Old 19th April 2010, 11:01   #91
lohithrao's Avatar
Thanked: 163 Times
i really wish that it can be fixed as the new fan costs 7500, couple of mechs whom i spoke to suggested me not to repair the fan??
Originally Posted by JVH View Post
Show it to the mechanic and get it repaired ASAP! Mine is beyond repair and replacement is the only solution.
It's also a matter of spending a few hundreds instead of a few thousands if you take my way
lohithrao is offline   Reply With Quote
Old 19th April 2010, 11:05   #92
JVH
JVH's Avatar
Thanked: 148 Times
Depends on what needs to be repaired. In my case, the shaft was losing play. Mechanic tells me had I brought it immediately, he would have repaired it in 200 bucks.
A big dig in the pocket I know and the other thing is part availability. Mechanic is on a hunting spree and lets hope he gives me some positive news today.
JVH is offline   Reply With Quote
Old 19th April 2010, 13:15   #93
drifter's Avatar
Yes, the fan is about Rs 8000 here in Bombay. Some parts are still expensive. It was available till last month at the dealership here. The Tata-Fiat dealership here doens't have spare parts problems as far as I've seen.
Drifter
drifter is offline   Reply With Quote
Old 19th April 2010, 15:14   #94
JVH
JVH's Avatar
Thanked: 148 Times
I just finished talking to my mechanic. He claims that fan motor alone can be worked upon. A few members in PUG have also claimed the same. There is no update on cost though.
Will keep posted.
Old 19th April 2010, 15:51   #95
lohithrao's Avatar
Thanked: 163 Times
great,i guess even my cars fan motor would have gone. hope it canbe fixed at a reasonable cost?
Old 21st April 2010, 11:22   #96
JVH
JVH's Avatar
Thanked: 148 Times
Alright! Here's the update
The fan motor was the main culprit. But it did not die alone. It took along the fan and most of its assembly with it. Don't ask me how but the complete assembly was worked upon. I should thank my stars that there was a scrap Sienna weekend lying around from which we took the parts. Only the fan motor was brought new. Yes it was indeed Ford Ikon 1.6's motor and it costed 2K. Lohith, are you listening?
Pic 1 - This whole set was replaced
Pic 2 - Crack in one of the components of the assembly
Pic 3 - More cracks, although invisible
Pic 4 - Heat coil sensor was also replaced
Palio GTX - Red beast comes home! EDIT: update @100,000 kms-img00033201004201628.jpg
Palio GTX - Red beast comes home! EDIT: update @100,000 kms-img00034201004201629.jpg
Palio GTX - Red beast comes home! EDIT: update @100,000 kms-img00035201004201629.jpg
Palio GTX - Red beast comes home! EDIT: update @100,000 kms-img00036201004201629.jpg
Old 21st April 2010, 12:17   #97
planet_rocker's Avatar
Thanked: 368 Times
Congrats JVH do give us an update after running it for some time.
Ford Ikon 1.6 Fan Motor works in the Palio 1.6 - Noted
planet_rocker is offline   Reply With Quote
Old 21st April 2010, 13:42   #98
JVH
JVH's Avatar
Thanked: 148 Times
Thanks and will surely update. There's another motor of Korean make which is also equally good. I forgot the name.
As I said in the previous post, it was not as simple as just the fan motor. So folks, request you to show it to the mechanic ASAP if you encounter strange noise in the fan assembly or if the temperature needle goes beyond the half way mark. Its very difficult to predict what the motor takes along with it during its last stages.
The total damage for the fan assembly was 4K including the motor. I was lucky enough to find a lying Sienna around from where we could procure the parts.
Also got the servicing done. Regular oil and filter change, fluid top ups and the washing stuff. This was about 2K including labour. The car now rides like a charm. Makes you forget the cost damage done earlier. Precisely why one never gets tired of it . Just Beautiful!
Old 21st April 2010, 14:46   #99
Thanked: 18 Times
@Jayanth,
Where did you get all these work done? My Fan motor Assembly is also making some noise when I keep the speed above 2 mark, when I showed it to the mechanic, he said not to worry!!! just wanted to know if I can get a quick check up done
ravikn is offline   Reply With Quote
Old 21st April 2010, 14:58   #100
JVH
JVH's Avatar
Thanked: 148 Times
Originally Posted by ravikn View Post
@Jayanth,
Ravi,
Where else? Our friend Venkatesh
What exactly is the sound like? Is it uneven metal interface kind or just a loud noise? If it is a loud noise akin to the normal fan noise, no issue, it sometimes happens.
The uneven noise could be because of a simple issue like a lose bearing or as complex as my issue. Bearing issue can be solved in a few hundred bucks where as an issue like mine would take anything beyond the stated costs below PROVIDED the parts are available.
Old 21st April 2010, 15:00   #101
Thanked: 368 Times
@ Ravi - are you talking about the in-cabin fan? didn't get when you mentioned that the fan assembly makes sound if you keep the speed above 2 mark? do you mean above 2k rpm?
Old 21st April 2010, 15:22   #102
JVH
JVH's Avatar
Thanked: 148 Times
I think he means the speed level of the fan. 1, 2 levels are fine but 3 and 4 are creating the noise.
Right Ravi?
Old 22nd April 2010, 12:26   #103
Thanked: 18 Times
Right Ravi?
Yes sir, you got it.
@planet_Rocker,
It does make some kinda metallic sound if I keep the fan speed above 2, I did ask the electrician from Venkatesh's Garage and he said not to worry and live with it!! since to replace this will cost me 7K
Old 22nd April 2010, 12:51   #104
lohithrao's Avatar
Thanked: 163 Times
phew i have noted that i can get the motor of Ford Ikon for 2k today i have left thecar at TASS and have clearly told the advisor that am keen on getting it repaired and not replaced
will keep you guys posted!
Old 22nd April 2010, 15:26   #105
lohithrao's Avatar
Thanked: 163 Times
JVH, my car's radiator fan has gone and needs to be replaced, it seems the orginal cost about 6k
IKON fan+ the motor is 4k ? if so can you give me the model number etc?
and is it a direct fit??
thanks
2013 Mahindra Bolero - Rumble Tumble Tank comes home! EDIT: 14,000 Kms Update ByDesign Test-Drives & Initial Ownership Reports 124 5th March 2018 20:51
'The Red' is home: Fiat Punto 1.3 MJD Dynamic. EDIT: 30,000 kms up! vibbs Test-Drives & Initial Ownership Reports 45 22nd October 2016 09:32
Performance twins on a Budget- Palio 1.6 GTX Vs Ikon 1.6 (Edit - Its a Palio 1.6 GTX) Makesh Hatchbacks 48 9th October 2012 01:34
PALIO 1.6 GTX 2001-1.5 LAKHS?? ( calling all palio GTX owners ) karizma_devil Hatchbacks 18 28th December 2008 13:04
Chennai to vizag (1928 kms) on my new Beast! (EDIT: Beast=Fiesta 1.6 zxi Petrol) gopal.putrevu Travelogues 19 18th April 2008 13:35
