Go Back   Team-BHP > Indian Cars > Team-BHP Reviews > Long-Term Ownership Reviews
Long-Term Ownership Reviews Ownership reports, of Indian cars, spanning over several years and thousands of kms
Thread Tools
Old 14th September 2008, 10:00   #16 (permalink)
quicksilver's Avatar
Originally Posted by abhi1309 View Post
Yes my fathers old 83 model Padmini's R/C book said 12 HP. I don't know what was wrong with the 1980's.
Well, nothing was wrong really, it was one of the best times in fact. Our parents/grand parents had enjoyed driving like we never would. The cars seem under-powered on paper but were quiet adequate for the conditions they had back then.
I have heard stories about my Dad and his friends doing 100 MPH sprints on the highways (which I presume were almost empty compared to what we have now). The 137D was a different story though, surely underpowered but delivered an FE that was phenomenal even by today's standards. It could easily do 20KM/L for me with spirited driving (without A/C) and 18KM/L with A/C.
__________________
Market pulse and Sales volume are not something fanboys understand!
quicksilver is offline   Reply With Quote
Old 19th November 2008, 15:41   #17 (permalink)
I am planning to replace the gearbox(nissan floor) with any 5 speed box. I have 2 queires;
1) should i change the differential also?
2) will a isuzu box from ambassador/contessa fit without tinker work?
Apart from that i have asked for disc brakes from the 118NE.
ramzsys is offline   Reply With Quote
Old 19th November 2008, 16:10   #18 (permalink)
Do you want to do that because you need the 5th gear? The Nissan gearbox was a perfect match for that engine, butter smooth even with the diesel.
Besides that, I doubt if you'd be able to mate a ISUZU box without much tinkering.
Please do have a re-think about it.
__________________
Old 19th November 2008, 17:07   #19 (permalink)
planet_rocker's Avatar
this is what Mr. Dhabhar once said about the nissan GB:
After reading all the mails that you guys are shooting to each other on the S1 transmission et al, let me clarify as follows:
First of all, the ratios are 3.757 / 2.169 / 1.404 / 1.000 for NISSAN transmission and 3.86 / 2.38 / 1.57 / 1.00 for FIAT transmission.
The Padmini was introduced with NISSAN aggregates in 2 phases. 1 - only the gearbox (quite good number of cars were released in the field) and 2 - engine and gearbox (very very few cars were released in the field).
As far as the F4W56A gearbox is concerned, the main casing was changed to incorporate the Padmini engine bell housing configuration, so gravity die cast housings were made and cars were sold with these housings. The housings were not pressure die cast as the die cost is prohibitive. As far as your specific query on cross member is concerned, as the cars were with floor shift (deluxe BU) as well as column shift (deluxe BE), you will all appreciate that in the floor shift the stick is directly connected to the gearbox whereas in the column shift, the system is remotely operated. In order to have the column shift, original NISSAN design of shifter was adapted where the "REAR EXTENSION OF THE GEARBOX" is smaller in length (this gearbox is NISSAN van derived). Thus it was necessary for us to use a two piece propeller shaft in the column shaft car with the NISSAN gearbox (Euler's theory of long columns), whereas we stayed with the single piece propeller shaft in the floor shift gearbox as the length of the rear extension of the gearbox was adequate by design. Therefore, in the column shift car, there is a centre bearing for the propeller shaft (118NE derived), mounted on an additional cross member bolted to the floor. With the kind of corrosion that the floor is susceptible to, you can well imagine the condition of this cross member. Therefore, if anybody is thinking of buying an S1, I will strongly recommend only floor shift as these hassles are avoided.
Further, in the NISSAN transmission cars, the clutch was operated by a cable instead of a link which is another problem because Remsons cables who was the OE vendor may not be manufacturing these cables any more. With the kind of dusty environment at the cable location, performance gets disturbed.
Further, in order to orient the cable correctly away from the exhaust, thee is a 7 degrees orienting spacer assembled in the bell housing. Many mechanics do not know all this and end up destroying the design.
With all above information known to me (I happened to be one of the designers of these systems), I DO NOT PURCHASE NISSAN TRANSMISSION CARS AT ALL. I only purchase cars with FIAT transmission, so no problem.
__________________
Planet, Sonja, Etc - Elements of Life.
planet_rocker is offline   Reply With Quote
Old 3rd May 2009, 20:46   #20 (permalink)
So, finally got the engine specs.
http://www.engine-cemberci.com/engine/CMD/2.pdf
44 hp@4500 rpm, built by a marine diesel maker.
Also, there is a 60 hp turbo/ 75 hp intercooler turbo on the same engine.
__________________
This is the joy of owning a Fiat. You slog, but you enjoy it also
Old 31st May 2009, 01:12   #21 (permalink)
@quicksilver yes, the nissan's GB feels better, but for the OD. One of my relatives has got a Padmini with Mazda engine, 1.7 L (1720 cc) PN, Diesel, 8-valve, 57 hp/107nm He needs the versa(gypsy) gearbox, used or new. Can anyone give an idea of the price for a new box(provided Maruti is willing to sell) as a used one is as rare as Versa itself...
__________________
Old 31st May 2009, 21:32   #22 (permalink)
Today I gave my 137D for engine overhule. Now i am planning to change gearbox. Mostly I prefer 118NE gearbox. Can anybody suggest what are the work has to be done for this. Any suggestions are most welcome.
Thanks & regards
S. DAS
mituadas is offline   Reply With Quote
Old 31st May 2009, 23:10   #23 (permalink)
Dippy's Avatar
Nice review Ram. The 137D is one hell of a workhorse. A favourite among taxi drivers at one time. She looks clean too.
One of my relative had installed a Mazda mated to a isuzu 5 speed box. But getting an RTO endorsement is a problem nowadays.
I had the same combo in my Fiat. A Mazda 1.6 diesel mated to a 5 Speed Isuzu. It was an awesome performer and I used to smoke Esteems and Cielos at traffic lights. Very silent too once it warmed up. Miss that car.
__________________
The Automobile - It's just that special. Nothing else even comes close
Dippy is offline   Reply With Quote
Old 11th July 2009, 00:28   #24 (permalink)
jaisha8's Avatar
I have a Petrol engine Premier Padmini, 1996 model S1,Executive. Is it possible to change to Diesel engine, I mean would RTO authorize it? If so which would be the best Diesel engine for Premier Padmini.
__________________
Jk Benguela with
Linea Emo Pk
Tavera Neo B4
Ikon 1.8D
Padmini S1 Executive
RX-100
jaisha8 is offline   Reply With Quote
Old 11th July 2009, 21:28   #25 (permalink)
AFAIK, there is no problem in RTO endorsements for the original 137D engine. But the rules are getting stricter with reference to emission norms.
__________________
Old 12th July 2009, 01:44   #26 (permalink)
Silver Knight's Avatar
We had a 1993 model 137D which we used for 10 years an logged 1.25 lacs KM. Learned driving in that. Still has those sweet memories. Great car.
__________________
Swift VDi-Mar 09,8872 Km (101.98 Km/Day),Wagon R-01 Apr05 56,004 Km (37.41 Km/Day),P150 05 36K, Yamaha Rx100 95 1,22,245Km
Silver Knight is offline   Reply With Quote
Old 12th July 2009, 02:01   #27 (permalink)
great review ram!
does remind me of my first car a petrol premier padmini with steering attached gear shift.i learnt my driving on that car ,used it for 4 years and sold it of to a taxi driver for 30,000 in 1999.i remember during those days i used to fill up 10 lts of petrol in 100 bucks and it used to last me one whole month.
shantyrocks is offline   Reply With Quote
Old 13th July 2009, 15:06   #28 (permalink)
PP brings back a lot of old memories. I learned driving in one. It had a amazing steering and was fun to drive (it had floor gear but it was a pain). It was very well maintained by my father (my mother made sure of that), till we (my brother and me) started driving it. It was sold of in 2001 (for 15K).
p.s. remember AB driving a PP in the film Abhiman?
cuttingcrew is offline   Reply With Quote
Old 14th July 2009, 00:16   #29 (permalink)
loving_alaap's Avatar
We also had a Premier Padmini (petrol) in excellent condition. We had sold (with wet eyes litrally) last year, due to only parking problems. So, I can imaging, how you are feeling while you are driving.
Keep it up for as long as you can.
__________________
Ferrari Enzo
loving_alaap is offline   Reply With Quote
Old 18th July 2009, 13:12   #30 (permalink)
amanmalhotra's Avatar
Premier Padmini brings back the good old memories, remember learning how to drive on it and ramming it into a bullock cart. Nothing happened to the cart, but was left with a rather bad dent and a broken head light. Was **** scared to tell my Dad that I had banged his car.
Was a family car till 1999 when we, as a family, changed loyalties and bought a Maruti 800.
amanmalhotra is offline   Reply With Quote
Thread Tools
Premier Padmini 137D Gearbox Swap mituadas Modifications & Accessories 12 5th August 2009 21:48
What replacement engine for FIAT-1100D (premier padmini) hasopi Modifications & Accessories 25 5th August 2009 15:57
Fiat Premier Padmini - Shorter turning radius in reverse??? Shan2nu Technical Stuff 17 23rd July 2009 13:23
The lovely Premier Padmini S1 (Fiat 1100-D) Ram The Indian Car Scene 99 23rd July 2009 07:01
My 1987 Fiat (Premier Padmini) newcoolgadgets Long-Term Ownership Reviews 18 8th July 2008 13:11
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
