Old 23rd March 2009, 16:01   #946
smsrini's Avatar
Thanked: 77 Times
Default Can you confirm this
TSK,
Post the service light issue( 80kms test ) fix, have you observed any change in the Engine RPM when you coast ?
In my case, I feel that before the Injector change, the engine used to drop speed very fast, whereas now it takes much longer ( almost twice ) to reach below 1300rpm.
Also in cold starts in the morning, the engine noise has considerably reduced, engine feels smoother.
thanks
Srini
smsrini is offline   Reply With Quote
Old 23rd March 2009, 16:19   #947
tsk1979's Avatar
Thanked: 4,267 Times
Nope, everything is same. Smoothness was never an issue, and still isn't, thankfully
Old 23rd March 2009, 17:55   #948
Jaggu's Avatar
Thanked: 804 Times
Check coolant level by opening the cap (when cold) this time just to rule out a faulty cap.
Old 27th March 2009, 15:46   #949
Shyamtanu's Avatar
HI Tanveer,
Any updates on this? Howz the beast running now?
The remaining issues (the sound from front suspension etc) hopefully are gone now, or they are still there?
Shyamtanu is offline   Reply With Quote
Old 27th March 2009, 16:14   #950
tsk1979's Avatar
Suspension sound comes very occaisonally, some more driving will let me know.
Cold start still means grr grr grr, that will be checked up at service.
Radiator is full of water, so leak went away after replacing radiator.
Old 27th March 2009, 16:18   #951
Thanked: 40 Times
...Radiator is full of water, so leak went away after replacing radiator.
Had any luck in trying to find out what caused this leak in the first place? And how is the pipe left now? Thru the clip - isn't it?
HappyWheels is online now   Reply With Quote
Old 27th March 2009, 16:46   #952
tsk1979's Avatar
Pipe is out of the clip. I think I will let it be so.
As for what caused the leak, it was due to some joint issue near the battery, detail I will get to know once I visit workshop for 15K service
Old 27th March 2009, 17:20   #953
deepgautam_qa's Avatar
Thanked: 7 Times
Tanveer, are you going to take it for another hill-cruise before 15K service?
deepgautam_qa is offline   Reply With Quote
Old 27th March 2009, 17:54   #954
Shyamtanu's Avatar
Actually, the radiator can leak at any point during your ownership, since they are all pressurised these days... just like you can have it in refrigerators... though not very commonly heard. I am of the opinion that it is one off case with Tanveer.
When I banged my Alto behind another Alto... the lady driving in front did some hard (read panic) braking suddenly on the right most lane on Pune-Bangalore highway .. the speed will be around 70 when I applied the brakes, their were some tyre marks on the road.. and a little skdding of the rear wheels, kind a fishtailing... my bonet was looking like a 'Papad' right front panel bent, came inside, so right door would not open, right headlight assembly gone, the bumper came inside and was almost toughing the engine bay... it actually has no resistance... it works more like a collapsible plastic. I am not complaining, I knew this is the quality and it is not built for highway driving... but problem was that the AC pipe coming from the radiator and expansion assembly was bent.. and it seemed for a while that the radiator has leaked.. Thankfully no leaks had developed.
But I was told by Maruti that if that was leaked, bill for that itself will be around 16000 (I was under insurance), how much it costs for a Safari?
Old 27th March 2009, 20:29   #955
simply_sunny001's Avatar
Thanked: 13 Times
Thats too bad to hear Shyamtanu
but let me clarify that there is lot of difference in strength of an ALTO's bumper and Safari's.
the one in Safari is pretty strong so minor crash or watever wont be able to trouble anything but the paint of the bumper or maybe pasting of headlight assembly if the impact is on sideways.
simply_sunny001 is online now   Reply With Quote
Old 27th March 2009, 20:48   #956
Thanked: 45 Times
Whoa there!
Tanveer's Safari has never kissed anyone's or anything's behind!
And what a philosophical statement to make about radiators can leak on you at any time! Man, you scare me!
It certainly is NOT the norm!
Old 28th March 2009, 09:57   #957
sudev's Avatar
Thanked: 405 Times
A bit OT on this thread but...The crumple zone design of most modern cars results is what happened to the Alto. This also results in shocks being absorbed. Just yesterday I saw a Alto Indica head on (wish I had my camera) and surprisingly Alto passengers came out better. Indica front left seat guy banged his head on to windscreen (look ma no seat belt!!) and the rear passengers injured themselves hitting the front seats. But this all dependes on angles and velocities and loads of other factors.
Tanveer are you out playing OTR today?
sudev is offline   Reply With Quote
Old 28th March 2009, 14:00   #958
jaysmokesleaves's Avatar
Thanked: 127 Times
The Safari's front end is very different from the Alto. See the pic below. It was taken when I had removed the grille for wiring the Hellas.
There is a strong steel crossmember that is a welded part of the chassis. This protects the condenser and the radiator in a big way incase of a frontal collision. I think it is quite capabable of taking a hard knock without causing much damage to the Safari. No idea what will happen if a sedan is shunted from the back by a Safari.
jaysmokesleaves is offline   Reply With Quote
Old 28th March 2009, 15:38   #959
Jaggu's Avatar
Thanked: 804 Times
From the looks of it, small shunt and you will have broken fan and/or ac radiator. Trust me the bar will bent in case of frontal collusion, i thinks its there to give more rigidity to the chassis frame.
Old 28th March 2009, 17:38   #960
extreme_torque's Avatar
Thanked: 90 Times
You cant possibly save the radiator in case of a frontal collision in any car. The difference is that some car will have a radiator leak even if they hit a dog and some wont.
extreme_torque is offline   Reply With Quote
Black Storm-Safari GX 4x4. EDIT : 70k Kms update Lukeskywalker Long-Term Ownership Reviews 49 6th May 2013 16:58
Tata Safari 4x4, completes 4 years bj96 Test-Drives & Initial Ownership Reports 113 6th March 2013 21:18
Need help with Safari 4X4 sandeepgnair SUVs, MUVs & 4x4s 2 25th September 2010 13:00
Safari EX 4x4, RED!!! Abhiknov Test-Drives & Initial Ownership Reports 105 29th August 2009 02:37
Never Take Your 4x4 Safari To TASS. AMAN_SACHDEV Indian Car Dealerships 31 2nd July 2009 19:23
