() |
| | #791 |
| Distinguished - BHPian ![]() | |
| | #792 |
| Team-BHP Support ![]() | But I never march the car without idling for atleast a minute, and once you press the accelerator, the problem goes away, its only at idle No not twisted, just a bend in the middle where it goes into clip. I think it came off the clip, touched something hot for a while and developed a crimp there Last edited by tsk1979 : 17th March 2009 at 15:38. |
| | #793 | ||
For starters, is there enough play for the pipe to move enough for that point to toch the radiator ? If it did, is the radiator, at the point where the pipe would have touched, hot enough to de-form the pipe ? Quote:
Even if the pipe did move sufficiently to touch something hot, it is more likely that some other part of the pipe could have touched a (different) part of the engine bay that is hot enough to cause the deformation. Not that part where it is currently bent. Last edited by condor : 17th March 2009 at 15:52. | ||
| | #794 |
| Team-BHP Support ![]() | The pipe is long enough to touch the radiator. And its not hard like your gas pipe, its like the pipe with which you water your garden(the soft type) |
| | #795 |
| Distinguished - BHPian ![]() Join Date: Jul 2006 Location: Bangalore
Thanked: 655 Times
| My observations on the pipe problem from looking at the photos posted by ADC. 1. The first thing I see wrong is the positioning of the clip. It will cause the pipe to bend more than it needs to as it will cause the pipe to bend inward and squeeze itself against the metal frame over there. Second place where the pipe will get squeezed is at the coolant reservoir connecting pipe. 2. I also find the pipe to be longer than what is actually required or maybe it looks that what in the photo. |
Similar Threads | ||||
| Black Storm-Safari GX 4x4. EDIT : 70k Kms update | Lukeskywalker | Long-Term Ownership Reviews | 49 | 6th May 2013 16:58 |
| Tata Safari 4x4, completes 4 years | bj96 | Test-Drives & Initial Ownership Reports | 113 | 6th March 2013 21:18 |
| Need help with Safari 4X4 | sandeepgnair | SUVs, MUVs & 4x4s | 2 | 25th September 2010 13:00 |
| Safari EX 4x4, RED!!! | Abhiknov | Test-Drives & Initial Ownership Reports | 105 | 29th August 2009 02:37 |
| Never Take Your 4x4 Safari To TASS. | AMAN_SACHDEV | Indian Car Dealerships | 31 | 2nd July 2009 19:23 |
