Old 30th November 2011, 12:25   #301
JVH
JVH's Avatar
Thanked: 148 Times
Default re: Palio GTX - Red beast comes home! EDIT: update @100,000 kms
Originally Posted by lohithrao View Post
Jayant, get it done from Raj. he work is good and it should cost about 18k
Yup, I had him in mind. Will call him and check out.
Originally Posted by JayD View Post
Actually, im yet to install a freeflow on my car. Many of my friends have S10's with FFE's from different companies, so just deciding on which one!
In other news, i bought another S10! So will try different FFE design for both cars! Hehe!!
I have driven an S10 with stock headers and just an end can, it sound ok, because the stock engine note is good, but performance gain is nil. And it costs as much as an FFE, i would say FFE anyday.
Lol! Looks like you have been smitten by the S10 bug. I envy you
Do keep me updated on the FFE. Too bad you are in Cochin else we could have gone for it together.
JVH is offline   Reply With Quote
Old 30th November 2011, 12:43   #302
JayD's Avatar
Thanked: 1,996 Times
Hehe! Thanks! The feeling that i have two identical cars is just sinking in though!
Im from cochin, the car is in Chennai. Still deciding whether to get the FFE from Raj or from Coimbatore.
I'll just post my views on different FFe's, based on my driving experience.
1) Automech- The most popular FE for the palio. And undeniably, the WORST. Its makes the car sound like someone is drilling thru concrete! Engine becomes feels more free than stock. Life of the product is bad, end car breaking off just after a year is common, so are leaks from the mid pipes. No matter how much you tell them to 'customize', you will get the same thing!
2) Raj- Exhausts by Shabbir are probably the best sounding in the country, presently. It sounds like a proper Tuner car, and you will love pushing it. High revs are pure music. But, it is also very loud, deep and bassy. No matter how quiet you tell him to make it, it will still be on the noisier side. The low end will suffer quite a bit, but mid and top end will be good. There will be a bit of vibrations too. Life is average, with end can being a weak point, in some cars.
3) Coimbatore- It is done by a guy, popularly known as 'Exhaust Bhai'. He is an expert on FFE's especially for rally cars. he used to make for leela when he was in coimbatore, and it is said he does it for RRP too. But i had got an FFE from RRP for the OHC Vtec, which sounded horrible.
Performance is fantastic, especially low and mid end. Sound can be customized too. But it will always be a rally car like, high treble sound. Not a patch on Raj exhaust note tho.
Good life for the product too. A friend has it for over 4 years on his OCH, with just a lil issues in the end can.
These are just my personal opinions. hope it helps.
Raj quoted 14K for my S10.
JayD is offline   (2) Thanks Reply With Quote
Old 30th November 2011, 12:45   #303
lohithrao's Avatar
Thanked: 163 Times
Seems like he charges more for Adventure?? last month he quoted me this, if he had quoted 14 i would have happily gone for it:(
lohithrao is offline   Reply With Quote
Old 30th November 2011, 13:50   #304
JayD's Avatar
Default Re: Palio GTX - Red beast comes home! EDIT: update @100,000 kms
Could be, maybe due to the extra length.
Old 8th December 2011, 12:50   #305
planet_rocker's Avatar
Thanked: 366 Times
Slightly OT, but i found a nice website which provides information on Palio Rubber Parts with part numbers.
Click: www.parulrubber.com/product-palio-114.htm
Link Source: PUG
planet_rocker is offline   (2) Thanks Reply With Quote
Old 6th April 2012, 16:55   #306
JVH
JVH's Avatar
Thanked: 148 Times
Got the car serviced today. It was lying more or less unused after my last update. The only issue was the injector light coming on and fluctuating rpm at idle. The culprit was the rpm sensor which is now replaced and the problem's solved. Routine oil and filter change, coolant change, and other inspection jobs were carried out.
Did not get the opportunity to explore FFE. The leather inside also needs a change. These 2 will be the points to ponder in the next few days.
JVH is offline   (2) Thanks Reply With Quote
Old 1st May 2012, 09:10   #307
JVH
JVH's Avatar
Thanked: 148 Times
I encountered the dreaded fluctuating rpm problem just when I was about to leave for my hometown for a 2 week vacation. All packed and ready early in the morning, I started the car and just by the sound of the idle, it was clear something was wrong. The idle was erratic and the engine was getting shut after a few seconds. I sensed the culprit as the recently replaced rpm sensor or cut/bitten injector coils. Called my mechanic early in the morning. He says don't worry, continue the journey and all will be fine. Nothing was fine after that. I drove in that condition, only to be royally looted. I had to shell out almost Rs. 6000/- this time for fuel while the usual cost would be Rs. 2500/-. It was clear now that the fuel was not getting properly burnt.
As soon as I reached my hometown, got freshened up and went to a local mechanic which our family driver located. I got him connected to my Bangalore mechanic and they started the diagnosis. A wire was cut in the rpm sensor and quite a lot of carbon was deposited. We cleaned it and wound a tape after working on the wire. The idle was now smooth but around 1000-1200 rpm. We cleaned it once more and the injection coil as well. Problem solved. Damages 150 bucks.
Another work done was re-filling of the AC gas. 1600 bucks.
Old 2nd May 2012, 22:32   #308
lucifer919's Avatar
Thanked: 307 Times
Hello JVH,
could you please put up a picture of where this RPM sensor is if possible? i have this as an intermittent issue with my car especially in the rains. and now, with Bangalore getting the heavy rainfall that it is, i would like to check this and fix if found to be a problem.
the reason i would like a photo is because i plan a DIY on this and a pic would be really helpful to ensure i dont clean something i'm not supposed to
lucifer919 is offline   Reply With Quote
Old 3rd May 2012, 12:29   #309
Thanked: 366 Times
RPM Sensor is located below the engine bay near the crank, unlike in 1.2 engines, where it is very easily accessable.
It is a thick long black wire. unfortunately, i dont have a pic. No wait!! you are in luck
Here it is (post number 197 - first pic)
http://www.team-bhp.com/forum/long-t...ml#post2100198 (Palio GTX - Red beast comes home! EDIT: update @100,000 kms)
planet_rocker is offline   (1) Thanks Reply With Quote
Old 3rd May 2012, 13:47   #310
JVH
JVH's Avatar
Thanked: 148 Times
Have marked it using the same pic which Surya pointed out. You need to remove the sensor from the socket, blow compressed air and clean with oil. Blow air on the socket as well (connecting the engine). If there is a lot of carbon deposit, better to take it to Mechanic because it will be difficult to get rid of it by ourselves.
Palio GTX - Red beast comes home! EDIT: update @100,000 kms-rpm-sensor.jpg
JVH is offline   (1) Thanks Reply With Quote
Old 3rd May 2012, 20:08   #311
lucifer919's Avatar
Thanked: 307 Times
@Planet_Rocker, JVH, thank you for the pic. will get around to doing this in the weekend.
My car has also done 78,000 kms now and the suspension clank is getting on my nerves. Got an update from Vinit_metchant about the cause. got to get that part checked ASAP. also, the pipe holding the air filter in my car broke so got to get that replaced/fabricated also. planning on going to TDi racing in Jakkur for this. anyone here have any experience with them?
Cheers and drive safe,
Kiran.
Old 10th May 2012, 08:25   #312
Thanked: 110 Times
Thats a MAP (Manifold Absolute Pressure) sensor not the crank a.k.a RPM sensor. Its obvious you got the black soot in the exhaust when the MAP wire got cut off. The system relies on TPS and pre determined MAP tables which always run rich to avoid engine damage.
vijaycool is offline   (2) Thanks Reply With Quote
Old 10th May 2012, 11:33   #313
Thanked: 366 Times
Ooops! Jayanth - read your post just now. That is the MAP sensor as pointed out by Vijay.
I pointed to the black wire in the First picture that is the RPM / Crank sensor wire.
Old 10th May 2012, 13:46   #314
JVH
JVH's Avatar
Thanked: 148 Times
Thanks for the correction. I recall now that the mechanic had just mentioned sensor and it was me who got confused with RPM/MAP.
BTW, it was the MAP sensor which was diagonised and cleaned.
Old 4th June 2012, 10:29   #315
JVH
JVH's Avatar
Thanked: 148 Times
The latest damage is the ignition coil. The car was not at all picking up between 1200-2200 rpm giving a sputtering sound and jerking. When hooked to the analyzer, it showed that the ignition coil had gone bust. Replaced with a brand new one. The car now feels like its on steeroids. All good. Hope there are no more surprises.
Rs. 4500 including labour.
'The Red' is home: Fiat Punto 1.3 MJD Dynamic. EDIT: 30,000 kms up! vibbs Test-Drives & Initial Ownership Reports 45 22nd October 2016 09:32
2013 Mahindra Bolero - Rumble Tumble Tank comes home! EDIT: 14,000 Kms Update ByDesign Test-Drives & Initial Ownership Reports 123 13th May 2015 14:32
Performance twins on a Budget- Palio 1.6 GTX Vs Ikon 1.6 (Edit - Its a Palio 1.6 GTX) Makesh Hatchbacks 48 9th October 2012 01:34
PALIO 1.6 GTX 2001-1.5 LAKHS?? ( calling all palio GTX owners ) karizma_devil Hatchbacks 18 28th December 2008 13:04
Chennai to vizag (1928 kms) on my new Beast! (EDIT: Beast=Fiesta 1.6 zxi Petrol) gopal.putrevu Travelogues 19 18th April 2008 13:35
